hs50EXR Can bounce!
Started Apr 22, 2013 | Discussions
TAGRIFFIN Contributing Member • Posts: 837
hs50EXR Can bounce!
My hs50 fell out of the tripod mount last night whilst carrying it back into the house....and from a height of, oh, 3 feet, the camera landed on a hardwood floor and bounced about 5 inches high! Lens cap came off and the memory card door opened and that was it!
Doesn't appear to be any damage and, thus far, everything seems to be functioning fine.
Kinda thought the camera would stay in the mount but a lesson learned and, of course, you get what you pay for!
Tim
jcmarfilph Veteran Member • Posts: 7,592
Re: hs50EXR Can bounce!
Good thing the lens did not separate from the body. I remember one fella who dropped his HS10 and then it's a useless cam afterwards. Dunno if you can use the separated lens and convert it into TC
-=[ Joms ]=-
 jcmarfilph's gear list:jcmarfilph's gear list
Fujifilm X20 Fujifilm FinePix HS50 EXR +1 more
TAGRIFFIN OP Contributing Member • Posts: 837
-=[ Joms ]=-
Doesn't seem to have done any damage whatsoever!
Tim
MitchyK7 Regular Member • Posts: 131
I dropped mine about the same height, but luckily onto thick carpet. Good to know these cams are more resilient than earlier HS models.
Peter71951 Contributing Member • Posts: 553
Tim
OK mr. Paul Till, now it's your turn to do this from a height of about 4 feet, because the X-S1 is more expensive. To proove that the X-S1 is more solid build than the HS50. We don't pay attention to the lens droop before or after.
Peter
wymjym Veteran Member • Posts: 5,473
Tim
Peter
I tote my XS1 with me all of the time in a soft bag attached to the rear rack of my ebike.
Last month I failed to zip up the flap and while zipping into my property I heard a clunk. The XS1 had popped out of the bag and threw itself onto the (hard packed clay) driveway. Height = 48"
I have always had a step-up ring and 72mm 'Nikon' pinch cap on this camera (love the pinch cap and have a lot of 72 filters). The cap was scratched and there was some dirt inside of the tripod mount....that was all I could see. The camera works as it did pre 'bouncing down the drive', no better....no worse. I am certain that if the lens had been extended and it had hit on that protrusion this story would have a different ending.
wj
nikonfujicanonandricoh
Tim
OK mr. Paul Till, now it's your turn to do this from a height of about 4 feet, because the X-S1 is more expensive. To proove that the X-S1 is more solid build than the HS50. We won't pay attention to the lens droop before or after.
Peter
wj
This encouraging answer from you will certainly persuade Paul to cooperate with this experiment
Peter
what? raise it to 5' with the lens extended.......
sort of hoping it would be sharper after the 'natural' shock alighnment attempt.
wj
wj
Well, you know he is THE man who stated over and over again that the HS50 is an inferior toycam and the X-S1 is far superior. Let's wait for his video.
Peter
wj
Peter
+1 lol. X-S1 was built like a tank. Let's see!
-=[ Joms ]=-
tazmac
tazmac Regular Member • Posts: 360
Paul is not digging this thread now!
