Issues with Zeiss 15mm with ND filter
Started Apr 21, 2013 | Discussions
Mssimo
Mssimo Senior Member • Posts: 1,041
I looked around for months and found only one slim ND filter made in the 95mm size for the Zeiss 15mm f2.8.
Here is what I was looking for: DARK (1000x or ND3 or 10 stops) Slim or thing (less than 5.5mm)
I got this one of B&H: Heliopan 95mm Neutral Density (ND) 3.0 Filter Price was $341
Camera body is a D800E
I got some mixed results:
Issue is with the purple band from one side of the image to the other. Does it most at f22 but can be seen from f11. Is this because of the filter or the front element or elements on the lens.
 Mssimo's gear list:Mssimo's gear list
Nikon D810 Carl Zeiss Distagon T* 2/25 Nikon AF-S Nikkor 85mm f/1.8G Sigma 35mm F1.4 DG HSM Art Sigma 120-300mm F2.8 DG OS HSM +4 more
Nikon D800E
87350iroc Junior Member • Posts: 43
Re: Issues with Zeiss 15mm with ND filter
Sure looks to me like you didn't cover the viewfinder.  This will happen with any lens and is not the lens's fault.
 87350iroc's gear list:87350iroc's gear list
Nikon D600 Tokina AT-X Pro 100mm f/2.8 Macro Tamron AF 28-75mm F/2.8 XR Di LD Aspherical (IF) Nikon AF-S Nikkor 28-300mm f/3.5-5.6G ED VR Nikon AF-Nikkor 80-200mm f/2.8D ED +5 more
Mssimo
Mssimo OP Senior Member • Posts: 1,041
Your right! But now i have to test to see if its the view finder or filter.
Mssimo
Problem Solved. Viewfinder letting light in.
Problem Solved. Viewfinder letting light in. I can now to a full review on the filter.
Look at this cool landscape..I had the cap on the lens, viewfinder open. (un shaded)
