Wide angle (to normal) magic. Long lenses, not so much.
Started Apr 21, 2013 | Discussions
bigpigbig
Senior MemberPosts: 1,721Gear list
Apr 21, 2013
It is no surprise that Fuji started with 18mm, 35mm, 60 mm primes. Next came the 18-55mm zoom and then the 14mm prime. All these lenses are what make this camera special. Why? Because with short focal lengths, you can have a fast lens without it being HUGE. F-number=Focal Length / Diameter of the aperture. The apertures of the primes wide open are; 35--25mm, 60--25mm, 18--9mm, 14--5mm. These maximum aperture sizes (less than 25mm)  allowed the lenses to be kept small and, in my opinion, well balanced on the X-Pro1 and XE1 bodies.
The next two lenses in the lineup seem less "ideal" in size and weight. The 56mm f1.2 will need a 47mm maximum aperture. Almost double the largest to date. The 55-200mm 3.5-4.8 will need a 42mm aperture for the long end. At some point, the lens becomes so big and heavy that it defeats the purpose of having a small lightweight mirrorless system.
For example, in order to have a lens that would perform equivalent to a 200mm f2 would need to be an impossibly huge 135mm f1.4 with a diameter of almost 10cm.
Don't get me wrong, I am into this system with both feet. I love the handling and quality I am getting from a lightweight system. I have the 14, 35 and 18-55, as well as a 12mm Voitlander. I just don't am not convinced about using it with long lenses. The longer the lens, the more important balance (and very fast, accurate AF) becomes.
Does anyone else think the 55-200 fully extended looks ridiculous on the XE1?
It is no wonder why Leica had a 135mm f4-ish as its longest lens for their compact system.
 bigpigbig's gear list:bigpigbig's gear list
Fujifilm X-E1 Fujifilm X-T1 Nikon D810 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +12 more
Fujifilm X-E1 Fujifilm X-Pro1
David McGaughey
Senior MemberPosts: 2,246
Re: Wide angle (to normal) magic. Long lenses, not so much.
In reply to bigpigbig, Apr 21, 2013
This has more to do with limitations of the optical viewfinder of a rangefinder.
Mr Gadget
Senior MemberPosts: 1,947
I guess I would have to say that an X-E1 with the 55-200 is way smaller and lighter than my D2x and 70-200 f2.8. It would be nice when someone gets one to have them do a side by side comparison shot with some of the equivalent DSLR systems. All things are relative, it may look funny, but my bad shoulders would greatly appreciate it's compact size and lighter weight.
Conrad
Show Low, Arizona
bigpigbig
In reply to Mr Gadget, Apr 21, 2013
Conrad
Show Low, Arizona
True, but you'd need a 50-135 f2 for an equal comparison with the 70-200 f2.8. I am not sure it would be much lighter then.
The very excellent Nikon 70-200 f4 is only 200 grams heavier than the Fuji zoom.
About the Leica focal length limitation being a optical viewfinder, yes, you are right. Though I still wonder about balance.
Rod McD
Veteran MemberPosts: 3,530Gear list
In reply to bigpigbig, Apr 22, 2013
Hi,
I tend to agree, but it's a personal view - it really depends on how you value small size, balance, and weight and also the size of your overall kit.  It's the reason I posted the concurrent thread titled "Anyone else think the X system needs a longer prime".  Zooms are incredibly versatile, and tele-zooms more so than WA zooms, but they're simply bigger.  I'd like to see a small ultra sharp X mount AF lens of around 100/2.8 added to the range.  In the meantime I've got a legacy Pentax 100/2.8 I will try.
If you look through the posts on the DPR News page in response to the release of the 55-200 you'll see some similar comments about the size  and weight of the lens.  OTOH you'll also see quite a few people just aren't worried about the size of their kit at all.  I don't quite 'get' this - surely the advantage of mirror-less is the reduction in kit size from a DSLR?  If people buy an X camera and multiple lenses, whatever they saved from their DSLR by having a smaller body isn't going to be as significant in the whole equation.  Put it this way - if they're using the same case, they've gained very little indeed.
Cheers, Rod
 Rod McD's gear list:Rod McD's gear list
Canon PowerShot G1 X Fujifilm X-T1 Voigtlander 90mm F3.5 APO-Lanthar SL II Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R +6 more
TexasBuyer
Regular MemberPosts: 222Gear list
It's all about choices. . .
There have been a few times when I took photos with the telephoto end of my 18-55 zoom and wish that I had something a little longer.  I would be happy with a 55-135 OIS zoom in a faster f-stop, but at least Fuji is giving us a choice with the 55-200mm zoom.
Although I love my Fuji X-E1, it has been admitted frustrating that it is taking so long for the lens roadmap to become reality.  In the end, the market will decide and vote with their wallets.
 TexasBuyer's gear list:TexasBuyer's gear list
Fujifilm X100T Fujifilm X-E1 Fujifilm XF 14mm F2.8 R Fujifilm XF 56mm F1.2 R
bigpigbig
Re: It's all about choices. . .
In reply to TexasBuyer, Apr 22, 2013
Both of the above option would be better, in my opinion. A 135mm 2.8 prime with OIS. Or a 55-135 f4.
As I said, I will get the 55-200 anyway, so I have it along when I have only the small gear. But this combo will not even come close to the performance of a 70-200 on my D800 (very unlike the 35 1.4 and 14 2.8 which give DSLRs a run for their money) Even the 18-55 is a decent substitute in the right situations.
There is always the Leica 135 but no AF makes it less than ideal.
Al Downie
Senior MemberPosts: 1,194Gear list
In reply to Rod McD, Apr 22, 2013
Hi Rod,
For me, the greatest advantage is nothing to do with size or weight (but they're great side-benefits for sure) - it's more to do with the ergonomics of the cameras - a proper shutter speed dial, a proper aperture ring, and all the other knobs and whistles hidden away in menus somewhere - it's the closest thing I've found yet to the experience of using an FM3, my favourite camera ever. If there was such a thing as a digital SLR with only basic, manual controls, I'd have one in in INSTANT, but the manufacturers seem hell bent on competing with each other to squeeze even MORE modes, MORE functions, MORE buttons, MORE stuff that just gets in the way of the process (for me at any rate).
So the size and length of the zoom doesn't really bother me. Having said that, I think I'd definitely prefer a 200mm prime than the zoom...
 Al Downie's gear list:Al Downie's gear list
Fujifilm FinePix X100 Leica M8 Canon EOS 5D Mark III Canon EF 50mm f/1.2L USM Canon EF 135mm f/2.0L USM +3 more
JohnNewman
Regular MemberPosts: 426Gear list
In reply to Al Downie, Apr 22, 2013
Al Downie wrote:
Hi Rod,
Totally agree. My X-E1 body is what I've been waiting for since the advent of digital. I wouldn't mind if it had a "normal" Bayer sensor or even a mirror, so long as it's a reasonable size and has "analogue" controls for shutter speed and compensation. It's a huge plus that it has such great jpegs and excellent high ISO performance.
I take the point though that the 55-200 seems a bit big for the body but you can't alter the laws of physics! I'm on the fence about the new zoom at the moment and will wait for real world reviews from users before deciding. I may stick to MFT for longer zooms b.ut will see.
John
 JohnNewman's gear list:JohnNewman's gear list
Sony Cyber-shot DSC-HX90V Sony Alpha NEX-7 Fujifilm X-E1 Nikon D7100
Allen Chernack
Senior MemberPosts: 1,399Gear list
What you say has merit but, every time I reach in my bag and haul out my Canon 60D with it's 70-300 mm lens I put it back and grab my XE1.  The weight difference even with the new 55-200mm is significant for me. True, the new zoom looks odd when extended but I can live with it. After all, I'm looking through the viewfinder and don't see the way the camera looks anyway.
I do appreciate your taking the time to do the evaluation of the lens system.
tourretired
Travel in RV when not home.
 Allen Chernack's gear list:Allen Chernack's gear list
Sony Cyber-shot DSC-HX30V Fujifilm X-E1 Fujifilm X-T1
montera2
Regular MemberPosts: 339Gear list
"Does anyone else think the 55-200 fully extended looks ridiculous on the XE1?"
Yes, my first impression was "a stallion on steroids". As I've always used if-lenses, if used a zoom. The mechanical construction of the 55-200 may be a bit flimsy.
 montera2's gear list:montera2's gear list
Phase One Capture One Pro
DTwigg
New MemberPosts: 13
In reply to montera2, Apr 22, 2013
Al Downie has stuck the nail upon the flat part for me. I love the simple, solid mechanical controls of the X-E1 and the subsequent handling. I need a longer focal length and the 55-200 is going to provide that. Is it ugly when extended? Who cares. I don't watch myself when I'm taking pictures, I'm busy looking through the VF framing the shot and far too often I see a shot I just can't get close enough to with the 35/1.4. Would I prefer a 135/4 prime? Of course, even though I've promised my wife to give zooms a try (LOL). If Fujinon brings out a longish prime, and I mean one enough longer than the 60mm to be worth while, I'll probably buy it. But I might still hang on to the 55-200 for the extra reach of the 305mm equivalency.
Dave
motobloat
Regular MemberPosts: 497
I would like to see the following lenses from Fuji after they're done with the current roadmap:
  • 85mm f/2.0 or even f/1.4 - should be easy to design, since 85mm is a common focal length and there are a lot of good designs out there.  Would give a ~135mm equivalent angle of view.  Seems like the liklihood of this happening is pretty high, assuming the X-system is popular enough.
  • 300mm f/4 OIS and some teleconverters. - this lens wouldn't be extremely expensive (mabe $1000-2000), but would let the X-system get some real reach for sports and wildlife.
  • 100mm f/2.8 macro - a real 1:1 macro lens.  90mm or 105mm would be fine too.  Unlikely, since there is already the 60mm macro (but it's not 1:1)
  • 200-400mm f/5.6 OIS - this would be an expensive lens (probably $2,000+), but arguably Fuji needs something in the super-telephoto category to really compete, and hopefully with Fuji's lens design skills this would be pretty sharp wide open
Put those on the market, and all my Nikon gear goes on e-bay.
Rod McD
Re: To Al and John - analogue controls
In reply to JohnNewman, Apr 23, 2013
Hi Al and John,
I agree with you completely about the X series controls (despite also still being a DSLR user).  It's highly intuitive and you can see almost everything just by looking at the camera and settings in one glance.  However, that's the difference for me between say the NEX6 and the XE1, not so much the distinction between mirror-less and DSLR.  For me the size difference is very important - I travel and go hiking and cycling, and a DSLR is quite a lump.  The only disappointment I have about the X series is Fuji's decision not to make them environmentally sealed - definitely an omission on premium cameras.
Cheers, Rod
