My Fuji HS50EXR Review
Started Apr 21, 2013 | User reviews
jcmarfilph Veteran Member • Posts: 7,592
19
I have the camera for almost a month now and here are my impressions compared to my previous HS30 and other superzoom cameras. I will make this short and straightforward.
Speed and Performance
Although undocumented, Fuji put a new sensor on the HS50EXR. Sporting a FSI(?)-CMOS EXR II sensor with phase-detect pixel. This new sensor together with a more powerful processor dramatically reduced the shutter lag and shot-to-shot time and vastly improved the AF speed with its hybrid Phase-detect AF or Contrast-detect AF depending on the scene. A stunning 0.05sec AF speed and 0.5sec STS time and start-up time. * Under low-light condition and on the long-end zoom, AF speed will slight decrease but still faster and accurate than HS30 camera. Fuji introduced optical image stabilization now instead of the usual sensor-shift IS from previous HS camera.
Taking 1000mm EFL shot handheld is really achievable even at 4-5 stops below the suggested shutter speed of 1/1000s. HS50 is great for capturing action shots like running dogs, flying birds and running kids even indoor. Now you won't miss any shot, the way you want it, where it happens, when it happens. I gave it great only because a camera with larger sensor and brighter lens is the best for capturing action shot. * - When High-performance mode is enabled and light in is optimum condition.
Ergonomics and Handling
If there is any camera that will give your the true-DSLR feel, HS50 is one of them. The size and weight are perfect for person with average or big hands. Excellent built and design and unmatched manual zoom for quick framing of that critical shot. When it comes to scene requiring quick framing, fast AF and manual zoom will give you more keeper shots.
Image Quality
Not scientifically proven, FSI-CMOS delivers better IQ than BSI-CMOS sensor. As seen on various comparisons, HS50 has a slightly better quality than HS30 especially on low ISO. Coupled with a sharper lens and longer reach, the detail on distant subject that you've always wanted is now at your fingertips. I have vast experience in birding using superzoom for years so I can definitely say that my birding has improved further with the added reach, speed and sharper lens of HS50.
Below is my unscientific ISO ladder to show that HS50 delivers at par quality even on high ISO.
View: original size
View: original size
View: original size
Below are some of the comparisons that I have made against SX40. I've also included the great LSize and MSize comparison showing how good is the HS50 in retaining detail at LSize and how good it is in protecting DR at MSize. I have reduced HS50 to 12MP so as to avoid false assumptions that SX40 is better at 100%. Originals can be found in my gallery. Fuji image starts with SXXXX or DSCXXXX while Canon starts with IMGXXXXX. Click the original link for proper viewing.
SX40 left, HS50 right.
View: original size
Here another comparison against SX40 at the widest FL. At the expense of noise (which can be removed easily during PP) on the HS50, you can clearly see the detail is really there and no painterly effect as seen on some reviews online. CA/PF is also less-pronounced on the HS50. SX40 left, HS50 right.
View: original size
Moving on to the center of the scene. SX40 shows sharper result but again in terms of detail, HS50 is at par in this comparison. SX40 left, HS50 right.
View: original size
And moving on the right side of the scene, HS50 is sharper. SX40 left, HS50 right.
View: original size
Zooming in on the center of course will favor HS50 as it has 160mm EFL advantage over SX40. SX40 left, HS50 right.
View: original size
LSize versus Msize
This has been debated endless times already. One is saying MSize DR400 produces better detail overall than LSize. Which is which? My take on this is, if you want maximum detail/resolution, go for LSize. Simply upsizing the MSize to LSize does not create magic. Detail is not there so don't be fooled with those crappy crafted comparisons. Below is resolution comparison between LSize, MSize and the SX40 at the widest FL.
No more talking, LSize produced the best detail albeit with more noise than MSize and SX40. Sky is a lot nicer too on the Fuji. Love that Fuji colors!. HS50 LSize left, HS50 MSize center, SX40 right.
View: original size
Dynamic Range Comparison
I've made this comparison simple. I took the same scene using MSize DR400 and LSize DR100
MSize DR400 produced nicer sky and protected highlights better than LSize DR100. MSize DR400 left, LSize DR100 right.
View: original size
Note that that comparison is SOOC JPEG so you still definitely recover highlights on the LSize. Of course with careful look at the exposure, you can avoid blown highlights and blocked shadows regardless of DR setting you will use. Shoot in LSize RAW, you'll have highest latitude both on resolution and DR.
Macro Capabilities
HS50 has two modes to shoot in macro or close-up mode. It has improved in Super Macro mode because you can literally stick the lens on the subject and still be able to focus on it. The drawback though is you cannot use on-board flash or any flash unit. On the other hand, HS50 lost its magic in macro mode. If you are familiar with the "150mm <6 inches" trick then you will be surprised that it will no longer work on the HS50. That trick is to get the highest magnification and still be able to use flash and at the same time giving enough distance not to scare away insect or small critter. See my settings below for the optimum result.
Here are sample macro shots...
View: gallery page
View: gallery page
View: gallery page
View: original size
Image Stabilization
I've found out that Continuous IS is the best stabilization mode of the HS50 and this applies to all HS cameras I have handled. Below is the comparison of Continuous, Shooting Only and Off
Continuous (left), Shooting Only(center), IS OFF (right)
View: original size
Conclusion
As I have been telling all the time, I am not one of those reviewers giving personal conclusion and awards on the camera they have reviewed because that will affect the judgement of the viewer so I will leave it to you to judge the camera using the information and results I have posted.
My settings for variety of shots
I normally shoot wildlife so here I am using C-Mode with these settings:
Static/Semi Static critters
C-Mode set to Aperture-Priority (Go to Aperture Priority mode then save to C-Settings)
ISO = Auto 400 (shoot first with this then if the critter stays shoot with lower-ISO)
DR = Auto
EV = -0.33
Aperture = F/2.8 (it will become f/5.6 on the long end automatically and vice-versa)
Image Size = L 4:3 RAW
Image Quality = Fine
Film Simulation = Velvia/Vivid
Color=Mid
Sharpness=Standard
Tone=Standard
File format = RAW+JPEG
Noise Reduction = Low
Intelligent Sharpness = Off
Face Detection = Off
Face Recognition = Off
Image Stabilization Mode = Continuous IS
AF Illuminator = On
EVF/LCD Mode = 60 fps
Quick Start Mode Power Saving - High Performance Mode = On
Continuous Shot Mode at 6 frames/s
Photometry(Metering) = Spot (Note: This is the preferred for shooting critter, for general use consider center-weighted mode).
White Balance = Auto
AF-Mode = Center
Focusing = AF-Single
LCD on Best Framing (RO3 guide)
For Bird-in-flight or other flying critter
Shutter-Priority Mode
Shutter speed = 1/1000s
Focusing = Continuous
For Macro
Aperture or Program Mode
Flash ON for insects and other critters under shade
To achieve Maximum magnification/Shallow DOF set the focal length to 200mm (EFL) and lens at around 12 inches away.
For Low-light
EXR-SN or PAS mode
ISO=Auto ISO1600
Image Size = M 4:3
DR = DR100
Film Simulation = Standard
Noise Reduction=Low
Sharpness=Standard
For General purpose type of shooting like events
Program Mode
ISO=Auto ISO400
Image Size = M 4:3
DR = DR400
Noise Reduction=Low
Sharpness=Standard
Notes:
  • If you want extra resolution shoot in L-Size and set DR to Auto, File-type to RAW and PP it. After careful post-processing, resize it down to 50-75% (depending on the quality of the shot).
  • I am using Silkypix to PP my RAW files but sometimes especially on macro mode, JPEG is more than enough.
You can find more shots in my Flickr gallery: http://www.flickr.com/photos/joms_birding/
-=[ Joms ]=-
 jcmarfilph's gear list:jcmarfilph's gear list
Fujifilm X20 Fujifilm FinePix HS50 EXR +1 more
16 megapixels • 3 screen • 24 – 1000 mm (41.7×)
Announced: Jan 7, 2013
jcmarfilph's score
5.0
Average community score
4.8
bad for good for
Kids / pets
excellent
Action / sports
excellent
Landscapes / scenery
excellent
Portraits
excellent
Low light (without flash)
great
Flash photography (social)
excellent
Studio / still life
excellent
= community average
jcmarfilph OP Veteran Member • Posts: 7,592
Re: My Fuji HS50EXR Review
Apologies for the wacky format due to copy pasting. I could not edit it anymore.
-=[ Joms ]=-
m7svk Forum Member • Posts: 82
Hello Joms,
thank you for honest review, just sold fuji hs30, and canon 600d was sold too, still not decide between new fuji hs50 £399, refurbished fuji x-s1 £340, or new panasonic fz200 £429, but this review put me closer to hs50.. ;), many thanks.
m7svk
m7svk wrote:
Hello Joms,
m7svk
Glad to have helped. X-S1's strength is definitely high ISO while FZ200 is the constant aperture so you can use faster shutterspeed or lower ISO in very low light situation. HS50 kills both in reach and speed and matches X-S1 in handling and ergo.
-=[ Joms ]=-
Hello Joms,
Could please check for me when Focal ratio changing on hs50, would like to know at least up to when is f2.8, and when kick in f5,6 , or if possible check all focal ratios from 24 mm to 1000mm on hs50 as I can't find this anywhere on net, many thanks for help.
m7svk
m7svk wrote:
Hello Joms,
m7svk
Speedy put up a graph of apeture/FL here..
http://www.dpreview.com/files/t/E~1869ffd1933b450896e6531e3deda95d
-=[ Joms ]=-
Many thanks Joms,
exactly what I was looking for, shame is missing x-s1, thank you very much.
m7svk
DS21 Senior Member • Posts: 1,952
Why spot metering on HS50? It means half press and re-compose always, or somehow magically spot metering works as multi on HS50? By using spot you eliminated one big part of review, exposure consistency of the camera, and this is the area where Fuji is weakest lately compared to competitors. Using DR100 makes good exposure metering of the camera especially important. If you have the skill to use the spot all the time, does not mean others will have it, so some explanation of how you achieve this with the HS50 would be a welcome addition to the review, otherwise inexperienced users might struggle mightily with the exposure using spot metering as a default.
 DS21's gear list:DS21's gear list
Fujifilm FinePix S100fs Pentax MX-1 Pentax K-x Pentax K-01 Pentax K-5 IIs +6 more
wymjym Veteran Member • Posts: 5,477
I would imagine that spot is better for critters.....if you miss the exposure on fur/feathers there is usually too much noise or no detail to work with...so basically the critter is most important and the surrounding area takes a back seat.
wj
nikonfujicanonandricoh
MitchyK7 Regular Member • Posts: 131
Nice review Joms, well balanced with the comparisons i think too. It's definitely the case that no mode should be completely ignored, they all have their uses. M/L PSAM JPEG/RAW etc. They are all useful for different reasons, and i'm one of those people who will try and use all modes to see where each shines. I never discount something just because someone else might. Everyone has their own style and workflow, i like to keep an open mind and try many things. So i'm using M DR400 for landscapes and backgrounds, but L DR/ISO100 for zooming into to far off detail and capturing action stuff like BIF or KFS (Kids Full Speed! lol).
Keep it up dude, bewteen your and Kim's contrasting viewpoints i'm picking up a lot of information that Fuji haven't bothered to pass on! LOL
wj
I agree, but in the review the spot metering is a general recommendation, not just for critters. In all posted samples there is 0 Ev applied, I question will the less skilled users be able to pull this off just using spot, especially in high contrast scenes. The reviewer is effectively taking the camera metering out of the equation, replacing it with his skill in using spot, this is not how it will necessarily work for others. And Fuji metering, both avg and multi, is the area where Fuji slipped the most lately, it is strange not to mention it at all, and it can be a big problem for less skilled users who consider the camera based on this review.
That was just my exposure mode for C Mode. For general purpose shooting, center-weighted or average is my recommendation.
-=[ Joms ]=-
DS21 wrote:
wj
Not really. It just happened that I have left the metering to spot but as you can see the exposure on the comparison are the same.
0 EV was used because that was the default EV on SX40 as well.
Again, Spot-metering is for my C mode only. Average or Center-weighted for general use.
-=[ Joms ]=-
KJaay Senior Member • Posts: 5,109
Very nice review!
KJ
 KJaay's gear list:KJaay's gear list
Canon PowerShot S3 IS Fujifilm X-S1 Nikon Coolpix P600 Nikon Coolpix P900 Canon EOS 450D
KJaay wrote:
Very nice review!
KJ
Many thanks KJ.
-=[ Joms ]=-
I appreciate it. Just showing what this cam should be.
-=[ Joms ]=-
Peter71951 Contributing Member • Posts: 553
Is there an intelligent sharpness setting on the HS50? I must have overlooked that.
Peter
Peter
I have forgotten to remove that. I did not use it anyway with my HS30 settings.
-=[ Joms ]=-
Me Tarzan
Me Tarzan Senior Member • Posts: 1,392
Good on hands review, Joms. Appreciate the share.
Frank
Frank
Appreciate it Frank. Thanks for looking.
-=[ Joms ]=-
