Sigma 50mm f1.4 @ f1.4 -> WOW
Started Apr 21, 2013 | Discussions
Hardy Steiner
Senior MemberPosts: 2,442
Apr 21, 2013
It's amazing how sharp the Sigma 50mm f1.4 is at f1.4 ... once you manage to nail the focus that is ... which for me is not that easy. As with the 85mm f1.4 you can end up with quite a lot of green fringing at fast apertures (which, yes, you can remove in SPP). In any case, a very fine lens, the bokeh is very smooth and color rendition is great.
Focus in the pic below was on the head of the statue/sculpture:
Best regards,
Hardy
Join the Sigma DP Macro Group on:
http://www.flickr.com/groups/sigma_dp_macro/
My pictures on:
On Flickr: http://www.flickr.com/photos/diddy
jrdigitalart
Veteran MemberPosts: 3,285
Re: Sigma 50mm f1.4 @ f1.4 -> WOW
In reply to Hardy Steiner, Apr 21, 2013
Nice bokeh alright, Hardy.
Sincere regards, Jim Roelofs
Cherish your privacy? Avoid (sp)iPhones.
You are welcome to visit my portfolio here:
http://www.pbase.com/jrdigitalart
Hardy Steiner
One more for the bokeh @f5.6
Best regards,
Hardy
My pictures on:
Johan Borg
Senior MemberPosts: 2,276
I believe the focus shifts a bit with the aperture, so even a calibrated lens can benefit from a bit of manual fine-tuning. The lens is otherwise well described with a WOW, and on my 1.7 crop SD15 even the corners are sharp wide open.
Hardy Steiner
In reply to Johan Borg, Apr 21, 2013
I quite often use manual focus. My main tasks (which I should really do quite soon) is that I have to get the viewfinder dioptre adjustment setting right. Currently I can focus on close by objects fairly well, but if they are further away, my success rate drops significantly.
Best regards,
Hardy
My pictures on:
Tom Schum
Veteran MemberPosts: 4,647Gear list
This was the first lens I bought from Sigma, for my Canon 30D.  It has worked very well.  I did a fairly large project with it over the last couple years photographing paintings for an artist.
Here is a link.  Beware lots of photos here, and resolution is limited for protection of the images: http://www.mike-yengo.com/
I made one of these into a 30x40 wall mount print (10508, first shot in the first gallery, thru Meridian Pro on the web) and it turned out well.  Lots of bayer artifacts in the fine details but no issues at all with sharpness.
I wish I had one for my SD1, but I have the 85mm F1.4 instead, and certainly no complaints about this lens either!
Tom Schum
Sigma DP2 Sigma DP3 Merrill Ricoh WG-4 GPS Fujifilm X30 Sigma dp0 Quattro +8 more
