Displaying prints so they can be changed frequently
Started Apr 20, 2013 | Discussions
Birddogman
Birddogman Senior Member • Posts: 1,908
I need some suggestions.  I want to create a wall of maybe 10 framed pics in the hall that leads to my home office/library.  Since my printer will only produce 8.5x11" prints, that's the size I am going to use.
I'd like to have some nice looking frames with matting, but I want to be able to easily replace the pics with new ones.  Also, I don't want to spend a fortune.
Any suggestions?  Thanks in advance for your help.
 Birddogman's gear list:Birddogman's gear list
Sony RX1R II Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +3 more
jrkliny
jrkliny Veteran Member • Posts: 3,518
Re: Displaying prints so they can be changed frequently
I shop AC Moore or Michaels.  Both have frequent sales with up to 50% off of the price for frames.  I was able to buy 11x14 inch metal frames for between $3 and $5 each.  I did not use mats.  Instead I just attached the prints onto inexpensive drawing paper.  If you want mats the price will still be reasonable but will be at least twice as much.  When I was working and had an office, I would display about 20 framed prints.  Every couple of weeks I would change out a few of the pictures.  At home I displayed my prints without frames.  I used putty to attach the prints to the kitchen wall.  I changed them out frequently.  I have also considered a very quick display method.  You paint your wall with a special metal paint, then top coat with regular latex.  Prints are help up with rare earth magnets in the shape of push pins.  Of course this will only hold prints.  The magnets would not be able to hold matted prints.
Jim, AKA camperjim, formerly from liny, Long Island New York
 jrkliny's gear list:jrkliny's gear list
Canon EOS 600D Canon EOS Rebel T6s Canon EF 35mm f/2.0 Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 15-85mm f/3.5-5.6 IS USM +6 more
Charles2 Veteran Member • Posts: 3,514
I use sign holders sitting on the shelves of a shallow-depth bookshelf. There are acrylic holders and, for nothing in front of the print, simple metal ones something like tiny easel racks.
TonyGamble Senior Member • Posts: 2,562
You might like to try the new (still beta) version of Picture Window Pro.
Version 8 contains a simulated matte and frame routine. Even if you think the frames are not convincing enough you may find the double matte element worth using. It certainly fooled most people who looked at prints, treated that way, at a recent exhibition.
Tony
Version 8 contains a simulated matte and frame routine. ...
I've used PWP for years - great program. I have the beta (actually v. 7).
The only thing about printing a matte and frame is that I would want to buy larger sheets of paper!
Charles.
Larger paper. Agreed.
On the other hand the money you save in not having to make/buy mattes will more than compensate.
Yes. It is v 7. My mistake.
Tony
E Dinkla Contributing Member • Posts: 634
Snap frames used in the sign industry. I have a larger one permanently fixed to the wall so I do not have to take it from the wall either. Always straight too. Print with or without a simulated matte (Qimage can do that too), mount on a 600 grams mounting board, cut the total on the Qimage cut marks for the size, Spray with a protective coating if it will hang longer. Put it in the frame glassless so without the ugly PVC sheet that usually comes with the frame. Nothing of the image lost in glass reflections and over short display periods fading will not be an issue.
Just one address picked from the web, there must be good looking ones too:
http://www.sign-holders.co.uk/Snap-frames/c-1-3/
Met vriendelijke groet, Ernst
500+ inkjet paper white spectral plots: OBA content etc.
http://www.pigment-print.com/spectralplots/spectrumviz_1.htm
Philnw2 Senior Member • Posts: 1,657
One can buy plastic frames, one brand is format, another is Lawrence at BH, Adorama, that have a black plastic tray that you put the picture in it, and then a thin layer of glass pops in on top of it, plastic is sized to hold the glass in place.  No mat.  very quick to replace pictures and it keeps finger prints off them.  some plastic frames require a little trimming on standard sizes.
I've used these cheap frames for 3 years in a theater lobby that i help decorate.  you can get them in 8x10, 8x12, 11x14, 11xq7, etc.
Phil B
Nex 5n, Pentax K5, Epson R3000
 Philnw2's gear list:Philnw2's gear list
Sony Alpha NEX-6 Pentax K-3 Sony Alpha 7R II Sony FE 55mm F1.8 Sony FE 28mm F2
