Please help me to verify - Left AF Problem or lack there of
Started Apr 20, 2013 | Discussions
Akshaj Forum Member • Posts: 56
Hi,
I got my second D800 today. I did some preliminary left AF test using Nikon 28mm F1.8 (AF-S) lens. I am not sure whether I can reach a definite conclusion. Could anyone please help me to verify.
First image is the taken with Center Focus Point - 100% crop (no AF fine tune, F1.8). The subject is at 10 feet.
Second image is taken with Left most focus point - 100% crop (no AF fine tune, F1.8). Subject is 10 feet away
Left AF Focus point - 100% Crop F1.8
Third image is the also shot using the Left AF Focus Point (IN LIVE VIEW).
Left AF Focus Point - Live View (100% Crop, 28mm F1.8)
Based on this test, I am not sure whether I have a problem with left AF problem.
I have not done any AF micro adjustment to make sure that the PDAF is spot on.
Your comments and suggestions are greatly appreciated.
-Akshaj
Nikon D800
TOF guy MOD Forum Pro • Posts: 12,722
lack there of
Don't think you have it. Enjoy the camera !
Thierry - posted as regular forum member
 TOF guy's gear list:TOF guy's gear list
Nikon D810 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF-S Nikkor 24-70mm f/2.8G ED Sigma 150mm F2.8 EX DG OS Macro HSM +6 more
Chad Gladstone Senior Member • Posts: 2,608
Re: Please help me to verify - Left AF Problem or lack there of
Looks good.  If 1.8 was not a little sharper in the center, I would think the lens is underperforming.
Chad Gladstone
 Chad Gladstone's gear list:Chad Gladstone's gear list
Nikon 1 V1 Nikon D800E Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 50mm f/1.4G Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +7 more
Alchin Senior Member • Posts: 1,224
This looks like a good one.  What is the serial #    (B&H ? )
Did you have a problem with your previous one you posted 306xxxx
AC///
Akshaj OP Forum Member • Posts: 56
AC///
Yes, it is also from B&H. The serial number is 3065xxx. The previous one was 3062xxx. It is used by my wife.
-Akshaj
Longview Forum Member • Posts: 83
If you can't find it and have to ask the world to verify then I think you are looking too hard.
My eye seems to be tired now. Usually I am able to do these kinds of things, but with two D800 came in the last two weeks, I thought it is better to check with others and get some clarification.
-Akshaj
elliotn Senior Member • Posts: 1,113
Thanks for posting your results. I've had 3 D800s that can't focus the 28/1.8G with the left AF points. I was starting to think the D800 has a basic design flaw, but your results show that good focus is possible.
You are welcome. My D800 can focus with left AF although I am not happy with my copy of 28mm  F1.8
I am thinking of getting the new 18-35mm AF-S G lens.
-Akshaj
Joe Porto Senior Member • Posts: 1,063
Can anyone tell me if my arm hurts?
I'm not sure if I have a problem with pain in my arm. I was hoping someone could tell me if I have a problem or not.
But seriously, no, you do not have a problem. But isn't the definition of a problem: A matter or situation regarded as unwelcome or harmful and needing to be dealt with and overcome.
Shouldn't one be able to determine this matter or situation on there own? I'd imagine if they could not, then there is nothing to be dealt with or overcome, and therefore there would be no problem.
Just saying.
 Joe Porto's gear list:Joe Porto's gear list
Canon PowerShot G15 Nikon D7000 Nikon D750 Nikon AF-S DX Nikkor 10-24mm f/3-5-4.5G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +5 more
AC///
-Akshaj
Thanks and good luck.
Re: Can anyone tell me if my arm hurts?
You may be right but I appreciate the OP having the courage to post his result.  The left auto focus issue is a reality and can't be pushed under the rug.  Your beef is with Nikon for not coming forward to clear the air on this issue.
AC///
AC///
I wasn't trying to express any "beef". I was just pointing out that it was pretty obvious the OP does not have an issue, and was being tongue and cheek about it.
But do I have a "beef" with Nikon's QC? Yes I do, as I was one who DID have the LAF issue, and had to send my camera to Melville on my dime to get it repaired.
Yes, but it's perfectly okay IMO to ask others for confirmation. Isn't this something the forum is also here for ?
It was a joke...hence the smiley...why is everyone so serious around here?
Leonard Shepherd
Leonard Shepherd Forum Pro • Posts: 10,446
There seems a very slight loss of quality on image 2.
Why use a geometric pattern as a target when Nikon warn you they may cause poor results?
Geometric patterns can be 100% good - if you align the AF point perfect.
In shot 1 the red rectangle indicates alignment is a little bit off centre, and in shot 2 somewhat more off centre.
Leonard Shepherd
Many problems turn out to be a lack of intimate knowledge of complex modern camera equipment.
Nikon Coolpix P7700 Nikon D800 Nikon D7100 Nikon D810 Nikon D750 +24 more
Oops missed that sorry.
This is not the kind of geometric pattern which creates misfocus.
You're making that rule up.
And ?
Leonard Shepherd
Yes, I agree that there seems to be a very slight loss of quality in extreme left focus point (PDAF and LiveView). I did a quick test in outdoor and following are the images
1) Left AF Focus Point (28mm F1.8 Aperture Priority, No AF-Fine tune) - 100% Crop near the focal point
100% Crop - Leftmost Focal Point, 28mm F1.8
2) Left AF Point LIVEVIEW - 100% Crop neat the focal point (28mm F1.8 Aperture Priority, No AF-Fine tune)
Based on what I have seen in internet regarding the Left AF problem, this is not that case.
I have tested this earlier this with 50mm F1.8 lens (at aperture F2.0) and it seems fine there also. However a lot of people commented in internet that Left AF problem is mostly visible on wide angle lenses (anything greater than 50mm lenses, it is not visible).
-Akshaj
CraigBennett
CraigBennett Contributing Member • Posts: 699
It looks fine to me.  Looks much better than your last one, it's a keeper.
 CraigBennett's gear list:CraigBennett's gear list
Nikon D90 Nikon D800E Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 24-85mm F3.5-4.5G ED VR +5 more
