Lenses for a D4
Started Apr 19, 2013 | Discussions
net_walker
Contributing MemberPosts: 805Gear list
Lenses for a D4
Apr 19, 2013
Ok, when I get back home to Oz at the end of August I will be buying myself a D4. Do I deserve it?
Yes...
Am I good enough for it?
No...
Will I get it none the less?
Yes...
So, I currently own the 80-200 2.8 and 50 1.4g as well as the 28-300 for my travel lens to Europe in a few months. Sigma 10-20 as I use a D7000 atm.
I have really like shooting the few Forces Entertainment concerts so the D4 low noise use is what I want. But generally will be doing a lot of different things. Dropped my 105 macro just before x-mas and killed it off
Suggestions on lens recommendations appreciated. I read that the 70-200 F4 is not a bad lens  but not sure if it will hold up to night shooting handheld, but then again the D4 is the night shooting KING.
Enlighten me please guys and gals.
Cheers...
 net_walker's gear list:net_walker's gear list
Nikon D800 Nikon D4S Nikon D750 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +6 more
Nikon D4 Nikon D7000
coudet
Veteran MemberPosts: 3,857
Re: Lenses for a D4
In reply to net_walker, Apr 20, 2013
Yes...
That's the attitude!
Why not try that 80-200/2.8 first, since you already own it?
net_walker
Re: Lenses for a D4
In reply to coudet, Apr 20, 2013
coudet wrote:
Yes...
True I do own it Was looking at options is all.
Also noting that it does not support Nikon TE Converters.
Cheers...
87350iroc
Junior MemberPosts: 43Gear list
Re: Lenses for a D4
net_walker wrote:
coudet wrote:
Yes...
Cheers...
Yeah, whats wrong with the 80-200, that is a great lens.  I certainly don't see the f4 as a upgrade for your type of shooting.
You can use it with Kenko tele-converters with pretty good success.  Although I would not put a tele-converter on any lens for concert shooting.
 87350iroc's gear list:87350iroc's gear list
Nikon D600 Tokina AT-X Pro 100mm f/2.8 Macro Tamron AF 28-75mm F/2.8 XR Di LD Aspherical (IF) Nikon AF-S Nikkor 28-300mm f/3.5-5.6G ED VR Nikon AF-Nikkor 80-200mm f/2.8D ED +5 more
Minnesota_Steve
Contributing MemberPosts: 512Gear list
Re: Lenses for a D4
At what aperture is the 80-200 sharp?  My 70-200 VR I requires f/3.2, but much better than f/4 lens.  The 70-200 f/4 is supposed to be sharp wide open.  It also has a nice weight advantage.  But if your 80-200 is great at 2.8 or 3.2 I would stick with that.  On my D4, the 70-200 VRI lives at F/3.2 and I often shoot at ISO 8000+ for night events!  The extra 2/3 stop really helps.
My event kit is the D4 + 14-24, 50 f1.4 and 70-200 f2.8, 1.4 TC and a D7100 for backup.
Steve
 Minnesota_Steve's gear list:Minnesota_Steve's gear list
Nikon D300 Nikon D7100 Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +5 more
Gittix
Forum MemberPosts: 60Gear list
Re: Lenses for a D4
In reply to net_walker, Apr 21, 2013
Did you consider a used D3 or D3s? You could pick up one of these and use the extra $2500.00 or so to put towards another lens or upgrade the 80-200 to 70-200 VRII. You're not gaining a lot of low light capability with the D4 over the D3s and you could spend the money on some top notch fast glass instead. Just a thought.
 Gittix's gear list:Gittix's gear list
Nikon D3S Nikon D7000 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF +5 more
net_walker
Re: Lenses for a D4
In reply to 87350iroc, Apr 21, 2013
87350iroc wrote:
net_walker wrote:
coudet wrote:
Yes...
Cheers...
Thanks, did not know Kenko worked.
net_walker
Re: Lenses for a D4
In reply to Gittix, Apr 21, 2013
Cheers...not really thought about that path tbh.
vandv
Regular MemberPosts: 157
Re: Lenses for a D4
In reply to net_walker, Apr 22, 2013
Your 80-200/2.8 is a decent lens.  I would drop the 50/1.4 and get a 35 or 85/1.4.  The 28-300 probably should go too.
I am saying this in the context of you getting a D4.   The D4 you are paying a big price (not just money, but megapixels and size) for low-light and high speed shooting.  The 70-200/F4 would not be the right lens for it either.
I have a D4.  Put the 85/1.4g on it and it is amazing.  I also have a D800e which is the perfect size for the 85/1.4g or a 28-300
Anthony Nadia
New MemberPosts: 9
Re: Lenses for a D4
You will LOVE the D4!!!  Brilliant choice!
You can't put just any lens on that awesome body.  If you're shooting a concert, wouldn't you want the faster focusing 70-200 2.8?  Or how about the latest 80-400?  The AF on this new version is speedy!
JeffNYC
Junior MemberPosts: 26Gear list
Re: Lenses for a D4
Yes...
No...
Yes...
Cheers...
I've been using the new 70-200mm f/4G VRIII on a D700.
I don't think you'll have any problems with concerts or low light shooting (evening)
The new VR plus the D4 ISO levels will be enough.
Jeff
 JeffNYC's gear list:JeffNYC's gear list
Ricoh GR Nikon D300 Nikon D700 Leica M9 Olympus E-M1 +10 more
RudivanS
Veteran MemberPosts: 4,428Gear list
Re: Lenses for a D4
In reply to net_walker, Apr 23, 2013
Yes...
No...
Yes...
Cheers...
Ok, I found that the 70-200 f2.8 version 2 a significant step up in sharpness, speed and rendition etc. from the 80-200 - It's a trues pro lens, but at a cost though. Can ya handle it
Rudi - freelancer
'15 years in bladerunner Tokyo - back in sunny Sydney now'
 RudivanS's gear list:RudivanS's gear list
Nikon D4 Nikon D800E Canon Pixma Pro-10
richard cohen
Senior MemberPosts: 1,031Gear list
this is my lens lineup...
Acquired over several years...along with my d4...
14-24 2.8
24-70 2.8
70-200vr1
28-300vr
500mm vr
The 24-70 sits on the camera most of the time. The 14-24 is an amazing lens for outdoors, landscapes, etc. I don't use the 70-200 much but it is a great lens except in the corners. The 28-300vr is a compromise lens that I only use on occasions where I can have only one lens and need the reach (ie, hikes, mtn bike rides, etc). The 500 is a killer wildlife lens that can be hand held. I had a 105 2.8 micro but found that I don't like taking macro shots so I sold it.
 richard cohen's gear list:richard cohen's gear list
Nikon D4 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 500mm f/4G ED VR Nikon AF Fisheye-Nikkor 16mm f/2.8D +6 more
net_walker
Re: Lenses for a D4
In reply to net_walker, May 26, 2013
Tanks again guys. I have bought the D800 which I find a big step up but off to EU in a little over a month (still not home in Oz yet).
Have not ruled out the D4 yet tho
Looking at the Tamron 24-70, 70-200 and the Nikon 14-24. Possibly the Sigma 150 macro, Nikon 85 1.8 and Sigma 35 as well.
This will be what should be the only lenses that I would possibly need as birding is not something I would be interested in.
Oh and maybe some lensbabies for some fun times.
Cheers...
larrywilson
Veteran MemberPosts: 4,453Gear list
Re: Lenses for a D4
If you have the money, buy the d4, best camera for high iso shooting and the post processing is much easier and quicker than the d800.
I have the d4 and also the 70-200 f4.0 lens, excellant combination for any type of shooting between 70 and 200mm.  This lens is an excellant lens which takes all the Nikon converters with the d4.
Larry
 larrywilson's gear list:larrywilson's gear list
Nikon D810 Nikon D7200 Nikon AF-S Nikkor 500mm f/4G ED VR Tokina AT-X 16-28mm f/2.8 Pro FX Carl Zeiss Makro-Planar T* 2/100 +6 more
Steven Sax
Regular MemberPosts: 447Gear list
Re: Lenses for a D4
In reply to larrywilson, May 26, 2013
I have gone back and forth in shooting band photography at night with my D4. Using the golden trio 14-24, 24-70, 70-200, I found I didn't use the 24-70 much, and even with iso at 6400-12800 I often wanted faster than 2.8 to keep the shutter speed over 1/125th. Soooo, I used 35 1.4 sigma and nikon 85 1.4 and 135dc 2.0 and wished I had the zooms! Still can't decide. Either way I've been happy. Once rented a 200mm 2.0 and got awesome images and sore forearms...If I had to make a final choice, it would be: 14-24 and 85 1.4.
Steve
 Steven Sax's gear list:Steven Sax's gear list
Nikon D90 Nikon D300S Nikon D4 Nikon D600 Nikon AF-S Nikkor 14-24mm f/2.8G ED +8 more
