problem with new Sirui N2204 tripod..... (experience with sirui anyone??)
Started Apr 19, 2013 | Discussions
twan Senior Member • Posts: 2,292
Last week I've recieved a new Sirui N-2204 tripod with a k20X head.
It looks great out of the box, but the center column is stuck and I can't get it down. It looks like to me, that the mechanisme which should release the column (a big screw) does not work correctly.
I've talked with the supplier and offcourse they offered to look at it. So far for service I don't expect a problem.
But now I have some doubts about the stuff. Sirui offers 6 years of warranty. Fine too, but if a tripod is allready not working as expected out of the box.....
Should I have it replaced and is this a one time error or is the quality less dan I expected and should I look for an other brand?
 twan's gear list:twan's gear list
Fujifilm X-T1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +1 more
Sony Cyber-shot DSC-N2
Yezariael Contributing Member • Posts: 574
Re: problem with new Sirui N2204 tripod..... (experience with sirui anyone??)
I use the N-2204 since about 1 year without any problems. Mine is of very high quality, I like it very much! I would suggest to get a new one and you will be fine.
My new Panasonic TV was broken after 2 days, I got a replacement and now it is working like a charm since about 2 years. Every device can be faulty, that's usually not a problem per se in this category.
 Yezariael's gear list:Yezariael's gear list
Sony SLT-A77 Sony Alpha NEX-6 Sony DT 16-80mm F3.5-4.5 ZA Carl Zeiss Vario-Sonnar T* Sony DT 18-250mm F3.5-6.3 Sony 35mm F1.4 G +7 more
twan OP Senior Member • Posts: 2,292
Yeah you are right. I think then I will check it out this weekend first (I haven't made 1 single picture with it) and replace it next week.
afoton
afoton Senior Member • Posts: 1,086
I have used a T-1204X for almost a year, no problem. The twist locks even worked after a night in -20°C, that is not the case with all twist locks tripods.
But I also have a G20 ball head that is just junk. If I unlock the pano base just so much that I can can do pano, it runs all but smooth, like some surface inside is very uneven. The tension control is also very inaccurate and loose. I also have a Markins head so it is perhaps an unfair comparison. The Markins Q3T is the same size and far better in all areas execpt the security pin in the quick release clamp.
I returned it today
because I don't have time to go to the shop and look for a replacement within reasonable time.
It's a shame but I can't returned it in a few weekend. Now I'm going to look for an other one.
Maybe i check out a gitzo 2542T or 2541. I don't mind paying more if the quality is higher. I know how the sirui looks like so I can compare it.
Re: I returned it today
strange behavior in my eyes...
