Fuji 55-200: MTF Chart and Samples
Started Apr 18, 2013 | Discussions
Al Valentino Senior Member • Posts: 4,660
Below is the MTF chart of the Fuji 55-200mm lens. The chart looks pretty good but the samples on the fuji site  are nothing special - but then again they never are. One of the cats looks like the same one from my XE1 brochure for the 35mm, and the other is similar to a cat on the website for images of the 18-55. What's up the Fuji and cats!!!
http://www.fujifilm.com/products/digital_cameras/x/fujinon_lens_xf55_200mmf35_48_r_lm_ois/
 Al Valentino's gear list:Al Valentino's gear list
Fujifilm X-E1 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Rokinon 8mm f/2.8 UMC Aspherical Fisheye +6 more
Fujifilm X-E1
Tom Schum
Tom Schum Veteran Member • Posts: 5,180
Re: Fuji 55-200: MTF Chart and Samples
I guess Fuji has found many users buying Fuji cameras specifically to take pictures of their cats.  It's a gold mine in my case...I'm always looking for an excuse to post my cat photos.
Tom Schum
Sigma DP2 Sigma DP3 Merrill Ricoh WG-4 GPS Fujifilm X30 Sigma dp0 Quattro +8 more
Al Valentino OP Senior Member • Posts: 4,660
Tom Schum
I'm a dog man myself, mans best friend, loyal.... Cats are difficult And go their own way. That said, your cat pictures look better than the Fuji cats.
David McGaughey Senior Member • Posts: 2,246
Better at telephoto than wide?
If true, that's good. This lens should be far better than the Sony Nex 55-210. Though that's a low bar to clear.
Do we have any idea what aperture the MTF were calculate at?
Re: Better at telephoto than wide?
MTF is usually for the lens wide open.
baobob
baobob Veteran Member • Posts: 7,222
and that could explain better MTF chart at 4.8 than 3.5 ??
Sony RX100 Olympus Tough TG-4 Fujifilm X-T1 Nikon D7200 Fujifilm X-T10 +12 more
baobob
the shot with the boat is really pardoxical....
shooting in haze and condition to create flare and complete lack of contrast is really conter productive to test a lens!!!!!!!!!!!!!!!!!!!!!
baobob
your sandals are much more photogenic If  I may
4.8 is the lens at the long end, 3.5 is at the wide, 55mm end. Many telezooms go soft at the longest focal length. Even the fuji 18-55 is softer at 55 than at 18.
the shot of the highway is interesting, NO cars along that compressed but relatively long road. That certainly does not happen where I live in New Jersey!
1drey
1drey Senior Member • Posts: 1,408
Wow! Fuji cat has big balls! He must be dangerous when not sleeping.
Seriously - great graphs and nice samples. Make me want this lens even stronger.
 1drey's gear list:1drey's gear list
Fujifilm X10 Fujifilm X100S Canon EOS 5D Mark II Fujifilm X-E1 Sony Alpha 7R +7 more
baobob
but precisely it seems it goes the other way round ??
baobob
but anyway the charts seem excellent
sandwich during summer holidays contemplating in the living room this beautiful lens ...
A fantastic perspective...
As much as I hate to use cats as an example, the cat at 55mm looks better than at 175mm. But that is not fair since the 55mm cat has the lens stopped down much more than at 175. A better test would show more test shots wide open. But i personally do not judge the lens by those shots. But I do judge a lens by the sharpest result since that result represents the lens more so than technique.
Anyway, i will wait for reviews. The shots at fuji  from the other day of those horse are incredibly sharp but also look like they were worked and not SOOC.
bestbyte Regular Member • Posts: 155
Moscow VR blog - http://1drey.wordpress.com
Wow!! and how did you get all your attention drawn to the BALLS? .... He must have fathered loads of kittens in the neighbourhood considering the size of his balls!!
To put this in perspective, below is a the MTF charts for the Fuji 18-55. My take is that if you liked the 18-55 then you will love the 55-200 (above)
MTF for Fuji 18-55 zoom
Can't really compare two lenses like that
We have no idea if the testing methodology changes.
I'm mostly excited that it appears to be optimized to be sharp at the telephoto end, since so many telephotos are the opposite. That's a wise move since that's where most people will use the lens. Perhaps this is a (small) reason why this lens is so heavy.
baobob
Yes!
It is well known that it's easier to design a tele zoom than a trans standard zoom
My Canon 70-200mm f 4 L IS is just stellar all apertures all focal lengths incredible !!
I guess the Fuji will be on par...
baobob
Re: Can't really compare two lenses like that
My Canon 70-200mm f4 L IS is rather light
But it's an internal zoom which means it's long (200mm)
The Fuji uses extension tubes and to get some rigidity it finally gets rather heavy that's the price to pay for optical+mechanical quality and reliability
Joachim Gerstl
Joachim Gerstl Veteran Member • Posts: 6,496
New zoom lenses are optimized for their most used setting. My 24-70 Canon is best at 24. My Canon 70-200 is best at 200.
I'm glad that a tele zoom is best at it's tele setting and a wide angle zoom is best at it's widest setting.
 Joachim Gerstl's gear list:Joachim Gerstl's gear list
Ricoh GR Canon PowerShot G7 X Sony Alpha 7R Fujifilm X-T1 Sony a6000 +13 more
