Anyone know of a trusty lens cap holder?
Started Apr 18, 2013 | Questions
robertorinehart Contributing Member • Posts: 551
I keep misplacing my lens cap and end up finding it somewhere ridiculous. One time in the damn fridge. I was wondering if there's a strap out there that has a convenient lens cap holder. Hopefully on the cheap.
Paul Farace
Paul Farace Contributing Member • Posts: 791
Yes, don't use one! Or keep it in the bag...
I keep multicoated clear filters on my lenses to keep them safe. My caps always end up in the bottom of the bag, in a shirt pocket, etc. using a leash is soooo amature... like permanently using over-hand focusing or a tapestry wide strap.
Holding a camera, any camera, reduces my blood pressure, calms my nerves, and gives me a sense of opportunity!
 Paul Farace's gear list:Paul Farace's gear list
Fujifilm FinePix Real 3D W3 Fujifilm X100S Canon EOS 5D Mark II Canon EOS 50D Fujifilm X-Pro1 +3 more
Jim Parsons
Jim Parsons Contributing Member • Posts: 754
Re: Anyone know of a trusty lens cap holder?
I keep them in my left front pants pocket. Cap off the lens- in the pocket. Out of the pocket-on the lens.  Each.  And. Every. Time.  Haven't lost one yet. Errr... haven't misplaced one yet.
Jim Parsons
robertorinehart OP Contributing Member • Posts: 551
Oh okay I guess I'll have come up with a great mnemonic phrase, so I can remember where I place it all the time. Or get the filters. But thanks guys.
Osvaldo Cristo
Osvaldo Cristo Veteran Member • Posts: 4,079
Your troussers´ left pocket
Your troussers´ left pocket, at last for me it works with my own pocket...
O.Cristo - An Amateur Photographer
Opinions of men are almost as various as their faces - so many men so many minds. B. Franklin
 Osvaldo Cristo's gear list:Osvaldo Cristo's gear list
Olympus Stylus 1030 SW Nikon D200 Nikon D300S Nikon D810 Nikon AF DX Fisheye-Nikkor 10.5mm f/2.8G ED +32 more
Peter A. Stavrakoglou Veteran Member • Posts: 7,752
Re: Your troussers´ left pocket
I'm left-handed, maybe that's why I keep mine in the front right pocket.  Or is it because I keep my mobile phone in the left pocket?
My humble photo gallery: http://www.pete-the-greek.com
 Peter A. Stavrakoglou's gear list:Peter A. Stavrakoglou's gear list
Fujifilm X-S1 Panasonic Lumix DMC-FZ200 Sigma SD15 Canon EOS 7D Sigma SD1 Merrill +16 more
Sailor Blue
Sailor Blue Veteran Member • Posts: 9,183
Just remember that any filter will slightly decrease the sharpness of your images. The decrease in sharpness is small for a good quality clean filter, but it is there.  I don't recommend a filter except:
If light strikes the lens directly a filter will dramatically increase lens flare.  In fact, I add a clear "protective" filter if I want lens flare in an image.
A filter will protect the front element of your lens if you are working in a dusty environment.  If you are shooting at the beach or in a desert then a protective filter is a good idea.
Under normal shooting conditions using the lens hood is the best way to protect your lens, not a filter.  I keep my lens hood on indoors and out since I know it not only helps reduce lens flare it just might protect my lens from a hard knock or even if it is dropped.  I would much rather have a lens hood knocked off or bent than have a broken lens.
Living and loving it in Bangkok, Thailand. Canon 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Tamron SP AF 90mm F/2.8 Di Macro +10 more
jjacoberger New Member • Posts: 18
I got a Cap Gorilla.  It attaches to the strap and hold any cap size up to 105mm very securely.
http://www.amazon.com/Cap-Gorilla-Camera-Lens-Holder/dp/B009UW7IVS
-John
valkerie Regular Member • Posts: 313
Jim Parsons
same here . . when the cap comes off , it goes into my left front pocket .. the one time I couldn't find the cap it drove me nuts .. then I stopped to think , NOW I then went to the washing machine and stopped it to check the left front pocket of all the pants in the washer , and there it was ..................
 valkerie's gear list:valkerie's gear list
Canon EOS Rebel SL1 Canon EOS 70D Canon EOS 80D Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF-S 17-55mm f/2.8 IS USM +7 more
scorrpio
scorrpio Veteran Member • Posts: 3,388
Sensei CapKeeper  leash $3 from B&H.   Elastic band goes on the lens barrel, adhesive disk goes on the cap.    All my caps are center-pinch.   All lenses are used with hoods.   Each lens has its own cap leash.
I also take some adhesive-backed velcro.   The 'prickly' part goes on the bottom portion of the hood.   The fuzzy part goes on the lens cap.   If I need to bring camera into action rapidly, I poke at the cap with my left thumb as I lift the camera, and just let the cap drop on its leash.   Then, whenever convenient, I stick the cap to the hood with velcro.   With cap always right next to the lens front, it goes straight back on when I don't expect to shoot for a while.
Don't care if this looks 'amateur'.  It's blasted convenient.
