x100s and x100 have same focus speed most of the time
Started Apr 18, 2013 | Discussions
polarizer Contributing Member • Posts: 845
you will get the instant phase detection focus 20% of the time in excellent light and only 10% in moderate ight and 0% in low light
so most of the time it will be the same as x100 - therefore not worth the upgrade
 polarizer's gear list:polarizer's gear list
Nikon Coolpix A Sony Cyber-shot DSC-RX10 Fujifilm X-Pro2 Fujifilm XF 14mm F2.8 R Fujifilm XF 56mm F1.2 R +1 more
Fujifilm FinePix X100 Fujifilm X100S
polarizer OP Contributing Member • Posts: 845
Re: x100s and x100 have same focus speed most of the time
if anyone knows how to get these percentages up please let me know what i'm doing wrong
i have now set the focus box back to middle size and power management is on
BTW, its FW1.01
JCP_76 Regular Member • Posts: 112
Well, thanks for clearing that up.
I'm going to go and immediately throw mine in the bin.
haha - no need to get defensive - its not worth it to me but you might like the other stuff and it may well be worth $ for you
are you seeing same focus behaviour?
chris80 New Member • Posts: 19
BTW, its FW1.01
AFAIR you have to switch Power Save to Off for full AF performance.
My experience luckily is different from yours - AF under good light conditions is consistently much better than before.
tommoore_mis Forum Member • Posts: 63
From what I have read, those with the original firmware 1.0 claimed faster focus speeds. Those on 1.01 don't seem to see the faster focus speeds. I have the x100s, but never had the 100, and mine came with 1.01, so I can't add any observations to the discussion. If it is firmware, hopefully, we will see that improved upon in the future.
 tommoore_mis's gear list:tommoore_mis's gear list
Sony Alpha 7R II Sony FE 55mm F1.8 Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS +1 more
BTW, its FW1.01
thanks I have that switched off
what FW are you running?
i think FUji could make this right in the fullness of time with successive FW upgrades and thus make the upgrade worthwhile in the long term but it will require patience (similar to all their other product introductions)
sgoldswo
sgoldswo Senior Member • Posts: 5,590
BTW, its FW1.01
+1 - my AF is appreciably faster except in low light when it is about the same.
Note that in addition to turning power save to off, using AF-C also gives very fast AF performance.
 sgoldswo's gear list:sgoldswo's gear list
Leica Q Leica M Typ 240 Nikon Df Nikon D810 Nikon D750 +1 more
sgoldswo
I have FW 1.01 and my X100S AF is faster than my old X100
christy88 Junior Member • Posts: 27
I was this close to getting one today at the airport but held off. From all the replies on FujiX-Forum It looks like only the Japanese and APAC models (serial letter 0 and M) do not suffer from AF lag (irrespective of firmware). Perhaps getting an import from Digitalrev aint such a bad idea - not withstanding the lack of original receipt / fuji warranty..
sgoldswo
Mine is a UK model
sgoldswo wrote:
Mine is a UK model
you sure? uk model should be 31N. can u confirm?
Mine is Canadian model 31A - nt
christy88 wrote:
sgoldswo wrote:
Mine is a UK model
LaFonte Senior Member • Posts: 2,744
This is a totally in line of an urban legend. They don't make different models for different countries  it is the same camera with different stickers. The phase detection is not same as the phase detection in dslr. The purpose of the on chip phase detection is to determine if the lens is currently in back or front focus and then move it accordingly correct way. But the actual focus is not done by this - the differential in phase is too small for correct pinpoint focus, it is just for direction. When it gets the direction right the lens doesn't need to go full cyc down then up it simply goes in right direction, the saving in time could be easily 3x. You want to avoid the case when it starts wrong direction because then it would need to cycle lens twice and it will be slower than without ph. So if it is not 90% sure it doesn't engage at all. It is really a bit flimsy system that only improve chances of faster focus, but it isn't faster focus per se. Still in average it should improve the chances of faster focus from x100, but not like dslr speeds.
 LaFonte's gear list:LaFonte's gear list
Fujifilm FinePix X100 Panasonic Lumix DMC-FZ1000 Fujifilm X-Pro1 +1 more
that is true
but i am seeing more of the scanning of the whole focus range in most of the cases
AF box size
i am not finding a difference between medium and smallest box size in terms on AF speed in AFS mode
FW 1.01, and SN starts with 31Q (probably Germany)
