profoto pro 5 2400 information ? Anybody ????
Started Apr 18, 2013 | Discussions
michael lipman Junior Member • Posts: 35
I'm looking into the old Pro 5 myself and noticed the Profoto site is terrible in giving information.
There is NO information about it any where.  ANYWHERE!!!!
Any one have an old spec sheet sitting around any where you could share???
mlipmanphoto New Member • Posts: 2
Re: profoto pro 5 2400 information ? Anybody ????
Ok found it !
http://www.vistek.ca/store/ProPhotoProfoto/141042/profoto-pro5a-2400-power-supply-only/Specs.aspx
3.5 sec recycle time and 29 lbs and real expensive to fix
umm no thank you.
gemeneye New Member • Posts: 1
Hello Michael.  I Have (qty 2) Profoto Pro studio generators and (qty 4 heads that I am selling), and other studio lighting equipment including light stands, booms, backdrops, etc.
Please reply for more information if you are still interested.
thanks,
Corby
jakevador New Member • Posts: 1
Hi Michael,
i purchase used Pro 5 power pack from USA and don't see any power setting on (like the newer packs).
did U know if i can use it in France (220v) within dammage ?
thanks,regards.
Jake
Matt L - Blink Photographic
Matt L - Blink Photographic Regular Member • Posts: 182
jakevador wrote:
Hi Michael,
thanks,regards.
Jake
Jake,
The Pro-5 is self seeking voltage and no problem to use with 220V.   You would have to change the modeling lamp as they operate directly off the incoming voltage.
Matt LaPointe
Blink Photographic Equipment, Inc
The Profoto Pro 5 was phased out about 1997 or so ....  it differs a bit from anything that came after.
The Pro 3 and Pro 5 systems had a trigger voltage of 700 volts.  The Pro 6, Pro 7 and Pro 8 are 1000 Volt Systems.
So while many accessories will fit, flashtubes are definitely different.   Also using Pro 5 (PF) heads on current packs would have a significantly shorter lifespan for the flash tube.   Using later heads on a Pro5 pack would result in possible misfires.
Hope that helps .....
Matt LaPointe
