Nikon to Pentax K adapter
Started Apr 18, 2013 | Discussions
emem
emem Veteran Member • Posts: 4,196
Does anyone use such a thing? If so what make and how good is it in practical terms? Can you use AF or is it purely manual? I have some nice Nikon lenses and would love to use them on my K-5.
Mike M. (emem)
www.veritasmea.com
 emem's gear list:emem's gear list
Pentax *ist DS Pentax K10D Pentax K20D Nikon D300S Pentax K-5 IIs +12 more
Pentax K-5
Simon Devlin
Simon Devlin Senior Member • Posts: 1,326
Re: Nikon to Pentax K adapter
I've never heard of this marriage and if you could do, AF would never ever be compatible in a zillion years.
You could try duct tape.
Look up the web although I have never heard of it.
Simon
Legacy lens lover
smafdy Regular Member • Posts: 494
I wondered the same thing when I bought my Pentax bodies. I don't think the Pentax mount is adaptable to the optics of other manufacturer's glass. I think it has something to do with the mount to sensor distance, although I'm not absolutely sure of it. It does seem to me that if an adapter was possible, someone would be manufacturing it.
altis Contributing Member • Posts: 846
steephill Veteran Member • Posts: 9,747
Ask Ron (brandx)
A manual focus adaptor exists but it has a correction element built in because of the registration distance issue. This means it is also a teleconverter. AF is not available.
Steve
www.pbase.com/steephill
brandrx Forum Pro • Posts: 28,337
Re: Ask Ron (brandx)
You can go either way, Pentax to Nikon or Nikon to Pentax. In order to focus to infinity you need to have the glass corrective elements. It will provide a teleconverter effect of about 1.25 to 1.3X. You can get them without the glass corrective elements also but you lose infinity focus. These things are cheap enough that it is worth a try IMO. I don't remember which one that I bought. I think they are all pretty much the same thing. The one with the glass corrective elements work best with very good lenses.
Nikon PK adapter
I bought one with and one without the glass corrective elements to use with a Nikon 400mm f2.8 AI-S manual focusing lens. Without the glass corrective elements It will only focus to about 100 feet.  However, I did find out that my Nikon 400mm f2.8 + Nikon TC-301 2X teleconverter will focus to infinity with a Nikon-PK adapter that does not have the glass corrective elements. With a Nikon 1.4X TC it will focus to about 400 feet. With a Nikon TC16A 1.6X AF Adapter (set to it's infinity position) it will focus to about 600 to 700 feet. With the glass corective elements Nikon-PK adapter I do have a loos of IQ but not too much IMO. It is still very usable. I also use it with my Pentax 1.7X AF Adapter to make for a 400mm times 1.3X times 1.7X (884mm) autofocusing lens.
Forum member Ari Aikomus modified a Pentax K-mount Kenko 1.5X teleconverter to take a Nikon lens on the lens mount side
Cheers.
Ron
Ron - 'We don't have time to go take pics this afternoon Carl.'
Carl - 'What do you mean? It will only take 1/1000s.'
'Keep your eyes looking forward. However, glance back now and then to see where you've come from. It will put a smile on your face.' ~ brandrx
emem
emem OP Veteran Member • Posts: 4,196
Thanks for the detailed response Ron - appreciate it. I did find a Nikon-PK adapter online after I started this thread which allows you to remove the glass element. Not sure how that will work but I might give it a try.
Mike M. (emem)
www.veritasmea.com
I did the same thing with my original one that I bought. However, when I wanted to screw it (the elements) back in I had a problem keeping them (there are two lens elements) clean. I found it was less hassle to just buy one with glass elements and one without glass elements.
EDIT: Also take not that without the glass elements you cannot focus to infinity. My 400/2.8 will focus to about 100 feet. I remember trying it with a Nikon 200mm macro and I think it would only focus to about 10 feet. So, even shorter focal length lenses will have even shorter maximum focusing distances when used with a glassless adapter. I always wanted to try a glassless adapter with a Nikon 800mm f5.6 just to see hor far I could focus but I didn't want to spend over $3000 just to do that test.
Cheers.
Ron
Petroglyph
Petroglyph Senior Member • Posts: 4,974
Re: Photodiox probably makes one.
I tried one going the other way.  To mount an old PK/A 50mm f/2 manual lens on a Nikon D60 (CCD sensor also old tech).  It actually worked fine in completely manual mode and can focus at infinity.  I thought the fit was a little wobbly so I wouldn't use it until they come out with a pro-grade model.  I haven't checked in over a year if they have or not.  It is fun experimenting with things such as that.
Regards.
 Petroglyph's gear list:Petroglyph's gear list
Sony Alpha 7R II Pentax K-1 Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Pentax smc DA* 300mm F4.0 ED (IF) SDM Pentax smc FA 43mm F1.9 Limited +5 more
photoholiko Senior Member • Posts: 1,028
I just acquired a Canon FD to PK adapter and I already have one for Nikon lenses, they both have glass elements but the FD one doesn't allow me to focus to infinity, the one for Nikon does. I have used different brand lenses with both adapters and found the results from FD lenses are not impressive on the Pentax while they do well on other cameras, howerver the Nikon mount lens do great.
 photoholiko's gear list:photoholiko's gear list
Canon EOS 400D Olympus PEN E-PL1 Canon EOS 70D Epson PhotoPC 850 Zoom Minolta DiMAGE 7 +25 more
