How to light black metal objects?
Started Apr 16, 2013 | Discussions
(unknown member) Forum Pro • Posts: 10,011
Re: Strobist article
AlbertInFrance wrote:
Thing is, there was nothing wrong with the basic lighting, in terms of the modelling on the guy's face, for example, as far as I could see.
I wasn't suggesting that there was something wrong with the original lighting. I was illustrating how the lighting in an edited image can be made quite different from the original.
Whether it is right or wrong or better or worse depends (as I said before) on one's subjective tastes and on the use to which the image will be put. My main point is that lighting isn't necessarily baked into the original image; it can often be changed quite dramatically in post.
I was responding to your statement that "If it ain't lit right then all the PP in the world won't rescue it." I respectfully disagree with that statement.
EDIT: Maybe this will make the point more clearly. The top image definitely wasn't lit "right" for the client's purposes, because he needed a night shot and wasn't able to visit the property at night and do that. So he hired me to change it to a night shot. Clearly, what wasn't lit "right" could be rescued in post.
~ Peano
www.radiantpics.com
AlbertInFrance
AlbertInFrance Senior Member • Posts: 5,410
~ Peano
www.radiantpics.com
Depends on how credulous you are.
And how did he get that into a studio>
Albert
Every photograph is an abstraction from reality.
 AlbertInFrance's gear list:AlbertInFrance's gear list
Canon PowerShot G15 Fujifilm X-T1 Sigma 70-300mm F4-5.6 APO DG Macro Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R +4 more
