Vanguard SBH-30 ball head question
Started Apr 15, 2013 | Discussions
baneling
baneling Senior Member • Posts: 1,645
hi all, i came back from a camera store and i looked at this ballhead.  when i locked it, i was able to push on the part where the camera sits on and i was able to move it.  is this normal?
http://500px.com/baneling
http://www.redbubble.com/people/baneling/portfolio
Canon T3i
Canon EF-S 18-55mm f/3.5-5.6 IS
Canon EF-S 55-250mm f/4-5.6 IS
Canon EF-S 50mm f/1.8
 baneling's gear list:baneling's gear list
Canon EOS 600D Canon EOS 5D Mark III Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 18-55mm f/3.5-5.6 Canon EF 70-200mm f/4L IS USM +4 more
digital-freak
digital-freak Senior Member • Posts: 2,784
Re: Vanguard SBH-30 ball head question
Since this has only one knob for the ball tension, if you tightened it and were still able to move it, No this is not normal.
*/Mark/*
____________________________________________
- http://mark4pics.com
 digital-freak's gear list:digital-freak's gear list
Nikon D750 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF Nikkor 28mm f/2.8D Nikon AF-S Teleconverter TC-20E III Tamron SP AF 90mm F/2.8 Di Macro +16 more
puttin
puttin Veteran Member • Posts: 6,767
I would not trust it. Look at the SBH 250, around $70 from b&h. I can't move mine, it has 2 knobs plus 1 for panning.
 puttin's gear list:puttin's gear list
Fujifilm XF1 Fujifilm X100S Nikon Coolpix A Fujifilm X70 Nikon D300 +30 more
baneling
baneling OP Senior Member • Posts: 1,645
i'll consider that.  but my other option is the manfrotto 055cxpro4 with the 054-Q2 head.  what do you think of that option?  i read in an old article that you can move the ball on vanguard heads when they are locked, but not on manfrottos.  but like i said, its an old article.  i haven't played with the 054-q2 head though.   plus is i were to get the vanguard tripod, i'd get the BBH-200 head which i'm hoping is better than the SBH-30 and doesn't move when locked.
Canon T3i
puttin
Canon T3i
I can even move my SBH 50 head like you but my SBH 250 is solid. I use it on my 055XPROB
baneling
why is that?  is it cause the SBH-250 can hold heavier weight?
Canon T3i
puttin
Canon T3i
Yes and because it has a bigger ball.
baneling
is it a problem if you can move it with your hand?  its not like a person would do that while the exposure is going on and assuming we're not using those really big lenses and I doubt there is wind strong enough to move it.
Canon T3i
Joshua123
Joshua123 Regular Member • Posts: 335
Yes, the SBH-30 is a light duty head.  I have, like others have mentioned, the SBH-250.  I enjoy it with the Vanguard aluminum tripod legs combination.
Vanguard has a 100% guarantee.  Included in the literature you received with you tripod head lists this guarantee. Vanguard will replace this head free of charge.  Call the number listed in the literature or on the box.  A rep from Vanguard will be more than happy to speak with  you and replace your head if necessary (no questions asked).
,Josh>
 Joshua123's gear list:Joshua123's gear list
Nikon D50 Nikon D300 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S Nikkor 24-70mm f/2.8G ED +6 more
baneling
have you heard or read anything about the BBH-200?  does it move if you push it?
Canon T3i
Joshua123
No.  The Vanguard BBH-200 head compared to the SBH-30 head would be like comparing a VW Beetle to a Lamborghini.
<Josh>
