Lightroom 5 is out
Started Apr 15, 2013 | Discussions
MisterBG Veteran Member • Posts: 5,813
Re: Don't like some of the changes
RoelHendrickx wrote:
StevenN wrote:
I've only tried Lightroom 5 out briefly, but I already miss the Recovery slider and Fill light slider that they've eliminated.
I'm talking about the differences from Lightroom 3.6 (I was going to get version 4 -- until 5 beta came out).
Under the Basic controls, here's the differences:
Lightroom 3.6                                       Lightroom 5
Exposure                                                Exposure
Recovery                                                Contrast
Fill Light                                                 Highlights
Blacks                                                    Shadows
Brightness                                              Whites
Contrast                                                 Blacks
I worked on a raw photo that I previously had worked on in Lightroom 3.6, and I wasn't able to achieve the same pleasing result with version 5. But I understand that this is still in beta, so it should get better.
The methodology changed between LR3 and LR4.
Takes some getting used to, but you will get there.
The new methodology is more logical, actually, with all sliders that affect "exposure" and light levels, resulting in brighter to the right and darker to the left.
In the old methodology, the "Blacks" level slider made the image darker when sliding to the right.
Since LR 4 was the first edition that I thought was worth the money, I'm not aware of the changes in the slider labelling compared to earlier versions, so I don't have to "unlearn" anything.
What I will say is that the highlight recovery in LR4 is better than any other raw developer programs that I've tried, and that's most of them.
The actual image manipulation tools in Lightroom seem to be simple and intuitive, although I cannot say that about some of the other features, although I slowly becoming more familiar with the program.
I've downloaded the LR 5 Beta but not yet had a chance to play with it.
It's a "doh!" situation when you've paid out for a piece of software and a new release comes along quite quickly. I hope Adobe's upgrade pricing is not too aggressive when the final release of LR5 comes out.
>The only way of discovering the limits of the possible is to venture a little way past them into the impossible.
RoelHendrickx
RoelHendrickx Forum Pro • Posts: 24,431
Exposure                                                Exposure
Recovery                                                Contrast
Blacks                                                    Shadows
Brightness                                              Whites
Contrast                                                 Blacks
That is why I have stuck with LR since trying it (without even looking further) : the workflow is just totally intuitive and natural for me (but I don't use everything : mainly just the basics).
I've upgraded from 2 to 3 and to 4 and found the upgrade policy reasonable.
IIRC, I think that LR4 was also cheaper than previous versions for new buyers.
Roel Hendrickx
lots of images: www.roelh.zenfolio.com
my E-3 user field report from Tunisian Sahara: http://www.biofos.com/ukpsg/roel.html
MatsP
MatsP Senior Member • Posts: 1,516
Exposure                                                Exposure
Recovery                                                Contrast
Blacks                                                    Shadows
Brightness                                              Whites
Contrast                                                 Blacks
StevenN
Roel Hendrickx
I have used LR 1,2,3,4 and now 5. It has developed from a quite simple organizing tool with the possibility to some basic adjustments to a very sophisticated piece of software. Earlier I needed PS, PTlens and other programs to make complimentary adjustments. Now I manage with LR alone. The controls introduced in LR4 are much more logical and easier to use than the old ones. Getting used to them was no problem at all. I think it was a great advantage.
 MatsP's gear list:MatsP's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Samyang 7.5mm F3.5 UMC Fisheye MFT Olympus 12-40mm F2.8
MatsP
Re: Lightroom 5 is out
exdeejjjaaaa wrote:
MatsP wrote:
It seems also to me as the colors from my E-M5 look better than in LR4. If Adobe really has done someting about their a little strange color rendering from Oly raw files it's good. Or is itjust my imagination?
compare .dcp profiles from v5 vs v4...
I don't know what that means, but I made a test by comparing two copies of same picture, one imported into LR4, one into LR5 and then exported to jpeg whithout any other processing. There is no difference. It was my imagination.
Bob Tullis
Bob Tullis Forum Pro • Posts: 31,106
Exposure                                                Exposure
Recovery                                                Contrast
Blacks                                                    Shadows
Brightness                                              Whites
Contrast                                                 Blacks
StevenN
I felt the same way going from v3 to v4 initially, but in fact the algorithms involved are dramatically better.   v4 gave new life to existing RAW exposures, like that old camera suddenly had a new sensor.   The practice of taking multiple exposures for HDR type blending has become very much less necessary - when I do execute such, most times one of the bracketed exposures is all that's required.
I ended up getting Martin Evening's LR4 book, which gave a lot of insight into the differences obvious and under the hood.  Give LR5 and yourself a chance to get to know each other - not to would be a disservice to your photography [g].
...Bob, NYC
http://www.bobtullis.com
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Little Big Man
 Bob Tullis's gear list:Bob Tullis's gear list
Sony Alpha 7S Sony Alpha 7R II Voigtlander 28mm F2 Ultron Sony RX1R II Sony Alpha 7 II +16 more
Droogie45
Droogie45 Regular Member • Posts: 206
Re:Quick question?
I've never had the chance to use Light Room, however I usually have the latest versions  of Photoshop, is there something I'm missing out on with Light Room? Do I need it?
 Droogie45's gear list:Droogie45's gear list
Olympus PEN E-PL2 Panasonic Lumix DMC-G3 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Sigma 30mm F2.8 EX DN Sigma 19mm F2.8 EX DN +8 more
MatsP
Re:Quick question?
Why not download the beta and try it. Its for free. Then you can decide if you want to buy the sharp version when it comes in June. Only you know if it is something for you.
Bob Tullis
Re:Quick question?
If you're comfortable with PS, there's no reason to change.   LR is more geared towards photographers, however, and has a lot of conveniences w/o the extras.   It would take a different approach if you're used to working with layers, and a third party book would be useful to make the transition easier if you wanted to give it a go.
The beta version would be a good way to check it out - iirc you'll get more time to use it than if you tried the trial version of the current version.
...Bob, NYC
Mingjai
Mingjai Senior Member • Posts: 1,338
I agree with this--I was amazed at how much more room there was to process my GH1 RAWs than under LR3. Even my G1 and E-PL2 RAWs benefited, but the GH1 benefited the most from the new processing engine.
 Mingjai's gear list:Mingjai's gear list
Panasonic Lumix DMC-GX7 Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital ED 75mm F1.8 +16 more
Droogie45
Re:Quick question?
I think I will give it a go. Just to see how the other half lives. Plus I can get an educational discount if I like it.
bgalb
bgalb Senior Member • Posts: 1,728
I have been playing with LR5 just a little and don't see much different from 4.4.  I have noticed the Blue and Red "blinkies" or whatever you call them that indicate blocked shadows and blown highlights.  Am still not sure if they will be very useful.  May be when I get used to them.
Have yet to find a way to turn them off ??  Sometimes they are irritating when I want to leave some of my shadows or dark areas like they are, but those nagging blue patches keep getting me conflicted between adjusting them off or leaving the dark areas the way I seem to want them in some photos.
Any way to turn them off when desired ? Anyone?
 bgalb's gear list:bgalb's gear list
Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix DMC-GX85 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +5 more
JohnBGood
JohnBGood Regular Member • Posts: 347
If it's behaving like the same option in LR4, all you have to do is to click on the corresponding arrow that are located at the top of the Histogram window, left arrow is for the blacks, right one for the whites (both small arrows are pointing up)
Usefull but I also don't let them on, just using them on occasion.
Hope this help
-John
A mind is like a parachute, it works better when open.
 JohnBGood's gear list:JohnBGood's gear list
Canon PowerShot A720 IS Olympus OM-D E-M5 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 +4 more
Atwater Forum Member • Posts: 83
If it's the same as LR 3.6, then click on the triangles in the upper corners of the histogram in the develop module.
 Atwater's gear list:Atwater's gear list
Lytro Light Field 8GB Panasonic Lumix DMC-G1 Olympus PEN E-P2 Panasonic Lumix DMC-GX7
robert1955 Senior Member • Posts: 2,499
Re: Is LR now out of sync with ACR?
When your LR and PS versions are not in synch, when you want to edit in PS you get a warning [a nag screen really] that informs you that 'this operation may require version 7.4 of ACR."or words to that effect. This has been updated already to tell you the version should be 8.1.
 robert1955's gear list:robert1955's gear list
Fujifilm X-T1
tgutgu Veteran Member • Posts: 3,613
The "J" keyboard shortcut toggles the markings on and off. That should be the easiest way.
Thomas
 tgutgu's gear list:tgutgu's gear list
Olympus E-M1 Olympus E-PL7 Olympus E-M5 II Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +30 more
bgalb
Oops!  I never used them in LR4 and they must have been on by default in LR5 beta.  Thanks!
Re:Quick question?
Funny, I'm coming from the opposite position.
I've adopted Lightroom as my raw developer and I've never used Photoshop. Lightroom does just about everything I need, so I wonder what advantage I will gain by having Photoshop. I tried Elements, hated the UI and found it so limited in what it can do. The full Photoshop CS is way to much money to even think about.
Yes! I just tried LR5 beta for the first time, and the highlight/shadow clipping indicators were enabled by default. In LR 4.4 you need to select them to enable the display.
