2 question about YONGNUO OEM YN-560 II
Started Apr 15, 2013 | Questions
mantra
mantra Contributing Member • Posts: 769
hi
may i ask you 2 question about YONGNUO YN-560 II ?
i have a canon 5d mark 2
1)my first question is
if i mount a flashgun on my 5d mark 2 can i let fire the other YONGNUO YN-560 II flashguns ?
in short like the canon 580 II
2) if i mount an YONGNUO transmitter on my canon 5d mark 2 and a receiver on an YONGNUO YN-560 II, can i let fire others 560 II flashguns
or do i need 1 transmitter and 3 receivers  if i have tree 560II
thanks
hope to be not off topic
 mantra's gear list:mantra's gear list
Canon EOS 5D Mark II Nikon D700 Canon EOS 5D Mark III Canon EF 50mm f/1.4 USM Canon EF 85mm f/1.8 USM +9 more
diyphotographystuff
diyphotographystuff Regular Member • Posts: 193
Re: 2 question about YONGNUO OEM YN-560 II
mantra wrote:
hi
thanks
The yn560ii has a simple builtin optical slave.
1. if you put any flash on you 5dmkii , your other yn560ii will fire in S1/2 slave modes. You set their power manually.
2.You can use with them the simple RF602/3, yet you'll still have to set the flash power manually.
If you want something more advanced, I recommend using the following:
YN622C  + YN565EX  or YN568EX
This combo will let you control the set from your camera menu. It costs more, but the options are amazing.
TNX
DIY photography stuff for product photography and
portrait photography
http://www.diyphotographystuff.info/
mantra
mantra OP Contributing Member • Posts: 769
hi Tnx
thanks a lot!
Suntan Veteran Member • Posts: 5,637
As DIY said, set any remote 560II to S1 mode and it will flash whenever the camera mounted flash or the flash connected to your RF trigger fires.
-Suntan
 Suntan's gear list:Suntan's gear list
Panasonic Lumix DMC-LX100 Nikon D300 Nikon D750
Freneticburn Regular Member • Posts: 200
-Suntan
If you have a flash using automatic ttl metering mounted onto the camera make sure to use S2 mode so the pre-flash for metering doesn't set the slave off but rather the actual flash for the photo sets it off.  S1 mode is for when you are using the flash mounted on your camera in manual (as in not using ttl metering)
 Freneticburn's gear list:Freneticburn's gear list
Canon PowerShot SX260 HS Canon EOS 550D Canon EOS 6D Canon EF 50mm f/1.4 USM Canon EF 135mm f/2.0L USM +3 more
