D800e Red Oversaturation
Started Apr 15, 2013 | Discussions
Randy Redford
Regular MemberPosts: 204Gear list
Apr 15, 2013
I just printed my first image with the D800e -- shot raw and processed through ACR and PS (latest versions) and the reds are all way oversaturated to the point of almost being blown.
Have any of you had this issue?  Any advice would be greatly appreciated.  I am trying to decide between this and a Fuji x-e1 for an upcoming trip to India.
Thanks.
Randy
Fujifilm X-E1 Nikon D800E
FourT6and2
Forum MemberPosts: 51
Re: D800e Red Oversaturation
In reply to Randy Redford, Apr 15, 2013
Thanks.
Randy
If you edited the photo through ACR and PS, then it's not the camera's fault. You need to go back and review your workflow process. Shooting RAW gives you the ability to have complete control over your color. If your reds printed over saturated, then maybe bring back the reds a bit in PS. Just a thought...
michaeladawson
Veteran MemberPosts: 8,991Gear list
Thanks.
Randy
All I can say is "yes".  In all my years of owning Nikon DSLRs, going back to the D100, I have always had the most difficulty with the red channel.  I am not saying this is a fault of Nikon.  I don't know.  All I do know is that you have to be very conscious of the red channel because that is the one that will tend to blow out first.
Is it any worse than Canon or Sony?  Don't know.  The only thing you can really do is expose for the red channel and handle correction in post.  The good news is that the D800 has a lot of DR and you can bring up the shadows a ton with very small degradation in quality.
Mike Dawson
 michaeladawson's gear list:michaeladawson's gear list
Panasonic Lumix DMC-LX3 Nikon D200 Nikon D4 Nikon D800 Nikon D800E +21 more
Robin Casady
Forum ProPosts: 12,898
...the reds are all way oversaturated to the point of almost being blown.
You have to watch what color space you are using, and what your printer can handle. Photoshop has a Gamut Warning that will tell you when a color is blown for the color space being used.
If you are using ProPhoto RGB, or Adobe RGB, and your printer can only handle sRGB, you are likely to process colors beyond what your printer can render.
Lightroom 4.4 and ACR use camera profiles for rendering color for different cameras. If you wish, you can open one of the Adobe camera profiles in the free Adobe DNG Profile Editor and make adjustments for reds. Then save it as a new profile and apply that to your files.
With digital RAW, the color is up to you.
Robin Casady
http://www.robincasady.com/Photo/index.html
"The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts."
— Bertrand Russell
Tony Beach
Veteran MemberPosts: 6,833
In reply to michaeladawson, Apr 15, 2013
This is very infrequently true.  The green channel blows out first far more often than the red channel.
How are you evaluating exposure for the red channel?  Do you set your camera up with neutral settings such as a linear curve?  Do you use uni-WB?  If not then it is likely you are underexposing the entire file to address a problem that lies elsewhere.
Yes, you can underexpose and then correct that in post processing; or better still, you can expose properly and address the problem with oversaturated reds in the conversion of the Raw file by avoiding high saturation, possibly applying a negative exposure compensation, and watching your output gamut.
Steve Bingham
Forum ProPosts: 23,129Gear list
Generally speaking, red channel problems CAN be a product of all DSLR files that I have seen. When shooting red roses, California poppies, or magenta clothes, the red channel can sometimes become blown (R=255) or merely super saturated (R=190-250). The solution most always ends up becoming a PP one and might well include some initial exposure compensation, like -.5. If the problem is simply too much red saturation, that can easily be taken care of in your raw conversion.
If the red channel is truely blown, the solutions are many:
1- Cut initial exposure
2- Do a double raw conversion and mask the reds. Most effective
3- Simply reduce the saturation in raw conversion
Steve Bingham
www.dustylens.com
www.ghost-town-photography.com
 Steve Bingham's gear list:Steve Bingham's gear list
Nikon D7200 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Sigma 17-50mm F2.8 EX DC OS HSM Tokina AT-X 12-28mm f/4 Pro DX +16 more
39matt
Regular MemberPosts: 441
In reply to Steve Bingham, Apr 15, 2013
In Lightroom 4 and I am guessing ACR in Photoshop the default Adobe Standard is too saturated. I found this with my D800.
If you change the camera profile to Camera Standard this gets it back to being virtually spot on with out of camera jpegs when set to camera standard.
It might not work for you but it solved my problem with over saturated images.
Hope that helps
39matt
In reply to 39matt, Apr 15, 2013
Wasn't clear. I meant change the camera profile in Lightroom or ACR in Photoshop not on the camera
mlewan
Senior MemberPosts: 1,284Gear list
What does "double raw conversion" mean?
Tony Beach
In reply to mlewan, Apr 15, 2013
Convert once optimizing the EC for one part of the image (e.g., the sky, in lieu of using an ND filter), and then again optimizing for some other part of the image (e.g., a dark foreground, or a bright red rose).
Stacey_K
Veteran MemberPosts: 7,617Gear list
I used to shoot with olympus and have found the nikon files do tend to over saturate reds. It's not a hard thing to fix in photoshop or in CNX2 but it is something I have noticed compared to the files from my E1/E410 olymnpus dSLRs. At first I was seeing totally blown out reds and thinking "????". Now I've learned to under expose when there are hot reds in the scene and be ready to desaturate them in post if needed to keep them from being blown.
Stacey
 Stacey_K's gear list:Stacey_K's gear list
Nikon D200 Nikon D700 Nikon D7000 Nikon D800 Sony Alpha 7 +14 more
digital ed
Veteran MemberPosts: 3,418Gear list
Thanks.
Randy
I use DXO Optics Pro8 for 90% of my development and it is very easy to de-saturate the red channel without any change to the other channels. Occasionally need to do this for D800 photos of red flowers.
 digital ed's gear list:digital ed's gear list
Olympus E-1 Olympus E-3 Nikon 1 V2 Nikon D810 Nikon AF-S Nikkor 14-24mm f/2.8G ED +15 more
mlewan
In reply to Tony Beach, Apr 15, 2013
And that assumes Photoshop and Smart Objects? Fair enough. I had missed that the OP already had PS.
My experience is that red oversaturation is less of a problem if one uses View NX or Capture NX. If one has Capture NX one can of course also use control points and adjust saturation or exposure locally directly.
Robin Casady
Or brush layers in Lightroom 4.4.
Robin Casady
— Bertrand Russell
jfriend00
Forum ProPosts: 11,163Gear list
In reply to Robin Casady, Apr 15, 2013
You don't even need a brush layer in Lightroom.  You can just turn down the saturation or luminance of the reds with the HSL control.
iJoost
Regular MemberPosts: 105
It's perhaps best if you show an example of the problem.
bgbs
Senior MemberPosts: 2,362
I don't get it  You said you printed the file and the print has blown reds. What were you seeing on the monitor then? Sounds like you're having calibration and profile problems. The first solution is to calibrate your monitor and profile your printer. What you see on screen should come very close to your print output.
Randy Redford
In reply to bgbs, Apr 15, 2013
I do have a calibrated monitor, and the reds were blown on it as well.  My printer tends to print darker than the screen (I don't have them calibrated together, but know about the amount of the difference) and the reds were much more blown on the monitor.
RR
j_photo
Senior MemberPosts: 2,381Gear list
In reply to Randy Redford, Apr 16, 2013
Isn't the solution to expose the image properly, so as not to blow the red channel?
If any channel is blown, then it cannot be really repaired in post processing--data has been lost that cannot be recreated.
 j_photo's gear list:j_photo's gear list
Nikon D800 Nikon Df
jfriend00
In reply to j_photo, Apr 16, 2013
It is always better to get the best exposure possible.  But, since it was shot as a RAW, the blown highlights may only be in the developed image - there is probably more data if it is developed properly.
An after-the-fact fix like this involves going back to the RAW processors and using soft proofing capabilities to bring the red channel into the range of the print/paper using a profile created specifically for the printer/paper combination so that detail can be seen in the reds in both the soft proof image and the print.
If it's hopelessly blown in the RAW and a good RAW processor can't recover any detail, then the only answer is to reshoot or live with the best result possible.  Otherwise, back off on the saturation or luminance of the reds to bring them into the range of the printer/paper.
