Nik Collection as Stand-Alones?
Started Apr 14, 2013 | Discussions
SantaFeBill Senior Member • Posts: 2,372
I got the Google version of the Nik Collection, since I was able to get it for free.
Can the apps in this version be used as stand-alones, following Jason ODell's instructions, or does this version only install and function if you have one of the stated programs?
I know, I could just try it. But I'm under some close deadlines on other projects, and my experience has been that, if something doesn't go just right, time multiples as you try to figure out why and how to fix. So I'd appreciate knowing in advance if it's not going to work.
Thanks.
_Fotogrfr_ Contributing Member • Posts: 755
Re: Nik Collection as Stand-Alones?
A friend of mine purchased the collection not knowing that HDR Efex 2 would not run in Elements.  However, I pointed him to sources that said it can run as stand-alone.  He located the exectuable and double-clicked on it.  Lo and behold, it opened up as a stand-alone and seemingly works fine.
The others in the collection have executables there too so I'm thinking that they can all run as stand-alone.  He's only tried HDR Efex though.
JPEG Shooter
galleries at: http://www.pbase.com/fotogrfr
Skip
Skip Senior Member • Posts: 1,847
I have used a couple of them as stand-alones on my iMac. One of them, I forget which it was, had no obvious way of opening a file. It's pretty clear that the teams writing these programs were not very well coordinated. Anyway my point is that I finally got the program to run the old fashioned way by dragging the photo icon from the desktop onto the program icon on the dock. I probably hadn't started a program that way in over two years.
 Skip's gear list:Skip's gear list
Panasonic Lumix DMC-FZ150 Panasonic Lumix DMC-ZS40 (TZ60) Panasonic Lumix DMC-G5 Sony a77 II
Toermalijn
Toermalijn Forum Pro • Posts: 13,603
Thanks.
I tested all the stand alone versions and can confirm that they all work as a stand alone.
SantaFeBill OP Senior Member • Posts: 2,372
Re: Thanks Very Much to All (nt)
___________
SantaFeBill
