D7100 substantially better AF than D7000??
Started Apr 14, 2013 | Discussions
Gene Goodman Regular Member • Posts: 181
Hi D7100 usersl;
Generally a happy D7000 owner (2 1/3 years coming from a D80).  My main problem is AF consistency.  I find that focus is spot on, then not.  I fine tune and come up with one value,  then then a week later its a different value,  example from 0 to -6,  or -8 to -14.  Then after fine tuning, I do a portrait focused on 1 eye, and it back focuses!!  Of course this is not ALL the time, and many shots are very accurate, then not??   My D7000 DOES NOT have any left/right focus problems.
For fine tuning I have kept light (and color of light) consistent.
If a D7100 would be substantially better in AF consistency, then I would upgrade.  I do not need high buffer speed or frame rates, an not concerned that shadows may have streaking/banding/noise, or that I will not get an ISO lift.
Reading the posts, it seems that 1/2+ of you D7100 users say the AF if GREAT, but a good number also say that it is inconsistent.  To be sure, I am not talking about speed of focus, just CONSISTENCY and ACCURACY.
So what has been your experience with AF consistency from D7000 to D7100
Thanks;
Gene
Nikon D7000 Nikon D7100 Nikon D80
Mako2011
Mako2011 MOD Forum Pro • Posts: 20,141
side by side
Gene Goodman wrote:
Hi D7100 usersl;
This should not be the case. What method did you use to determine your AF-Fine tune value? Other things that can affect the result are light temp if using certain lenses. What AF mode and AF-Area mode do you most often use?
What target and what method?
Most are finding it very good with focus...but I also find my D7K very good and very consistent as well. I suspect the D7100 to be a bit better but not blow the doors off better. I tested both side by side this week and found the D7100 better when the light gets dimmer than the D7K can lock in. D7100 seemed able to track slightly more accurate in AF-Area mode 3D as well. In Normal and low light...my copy was as accurate/consistent as the D7100 I was using but I only compared in 9pt, single, and AF-ON. The D7100 I test seemed a fine sample. I would certainly recommend that body.
Gene Goodman OP Regular Member • Posts: 181
Re: side by side
All fine tune tests done with AF-s single point using either a  typical fine tune chart,  or on a well defined flat subject and then varying fine tune amounts to see which were sharper.  Typically I take about 4 shots/test,  2 starting focus further out, then 2 starting with focus on the closer side.   I did sent the camera back to Nikon  -  on first "repair" the did say they replaced a part,  2nd time was just adjusted.  most shots at 1/320 sec exposure and all in similar lighting.  Done many times with a number of diff lens.  Pls note I am not bashing the camera,  in all other respects I am a happy camper, just wondering if D7100 will be particulary better  -  as you said, D7100,  for  you,  is better, but not by a great amount.
Thanks Mako
Gene
Mako2011
jsut helping
Thanks Mako
Gene
Never thought any bashing going on at all. Just hoping to help in some way. Be sure you're not using slanted charts. They can ruin everything. Horshack's DotTune method is amazingly accurate and a good cross check as well.
DotTune Video
I thought the D7100 to be very good. It's build quality seemed just a tad better as well and I found it fit my hand better. Small things make a world of difference. Sell the D7K and Buy the D7100 and it's not that costly.
My opinions are my own and not those of DPR or its administration. They carry no 'special' value (except to me and Lacie of course)
toomanycanons Forum Pro • Posts: 10,757
Re: D7100 substantially better AF than D7000??
My D7000 locked focus instantly every time.  No complaints ever.
Mako2011
update
My keeper rate though seems to go way down as my intake of whisky goes up. Wonder if a firmware update might fix that
herbymel Senior Member • Posts: 5,311
Re: update
Does it matter what you're drinking, Whiskey opposed to Cognac or Vodka? So any plans on selling your D7000 now to make an upgrade?
 herbymel's gear list:herbymel's gear list
Nikon D810 Nikon D750 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF Nikkor 50mm f/1.8D +7 more
Re: update
Vodka ups your keeper rate.  I thought everyone knew that.
Re: update
I thought that was only at the bar.
Re: update
Hate to break in on the whisky/vodka/cognac and at home versus the bar discussion, BUT yes, if I bought a D7100, I would sell the D7k.   Speed of focus has never been an issue, except sometimes with the 60mm f2.8 macro.   Its all about being consistent
Thanks all
Gene
Mako2011
not me
Big diff...friuty drinks make me giggle so there's added camera shake : )
Not going to upgrade unless I have to have a back-up (D5100 may work just fine for that). It does seem a better camera in all ways (with the exception of shadows leeway) but much less a jump than the D90 to D7000 seemed. Resolution can make a dif for some and I could see that for certain types of photography. In my case I prefer the ability to push the D7K shadows vs the greater resolution of the D7100. Anybody coming from a D90 or later though...the D7100 is a truly amazing camera at that price point. If something bad happens to my D7000 I'll jump to the D7100 without hesitation. If I when the lotto I'll add a D4 as well and drinks for everyone : )
Mako2011
no real...
Thanks all
Gene
If your current body is a little off and a bit inconsistent...and you get a fair price for it... I see no real reason not to move to the D7100.  Good Luck!
anotherMike Veteran Member • Posts: 8,101
I'm only one data point, but when I had a D7000 as my backup cam, it struggled to achieve consistent focus in the studio under reasonably decent modelling lights. That was simply inexcusable. I've owned D100, D70, D2X, D80, D90, D300, and D700 bodies and none of those ever gave me anywhere the issues that the D7000 did. Same studio, same lights, same modelling lights. Outdoors the D7000 was fine. So I sold the D7000. I shoot a D800E primarily and still have a D700 around, and recently picked up the D7100. In the same studio, same lights, same modelling lights, same type of subject matter and distance, the D7100 has never struggled anywhere like my D7000 did. I personally think the better AF system is enough reason alone to upgrade, even beyond the better sensor and extra resolution.
Disclosure: I had an early D7000 from the first production runs. Perhaps they changed something later and others might have not had the same issue. For a while I tracked what other colleagues who owned the camera were experiencing (all early bodies) and all of them had the same struggles. All of us moved on from that body, so I can't say for certainty whether bodies suffered the same problems.
-m
Thanks Another Mike;
I do have an early D7000, bought in Nov after a Sept introduction, and I do have inconsistent focus results  -  otherwise am not un happy.
Possibly time to change horses?
Gene
JimPearce
JimPearce Veteran Member • Posts: 8,831
A puzzle...
If the D7000 doesn't struggle to focus in challenging situations, where are all of those great D7000 wildlife shots? We know that a lot of wildlife shooters have D7000s.
Jim
 JimPearce's gear list:JimPearce's gear list
Nikon D7100 Nikon D500
Mako2011
first puzzle...
Was this your first puzzle?
solved puzzle
Mako2011
Nope
JimPearce wrote:
http://www.google.com/search?q=d7000+wildlife+photography&source=lnms&tbm=isch&sa=X&ei=81hrUfO3Is7qiQKowYHQDw&ved=0CAcQ_AUoAQ&biw=1643&bih=1050#imgrc=5hWwFr6n2i8ziM%3A%3B-kdbJ5bVPBcKoM%3Bhttp%253A%252F%252Fimg143.imageshack.us%252Fimg143%252F774%252Fdsc04290xx1024qc6.jpg%3Bhttp%253A%252F%252Fwww.dpreview.com%252Fforums%252Fthread%252F2225581%3B1024%3B768
Jim
I be thinking your using a kindle to view pics or your puzzle solving skills are rusty : )
My Fav
JimPearce
Could be manual focus...
Lots of time when the big cats are just hanging out at the zoo.
Jim
jonikon
jonikon Veteran Member • Posts: 5,759
-m
I have an early production D7000 bought in November 2010 and I only found some inconsistent focusing in AF-A mode, so I stopped using it. In AF-S or AF-C my D7000 AF is very consistent and accurate, even in lower light. I find the D7000 focus is more reliable than my D5100, which I believe has the same focus module as the D90, so for whatever reason, my experience with the D7000 AF is different from yours. It is curious that there is somuch apparent disparity in experience with the D7000 auto focusing module and also interesting that Nikon put the same AF module in two other DSLR bodies (D600, D5200), which do not appear to have nearly as many AF complaints as the D7000. Why the difference? That's anybody's guess.
"Pay no attention to that man behind the curtain! The Great Oz has spoken!"
- Jon
 jonikon's gear list:jonikon's gear list
Nikon Coolpix A Nikon D7000 Nikon 1 V1 Nikon 1 V2 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR +11 more
