Nikon 70-200 f4 vs Tamron 70-200 VC
Started Apr 14, 2013 | Discussions
fhibbs12 Regular Member • Posts: 113
I had all intentions in buying this Nikon 70-200 f4 until the tamron rolled along at a similar price point. My plans were using the f4 outdoors an my 85 prime indoors.
But now at a similar price point this tamron opens other avenues....
Assuming weight is not factor to me but good AF speed and sharpness is.
I'm at a loss on which to go for.
nkistrup
nkistrup Senior Member • Posts: 1,700
Re: Nikon 70-200 f4 vs Tamron 70-200 VC
That lens selection sounds awfully familiar.   Bobcat3610 posted a link to a review in:
http://www.dpreview.com/forums/post/51288867
It only hardened me in my resolve to get the 70-200 f4.  But maybe you want to be patient & wait for more reviews?  Tamron's lens is still very new.
 nkistrup's gear list:nkistrup's gear list
Canon PowerShot G12 Olympus XZ-1 Nikon D7100 Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF Nikon AF-S Nikkor 14-24mm f/2.8G ED +4 more
Marvin Doering Senior Member • Posts: 1,599
I bought the Nikon basically for weight.  I traded in my 80-200 2.8.  What a difference to use.  I can actually hand hold it and the VR takes care of my shaky hands.  I've never seen the Tamron but I know it is heavier.  I'm also guessing the Nikon will hold more value in the long run but I don't know that for sure.
MRD
 Marvin Doering's gear list:Marvin Doering's gear list
Olympus XZ-1 Olympus E-620 Olympus E-M1 Olympus M.Zuiko Digital ED 75-300mm 1:4.8-6.7 Panasonic Leica Summilux DG 25mm F1.4 +2 more
fhibbs12 OP Regular Member • Posts: 113
Blah I was hoping to read a better review than that!
Brev00
Brev00 Veteran Member • Posts: 7,572
If 2.8 is not so important to you, then get the Nikon. One other thing in the Tammy's favor is it includes a tripod ring. Getting one for the Nikon will raise the price beyond the Tammy. If using a tripod is important to you.
www.flickr.com/photos/brev00
 Brev00's gear list:Brev00's gear list
Nikon D90 Nikon D7100 Nikon AF Nikkor 50mm f/1.8D Tokina AT-X Pro 12-24mm f/4 DX II Tamron AF 28-300mm F/3.5-6.3 XR Di LD Aspherical (IF) Macro +3 more
XcaliberD800 New Member • Posts: 2
Tamron 70-200f2.8 vc on a Nikon D800
I have just taken delivery of this lens and completed testing today. The copy I have has put in what I can only describe as an astonishing performance in every area. the corner performance is incredible, at a range of 20 ft, 6pt text is visible and clearly readable in each of the four corners, the vignetting is negligable and the autofocus is bang on the money when I get it right and choose the correct mode for the subject, yes the D800 will give you a caning if you get the slightest thing wrong. It is no light weight, its built like a tank but more compact than my Nikon 70-200 f2.8 vr2 and a bit lighter. I also have the 24-70 vr, with that I had to try 3 lenses before I got one I was happy with, the rejects had bad centering problems. From what I can tell, it seems to be a step up from the Nikon VR2 and I would say its very comparable in performance to canon L II glass. One thing I did notice is that the 200mm end seems a bit shorter than 200mm, I wouldn't have noticed except for having the Nikon lens. I would recommend trying this lens but only with a try before buy or return type deal due to the experience I had with the 24-70. I hope this helps a bit.
Vladi Stoimenov
Vladi Stoimenov Regular Member • Posts: 421
 Vladi Stoimenov's gear list:Vladi Stoimenov's gear list
Nikon D90 Nikon D610 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 50mm f/1.4G Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR +5 more
chillils New Member • Posts: 13
Check dxomark. You can compare the measurements they got between the 2.
 chillils's gear list:chillils's gear list
Nikon D810 Nikon AF-S Nikkor 24-70mm f/2.8G ED Tokina AT-X 16-28mm f/2.8 Pro FX Nikon AF-S Nikkor 50mm f/1.8G Tamron SP 70-200mm F/2.8 Di VC USD +1 more
