Metabones Speed Booster for Pentax K lenses?
Started Apr 14, 2013 | Discussions
Ari Aikomus
Veteran MemberPosts: 6,927
Apr 14, 2013
Hi,
Has anyone heard if the Metabones would be planned speedbooster adapter for Pentax K lenses? For example Pentax K--> NEX speedbooster ?
I was forced to purchase Metabones' speedbooster for Contax/Yashica (C/Y) --> NEX adapter , because it was the only way to get my M42 lenses to work with speedbooster. But you can't adapt Pentax K lenses that way.
There are already quite a few of the old lens mount supported, but not Pentax - which I think is a bit odd.
http://www.metabones.com/buy-speed-booster
I also know that Canon FD and Sony Alpha mount are coming later this year...
http://koti.mbnet.fi/tidis/AAikomus.jpg
- Ari Aikomus -
'Why should I feel lonely ? is not our planet in the Milky way?'
BobORama
Senior MemberPosts: 2,001Gear list
Re: Metabones Speed Booster for Pentax K lenses?
In reply to Ari Aikomus, Apr 15, 2013
WHY would you want to use a product that reduces contrast and increases CA, when Instagram is free?
 BobORama's gear list:BobORama's gear list
Pentax K-5 Sigma 10mm F2.8 EX DC HSM Diagonal Fisheye Pentax smc DA 18-55mm F3.5-5.6 AL WR Samyang 14mm F2.8 IF ED MC Aspherical +8 more
MightyMike
Forum ProPosts: 33,163
In reply to BobORama, Apr 15, 2013
Mathematically it should actually increase the contrast, as for the CA that depends on the parent lens and speedbooster combination but in many cases it could reduce the CA
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/search/photo.search?sort_order=views%20DESC&first_this_page=0&page_limit=180&&emailsearch=mighty_mike88%40hotmail.com&thumbnails=
Ayoh
Regular MemberPosts: 187Gear list
Ari Aikomus wrote:
Hi,
- Ari Aikomus -
Why not ask the designer, Brian Caldwell, himself:
http://www.dpreview.com/members/5764986886
If you find something out please report back.
Ari Aikomus
No speedbooster for Pentax lenses ;(...
In reply to Ayoh, Apr 15, 2013
Ayoh wrote:
Ari Aikomus wrote:
Hi,
- Ari Aikomus -
I wrote Metabones to enquire about a Pentax K to NEX adapter and this is the response:
Sorry! We have not planning to make a Pentax (speed booster)…..
Thank you!
Alex
GBI Ltd
Do not get them. There's a lot of Pentax K FF lenses on the planet...
Ari
- Ari Aikomus -
Ayoh
Re: No speedbooster for Pentax lenses ;(...
Ari Aikomus wrote:
Ayoh wrote:
Ari Aikomus wrote:
Hi,
- Ari Aikomus -
Thank you!
Alex
GBI Ltd
Ari
- Ari Aikomus -
Could be due to a technical limitation due to potential interference from the protruding aperture lever in K lenses. Nikon lenses have a similar lever and a nikon adapter is not listed on the webpage either.
An EF speedbooster with a EF-K adapter should work anyway, just temporarily remove the aperture lever if there is interference (the lever can be unscrewed on most pentax lenses).
Ayoh
Ayoh wrote:
Ari Aikomus wrote:
Ayoh wrote:
Ari Aikomus wrote:
Hi,
- Ari Aikomus -
Thank you!
Alex
GBI Ltd
Ari
- Ari Aikomus -
Actually having just looked at some photos of the adapter it looks like the lens elements are sufficiently well recessed to not interfere with the aperture lever. They already even have designed an adapter (a contarex mount) which has an aperture control ring which would be required for Pentax and Nikon lenses without aperture rings. They could just adapt that. Not sure why Pentax and Nikon are not available.
Ari Aikomus
Nikon speedbooster
Ayoh wrote:
Ayoh wrote:
Ari Aikomus wrote:
Ayoh wrote:
Ari Aikomus wrote:
Hi,
- Ari Aikomus -
Thank you!
Alex
GBI Ltd
Ari
- Ari Aikomus -
Nikon->NEX (and fuji) speedbooster will be coming.
http://www.dpreview.com/forums/post/51281348
- Ari Aikomus -
Ayoh
Re: Nikon speedbooster
Ari Aikomus wrote:
Ayoh wrote:
Ayoh wrote:
Ari Aikomus wrote:
Ayoh wrote:
Ari Aikomus wrote:
Hi,
- Ari Aikomus -
Thank you!
Alex
GBI Ltd
Ari
- Ari Aikomus -
- Ari Aikomus -
No idea then. I would wager that there are more Pentax M42 and K mount available than ALPA, Contarex or Contax lenses combined, so you would think there is a reasonable business case to make a Pentax adapter.
Ari Aikomus
- Ari Aikomus -
Indeed. This observation makes me think that it would be something more "behind lack of Pentax K lens support" - not technical reason!
Anyway - Could C/Y mount modified to accept Pentax K lenses? Kind of DIY work...Flange distance is same with Pentax K and C/Y.
Ari
- Ari Aikomus -
Ari Aikomus
Speedbooster works well.
Actually it works surprisingly well:
http://www.eoshd.com/content/9485/metabones-speed-booster-adapter-full-review
at least 28-135mm range, it is designed for shorter than 200mm FF lenses.
- Ari Aikomus -
Ari Aikomus
Maybe Mitakon then...
It's very hard to understand why MetaBones is not interested Pentax K lens speedbooster...
But maybe Mitakon can understand better this maladministration, and to make such an adapter.
http://www.thephoblographer.com/2013/03/15/mitakon-to-do-pretty-much-what-metabones-did-with-the-speed-booster/
- Ari Aikomus -
viking79
Forum ProPosts: 14,102Gear list
Because it allows you to use an APS-C camera effectively as a full frame camera.  It would be nice to be able to take that classic 50mm f/1.4 lens for Full Frame, and use it on APS-C and get effectively a 35mm f/0.93 lens as used on APS-C.
Sure, like a teleconverter, a telecompressor has issues.  You are using the entire full frame image circle now, and the telecompressor introduces some of its own aberrations, like extra distortion and some edge CA according to their graphs at metabones, but it also increases central resolution.
I suppose this question came up because it would allow using the FA 31, 43, and 77mm as full frame lenses as they were intended.
Eric
I never saw an ugly thing in my life: for let the form of an object
be what it may - light, shade, and perspective will always make it
beautiful. - John Constable (quote)
See my Blog at: http://www.erphotoreview.com/ (bi-weekly)
Flickr Photostream: http://www.flickr.com/photos/28177041@N03/ (updated daily)
Sony Alpha 7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
Ari Aikomus
In reply to viking79, Apr 15, 2013
viking79 wrote:I suppose this question came up because it would allow using the FA 31, 43, and 77mm as full frame lenses as they were intended.
Indeed. And many other fine Pentax K lenses. I have seen a number of samples, and IQ have been pretty good.
So, I bought C/Y->NEX adapter. At least I can use my m42 Super Takumars as intended...And of course C/Y lenses, like Carl Zeiss gems.
But Pentax K speedbooster would be really necessary - would sell well too (even manual version). Once we do not even have the proper K-mount FF DSLR!
Ari
Eric
- Ari Aikomus -
BobORama
Re: Speedbooster works well.
In reply to Ari Aikomus, Apr 16, 2013
When shooting video, with its astonishing 2MP stills, most of the optical gack introduced by the Metabones FR is concealed.   For video work, it may be passible.
The example stills from DRP's review show significant CA, some edge softness, some loss of contrast.   And of course any increase in real aperture will come with a decrease in contrast.   Look at the DPR stills.   Its pretty telling.
MightyMike
In reply to BobORama, Apr 16, 2013
You are mocking an adapter designed by one of the best optical designers in the world "Brian Caldwell", pretty much because you don't seem understand the concept and why adding glass can actually improve image quality. Brian Caldwell was the designer of this lens too...
https://www.lensrentals.com/rent/nikon/lenses/specialty/coastal-optics-uv-vis-ir-60mm-macro-for-nikon
Here is a very thorough review
http://www.lensrentals.com/blog/2013/01/metabones-magic
It clearly shows resolution increase with use of the adapter, in the center and average and the only drop is in the corners however such a drop is typical if you're using the whole image circle instead of the center portion.
As with any adapter (teleconverter or the speed booster) the overall quality depends on the combination of the parent lens and adapter, the best of both worlds might not give you the best overall result.
Mike from Canada
KentG
Veteran MemberPosts: 4,199Gear list
In reply to Ayoh, Apr 16, 2013
You are missing the entire point of the adapter. There are less Pentax users on the planet than Canon and Nikon by a large margin. Its not the number of lenses available but the number of users available to buy it. They probably did a demographic study pinpointing how many NEX users had both a NEX and a DSLR system and which one. Also what kind of lenses NEX owners would like to be able to mount. And I am betting that in Europe Contax, Zeiss and Alpa were on the radar due the the high overall quality of their lenses (I was an Alpa shooter once upon a time).
They are not looking to sell these to people who would go out and buy a certain brand of lens to mount, but instead to people who already have the brand of lens they want to mount.
Kent Gittings
 KentG's gear list:KentG's gear list
Pentax K-5 II Pentax K-5 IIs Pentax K-S1 Sigma 50-150mm F2.8 EX DC APO OS HSM Sigma 18-250mm F3.5-6.3 DC Macro OS HSM +1 more
ET2
ET2
Veteran MemberPosts: 3,884Gear list
In reply to KentG, Apr 16, 2013
Besides, the  Nikon version should be able to use Pentax lenses anyway with K mount to F mount adapter..
http://www.amazon.com/Fotodiox-Mount-Adapter-Pentax-Camera/dp/B003Y31A2W
Ari Aikomus
No, NO and no! yes, yes, YES!
In reply to ET2, Apr 16, 2013
You both are missing the point.
ET2...This Pentax-Nikon adapter use correction glass. Not a good thing - at all, especially with speedbooster!
KentG...metabones already planning Canon FD and Minolta MD lens support - both are dead systems! Pentax k system is still alive!
You said that "high overall quality" of Alpa, Contarex, C/Y, Leica R lenses would be some kind of reason why they offer speedbooster for these lenses over Pentax K... I say no
Pentax K is still alive mount, Pentax has some very HQ fullframe lenses and Pentax does not have its own FF DSLR - I would say that there were the three big YES why Metabones should produce speedbooster for Pentax K lenses.
Ari
- Ari Aikomus -
Tom Caldwell
Forum ProPosts: 24,406
Ayoh wrote:
Ari Aikomus wrote:
Ayoh wrote:
Ayoh wrote:
Ari Aikomus wrote:
Ayoh wrote:
Ari Aikomus wrote:
Hi,
- Ari Aikomus -
Thank you!
Alex
GBI Ltd
Ari
- Ari Aikomus -
- Ari Aikomus -
Dumb M42 to EF adapter works fine on the Speed Booster.
Tom Caldwell
