Canon 600EX-RT and Yongnuo YN622C wireless trigger
Started Apr 14, 2013 | Questions
plautoq Regular Member • Posts: 118
Hi there...
I do believe this question has been asked, but I could not find the anwer anywhere : can we wirelessly trigger a Canon 600EX-RT using a Yongnuo YN622C (without attaching the YN622C to the 600EX-RT - the single unit would be attached to the camera only) ? I believe if I attach a second YN622C to the 600EX-RT it would be possible. Any input would be greatly appreciated. Cheers.
 plautoq's gear list:plautoq's gear list
Canon EOS 60D Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 24-70mm f/2.8L USM Canon EF 70-200mm f/2.8L USM Adobe Photoshop Lightroom 4
ScratchDisk Veteran Member • Posts: 3,225
Re: Canon 600EX-RT and Yongnuo YN622C wireless trigger
You are correct on both points.
Canon's RT radio tech - so far - is not compatible with any other radio based system. And I suspect Canon like it that way.
If you are going the Yn622C route, then it makes sense to attach a Speedlite, that is cheaper than Canon's 600Ex-RT, but yet fully compatible with those triggers. Yn publish a list.
plautoq OP Regular Member • Posts: 118
Thanks. Appreciate your feedback. Cheers.
