Hard drive dying?
Started Apr 14, 2013 | Discussions
HDProman Contributing Member • Posts: 891
Hard drive dying?
I generally boot my Windows 7 Professional x64 computer once every morning.
During the last three boots Windows runs checkdisk. So far upon completion Windows starts.
I am afraid this is an indication of an eminent hard drive failure, would you agree?
I have a 1TB internal drive that is empty and I am wondering if I should clone my C: drive to this internal drive and set it to be my system boot drive. The current C: drive is 500MB.
If this is a good plan, how should I go about making the swap. I have never cloned a drive or changed the order of boot drives. I am able to follow instructions and would be willing to purchase any cloning software as it is probably a good idea to have a bootable copy of my system drive.
What should I do?
Floyd...
Newbie, having fun.
filibuster
filibuster Veteran Member • Posts: 3,231
Re: Hard drive dying?
Wonderful stuff computers these days.  After a few ‘funny’ performance issues, mine actually messaged me on screen that my HDD was about to fail!
My choice was to buy a Seagate Momentus hybrid drive, and cloned to that using the free Macrium Reflect software. It all went like a dream even though I cannot remember exactly my step by step procedure to assist you. What I can say is that the hybrid speeded up my aging HP HDX18 1103EA with Win 7, and it seems to be performing better now that the day I bought it a few years ago. So you may wish to consider a hybrid rather than a standard drive, or the expense of SSD.
Quote hhgttg: Life is wasted on the living.
filibuster (Bromsgrove, Worcestershire, UK)
http://picasaweb.google.com/scenic.filibuster
HDProman OP Contributing Member • Posts: 891
I have installed Western Digital's Acronis True Image.
I cloned my C: drive to an empty internal drive, which is now Windows7 (G:).
Should I test my clone by booting from the (G:) drive? How should I set my bios to boot from this drive?
If I boot from the (G:) then how do I make my original boot drive again be the boot drive?
If my understanding of this whole process needs clarification, please instruct me.
Thank, Floyd...
Newbie, having fun.
Bill Lambert Regular Member • Posts: 475
When Installed,It should reboot as C.
digitalshooter
digitalshooter Forum Pro • Posts: 19,604
Have you ran the manufactures utility to check the drive?
A check disk at start up could be anything especially if you shutdown incorrectly.
Thanks,
Digitalshooter
PS: all posts are just my opinion!
 digitalshooter's gear list:digitalshooter's gear list
Sony Alpha DSLR-A700 Canon Pixma Pro9000 Mark II
Chris Noble
Chris Noble Senior Member • Posts: 1,802
Go easy on your HDD
Don't turn off your computer. Ever. It has sleep modes that bring the power dissipation down to a trickle and stop the HDD from spinning. It likes to check up on itself when you are idle. It likes to use all of its memory for frequently-accessed bits of software. You should be running an automated backup every night. And your HDD hates to have to reload all those routines every morning. I don't blame it for quitting on you. I never turn off my computers and I have never had an HDD failure.
 Chris Noble's gear list:Chris Noble's gear list
Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH +4 more
Update
I have cloned my 500mb C: drive to a unused 1tb internal drive and set this a my boot drive.
Completed several reboots, all on the day of the change over and no checkdisk.
Today, one day later, and upon first boot, checkdisk is running again.
The original C: drive is connected to a different computer and being scanned by SpinRite. So far no problems.
What could be causing checkdisk to run only once a day upon first boot?
Thanks, Floyd...
Newbie, having fun.
mfait Contributing Member • Posts: 653
HDProman wrote:
Update
Thanks, Floyd...
Newbie, having fun.
Sounds like checkdisk is scheduled to run on first boot of each day or something like that?
Google how to check for this and disable if is what is happening.
If this is what is happening then this this would have been cloned to the new driver as you are seeing.
 mfait's gear list:mfait's gear list
Canon PowerShot S100 Canon EOS 450D
Opened Administrator: Command Prompt
Ran
C:\Windows\system32>chkntfs c:
Returned
The type of the file system is NTFS.
C: is not dirty.
So, checkdisk is not scheduled to automatically run on startup, something else is causing checkdisk to run.
Newbie, having fun.
digitalshooter
you have errors in your file system and windows is trying to deal with it? (nt)
Thanks,
Digitalshooter
Ran
Returned
C: is not dirty.
Newbie, having fun.
Check here:
Start>Run> type in "msconfig" (no quotation marks). In dialog box, select
Startup tab. If Chkdisk is in the list, uncheck it.
greenmartini Regular Member • Posts: 276
Make sure you have everything backed up while it is still working.
Run a s.m.a.r.t test on the drive and see.
drj3 Veteran Member • Posts: 3,943
My PC started doing this also.  You should see the following Microsoft Support link concerning security update 2823324 .
http://support.microsoft.com/kb/2839011
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD +6 more
digitalshooter
Thanks for posting that link
I had it installed with no issues, but as per their recommendation I removed it.
Thanks,
Digitalshooter
