Yongnuo 622-C and 550EX (MkI)
Started Apr 14, 2013 | Discussions
WalterK Senior Member • Posts: 2,626
I've been using my 5DMkIII and 550EX (Not 550EX II) with Yongnuo 603C triggers, with everything on manual, and it works fine except I can't do HSS.  In fact the fastest shutter speed I can use is 1/160th with this setup, even if the flash is set for HSS.
I'm thinking of buying the YN 622-C, which I know will do ETTL with the EXII flashes.  I don't care about being able to use the on-camera controls for flash either way.  I'm mainly interested in having the 550EX set for HSS and being able to use shutter speeds of 1/200 and more with the 5Diii.  Would the YN 622-C's work for me using the 550EX off camera?
Walter K
Canon EOS 5D Canon EOS 5D Mark III
SeedyBee Regular Member • Posts: 150
Re: Yongnuo 622-C and 550EX (MkI)
Yes, the YN-622C will work fine. The limitation is that Flash mode, Zoom and Manual levels must be set on-flash.
Sync mode, E-TTL with FEC and Ratio can be handled from your camera.
More info in The Other YN-622C User Guide, esp. pp 4-5.
https://docs.google.com/open?id=0B77OmmGIg0gMVFpqNkpBYXBHajA
Clive
 SeedyBee's gear list:SeedyBee's gear list
Canon EOS 50D
WalterK OP Senior Member • Posts: 2,626
Thanks for the info.  The alternate user's guide is wonderful!  I'm going to buy the 622's.
Walter K
