Are new lenses getting too: heavy, wide and long?
Started Apr 13, 2013 | Discussions
Cytokine Contributing Member • Posts: 661
The design of modern lenses while in some aspects are getting better, seem to be growing every year and may soon outpace our desire / ability to carry such large objects. Sigma and other third party lenses can be just as bad. While cameras are shrinking lenses seem to be on steroids.
There appears to be growing popularity for the older lighter screwdriver lenses 20, 24, 50, etc., new wide angle lenses are so long they look like zooms, while high quality zooms are beginning to look like telescopes. Any thoughts?
slidewilson Regular Member • Posts: 153
Re: Are new lenses getting too: heavy, wide and long?
I would say that recent Nikon releases, particularly the 28mm 1.8G, 70-200mm F4 and the new 18-35 are all taking a step in the direction of lightening the lens. Can't speak for length but I'm happy to see the weight reduction..
Cytokine OP Contributing Member • Posts: 661
The 28 has no previous version I can see, except the 1.4D which is metal and heavier, the 18-35 has only grown fractionally, and the 70-200 f4 is lighter than the first 80-200 2.8 ED. as you say a move in the right direction, and nearly half the weight of the best 70-200.
http://www.photosynthesis.co.nz/nikon/lenses.html
paulski66
paulski66 Senior Member • Posts: 2,754
The 50s are bigger but lighter than their AF-D counterparts.
There are no equivalent 20 & 24 lenses. The new 24 is a 1.4 and a completely different animal.
But I agree with slidewilson that, overall, these lenses seem to be getting light, not heavier. Yes, the most expensive pro-level optics are still heavy, but the mid-level zooms seem lighter, as do the primes.
 paulski66's gear list:paulski66's gear list
Panasonic Lumix DMC-LX5 Nikon D750 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Nikon AF-S Nikkor 50mm f/1.8G +2 more
Tom Ames Contributing Member • Posts: 945
the 85 1.8 is lighter than D version
the 24-70 is lighter than 28-70
18-35 almost same as previous version
70-200 VRII lighter than previous afs versions (80-200 and 70-200VR)
50mm 1.4 heavier than D version
50mm 1.8 heavier
New 80-400 heavier due to VR
70-200 F4 much lighter than 70-200 2.8
I'll say it's even steven - some lighter, some heavier.
VR on many of the new lenses does it share to bring up the weight.
 Tom Ames's gear list:Tom Ames's gear list
Sony Alpha 7R II Nikon AF-S Nikkor 58mm f/1.4G Sony FE 28mm F2 Sony FE 35mm F1.4 Sony FE 24-240mm F3.5-6.3 OSS +1 more
Michael Benveniste
Michael Benveniste Senior Member • Posts: 2,438
I haven't seen any such "growing popularity" myself.  According to the serial numbers shown at Roland Vink's site, for example, Nikon's already sold more 14-24mm f/2.8's, than they sold 20mm f/2.8D's even though the cheaper, lighter lens has been on the market for about 3 times as long.
I miss the days when I used to be nostalgic.
 Michael Benveniste's gear list:Michael Benveniste's gear list
Nikon Coolpix 995 Nikon D200 Nikon 1 V1 Nikon D800 Nikon AF-S DX Nikkor 18-70mm f/3.5-4.5G ED-IF +33 more
It is difficult to compare a zoom with these little primes, which are lovely for street photography and compactness, I was looking at the prices on Ebay uk, also I bought a 50mm f1.4D from a dealer, whos's prices seem to keep going up for the same lens. It could just reflect the number of new people moving to Nikon for their new higher end cameras, that all have screwdriver ability.
John
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 12,567
If there is a growing popularity, it must be because the old lenses are selling cheaper on the used market than the new ones.
The lenses I've seen change (AF to G versions, basically), have mostly changed from using more metal to using more plastic.  Weight so far seems about the same, even though some of the lenses I've updated have gained VR.   I'd say it's basically a wash between saving weight from plastics and adding weight with VR.
No doubt that the lenses with VR and AF-S are physically bigger in diameter than their older counterparts.
I'm basing that on my 85F1.8AF versus 85F1.8g, my 50F1.8 AF and 50F1.4g (I know, 1.4 is bigger), and my 80-400AF versus 80-400g.    My 70-200F2.8 is about as heavy as my 80-200 push-pull, but actually longer and skinnier.   Both are heavy, and I've not noticed which feels heavier.
Craig
www.cjcphoto.net
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +35 more
gatorowl
gatorowl Senior Member • Posts: 1,035
Craig
www.cjcphoto.net
One of the things that makes older lenses attractive is the aperture ring.  For videography or using the lens with an adapter on a mirrorless camera, being able to manually set/change the aperture is huge.
I do think that the lenses are getting bigger.  Perhaps it's due to the more demanding digital photography, which requires more glass and greater precision to produce stellar results.
I have both the 50 D 1.4 and 85 D 1.8.  I never particularly liked the 50, but the 85 was quite nice.  I have since acquired both the 50 G 1.8 and 85 G 1.4.  The 50 G is significantly larger than than the D and, I believe, the 85 G is a bit larger than the D. However, both G lenses are noticeably lighter presumably due to the switch from metal to plastics.  Both G lenses produce superior results to their D counterparts.  I'm happy with the tradeoffs.
I have acquired a couple of 70-210 manual focus lenses. These lenses are reasonably sharp and quite compact especially compared to current 70-200 lenses.  However, these old lenses just do not compete with modern nikkors.
 gatorowl's gear list:gatorowl's gear list
Canon EOS Rebel SL1 Nikon D7200 Nikon D500 Canon EOS 80D Canon EF 85mm f/1.2L II USM +12 more
Leonard Shepherd
Leonard Shepherd Forum Pro • Posts: 10,602
Re: They are changing
Nikon lens designs and changing.
Usually in lens motors and VR take up extra space so the lens has to be a bit to a lot bigger. VR and in lens motors often weigh more than the gears used in older generation body driven focusing lenses.
Digital sensors still do not handle light reaching them at a low angle as well as film, and digital is more prone to corner vignetting and CA with many older lenses than film was. Several of these issues are put at least part right with modern in camera and post processing software.
In the more recent lenses these issues are reduced with tele-centric lens designs which for wider angles generally have a larger rear element further from the sensor, combined with larger diameter front elements for the focal length and maximum aperture than was common in the film era. This adds more size to new generation lenses.
Optical moulded asymmetrical lens elements are often lighter and enable a specific optical quality to be achieved with fewer lens elements. In addition the non-glass parts of lenses are now often made with lighter materials then in the film era.
Because of all this although modern lenses tend to be larger, though they are not necessarily heavier and sometimes they are lighter.
Leonard Shepherd
Many problems turn out to be a lack of intimate knowledge of complex modern camera equipment.
Nikon Coolpix P7700 Nikon D800 Nikon D7100 Nikon D810 Nikon D750 +24 more
windsprite
windsprite Senior Member • Posts: 2,304
I believe the VRII is heavier than the VR.
Slower lens, doesn't count.  :-]
Julie
 windsprite's gear list:windsprite's gear list
Fujifilm FinePix F100fd Fujifilm FinePix F550 EXR Panasonic Lumix DMC-FZ200 Nikon D2H Nikon D300 +39 more
joneil Regular Member • Posts: 171
Overall I think the original poster has a good point.  I love my nikkor 24-70 zoom, it is simply one of the finest lenses I have ever used.
But it is big and heavy, and if like me your are walking for two or three hours, it gets even heavier somehow.
I find myself now walking around with a small, manual focus 24mm nikkor, and carrying around another small prime in my pocket much of the time.   I still use my 24-70mm, and these other new lenses are nice, but yes, they do get heavy after a while.
