d7100, the smaller birds in flight.
Started Apr 12, 2013 | Discussions
engbert Senior Member • Posts: 2,504
Many DSLRs do a pretty good job with gulls, terns and pelicans.  The d7100, here with the new 80-400 af-s,  did a passable job with these Tree Swallows.  At least they are identifiable.
This one is a Barn Swallow
www.pbase.com/bertramm
pbase & dpreview supporter
 engbert's gear list:engbert's gear list
Nikon D810 Nikon D7200 Nikon D500 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S Nikkor 50mm f/1.8G +5 more
Nikon D7100
Brandon birder Veteran Member • Posts: 3,900
Re: d7100, the smaller birds in flight.
Well caught swallows and excellent news for me , as just added both camera and lens to my set.
Rhinofly New Member • Posts: 10
Nice job catching those little buggers.
Like you I have been out trying to take small bird in flight photos with my new D7100. I have it paired with the 70-300 af-s VR.
I have found that the 51 point autofocus seems to work pretty well for birds on uniform backgrounds, like blue sky. But it seems lousy if you have backgrounds with structure. In that case I have been dropping back to single servo/single point.  Did you play around with the different AF settings on these birds?
Also, I am seeing lots of noise in the sky at 100% crop, even down at ISO 320. I am shooting raw and then doing noise reduction after processing so it ends up looking pretty clean. My main drawback is the softness of my lens at 300mm and f5.6.
I am seeing quite a bit of noise in your photos as well, granted at ISO 1000. Did your photos have any noise reduction?
engbert OP Senior Member • Posts: 2,504
These are very small crops, and I think that is the reason you are seeing noise even after I applied some luma NR in Lightroom.  It is very fine grained noise, which probably would not show on a print.
