Tripod for Nikon 400mm f2.8
Started Apr 12, 2013 | Discussions
jestech
New MemberPosts: 5
Apr 12, 2013
I just bought a new Nikon 400mm lens and had a question regarding tripods.
I'm looking to purchase a tripod that I can travel with and pack into the woods.  Given the size of this monster lens, is it important to stick with a 3 section tripod?  A 4 section would be better for travel, but stability is critical with this lens.
I know I need a gimbal head as well.  Anyone with this lens have a recommendation?  Everything I've been reading points toward the Wimberley.
I'm finding that I should've calculated about $2000 more in accessories when I purchased this lens.
Hank3152
Forum ProPosts: 13,362Gear list
Re: Tripod for Nikon 400mm f2.8
In reply to jestech, Apr 12, 2013
You've invested in a quality lens so I wouldn't scrimp with inferior tripods. Look into the Gitzo 3 or 5 series for utmost stability. Check their site for the appropriate size and series......you won't be disappointed.
http://www.gitzo.us/?gclid=CN3W_4PrxbYCFYhAMgod2kQARw
If your concerned with portability, the gimbal head is far from convenient but you might consider the RRS BH-55 ball head to be a better substitute when hiking.
 Hank3152's gear list:Hank3152's gear list
Canon PowerShot S95 Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EF 300mm f/4.0L IS USM Canon EF 100mm f/2.8L Macro IS USM +5 more
IainD
Senior MemberPosts: 1,343Gear list
In reply to Hank3152, Apr 16, 2013
Definitely Gitzo! 3 or 5 section will hold it I think. You don't need to extend all the sections.
IainD
hotdog321
Forum ProPosts: 14,610Gear list
In reply to IainD, Apr 16, 2013
I vote for the Gitzo as well. Not sure a gimbal head is absolutely necessary--a solid normal head will work, too. Of course, also factor in a quick release plate.
Also, if you are hiking and shooting wildlife, a good Gitzo monopod is another option. It works well when shooting sports, and it sounds like you have quite a load of gear already!
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark III Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM Canon EF 16-35mm f/4L IS USM Canon EF 11-24mm F4L +1 more
IainD
In reply to hotdog321, Apr 16, 2013
Arcatec long lens head? Light and strong. Cheaper than Wimberley
IainD
jestech
jestech OP
New MemberPosts: 5
In reply to jestech, Apr 22, 2013
Thanks everyone for the suggestions!
Looks like I'll have to find myself a Gitzo.
hotdog321
Yep. Costs a fortune, but you only have to buy it once!
