Is there any Landscape photographer using a SD1 Merrill in the house?
Started Apr 12, 2013 | Discussions
SandyF Forum Pro • Posts: 14,937
Re: Not me
I really had to laugh.... you just couldn't resist that reply, I imagine.
All our best to you, I hope spring finally arrives to you up north too.
Best regards, Sandy
http://www.pbase.com/sandyfleischman (archival)
http://www.flickr.com/photos/sandyfleischmann (current)
 SandyF's gear list:SandyF's gear list
Sigma DP1 Sigma DP2 Sigma DP2 Merrill Sigma DP3 Merrill Sigma SD14 +6 more
vbd70
vbd70 OP Veteran Member • Posts: 5,113
Re: Not me
Laurence Matson wrote:
I tend to use it out of doors.
Laurence
laurence at appledore-farm dot com
"The fact of being reported multiplies the apparent extent of any deplorable development by five- to tenfold" (or any figure the reader would care to supply).
Barbara Tuchman, A Distant Mirror
http://www.pbase.com/lmatson
http://www.pbase.com/sigmadslr
http://www.howardmyerslaw.com
...the assist was irresistible, I guess Now, I'd love to hear from you on the matter. Best,
Vieri
equipment in profile
Vieri Bottazzini Fine Art Photography
http://www.vieribottazzini.com
My Newsletter:
http://eepurl.com/s1Sjb
portfolios:
http://www.madshutter.com
my blog
http://madshutter.blogspot.com
Facebook galleries:
https://www.facebook.com/vierimadshutter
 vbd70's gear list:vbd70's gear list
Panasonic Lumix DMC-LX100 Leica M-Monochrom Pentax K-3 Pentax 645Z
Laurence Matson
Laurence Matson Forum Pro • Posts: 11,594
Out of doors
The SD1 is as good as it gets in my opinion, which I am sure is not shared by everyone.
- It is more flexible than the DPxM cameras, because of the lens choices. Especially, if you want to use longer or ultra-wide lenses, the SD1 is preferable.
- It is faster than the DPxM cameras, especially for matrix shooting. You can gauge the overlaps better in the viewfinder (using the focus points) and work faster across a sweep, when there is a pretty high wind, as in this one (see the leaves on the left):
http://www.pbase.com/lmatson/image/149222540
- It is heavier and has a viewfinder. This makes it easier to hold steady without a tripod. Combined with the good OS lenses, this makes it easier to use in the field under certain conditions.
The downsides are:
- Weight and bulk
- Non-matched lenses
Here are some early landscapes:
http://www.pbase.com/lmatson/image/146438872
http://www.pbase.com/lmatson/image/140710299
http://www.pbase.com/lmatson/image/142407840
And one weedscape:
http://www.pbase.com/lmatson/image/142424188
Laurence
TRIODEROB Senior Member • Posts: 1,718
Re: Out of doors
wide angle sd1
Re: Out of doors
full size -have fun
Re: Out of doors
you want wide angle ?
this is wide
full size image:
vbd70
Re: Out of doors
The downsides are:
- Weight and bulk
And one weedscape:
Laurence
Hello Laurence,
thank you for sharing your impressions and your pictures, I appreciate it. Well, of course the SD1 is better than the DP Merrill for Ultra-WA and tele use, since the DP Merrills aren't of any use under 28mm and above 75mm which is exactly why I am seriously thinking about moving to a Foveon-based DSLR. to get the same look in a more flexible package.
Do you have anything shot with a WA, besides the great 70-200 samples you shared? That would be very much appreciated indeed. All the best, and thanks again
Vieri
My Newsletter:
portfolios:
my blog
Facebook galleries:
vbd70
Re: Out of doors
TRIODEROB wrote:
full size -have fun
Thank you very much! Looks pretty sharp up into the corners, however it shows a bit of CA on high-constrast areas. Is this before or after CA-removal in SPP?
Thanks, this was really helpful! Best,
Vieri
My Newsletter:
portfolios:
my blog
Facebook galleries:
vbd70
Re: Out of doors
this is wide
full size image:
Wow, this IS wide! Looks pretty impressive to me, sharpness is great except perhaps the far wide corners (especially lower left), but it is incredibly impressive nevertheless!
Thank you very much for sharing, best,
Vieri
My Newsletter:
portfolios:
my blog
Facebook galleries:
Park70 Regular Member • Posts: 192
Re: Is there any Landscape photographer using a SD1 Merrill in the house?
Another Sigma SD1 with 8-16 lens at 8mm.
Sigma 8-16 lens at 8 mm
And one with the new 50-500 mm OS.
At 430 mm crop factor
vbd70
Thank you very much for these! I am starting to think that the 8-16 can really deliver, despite some of the negative comments that I found around the net.
Thanks again for sharing, best
Vieri
My Newsletter:
portfolios:
my blog
Facebook galleries:
Kendall Helmstetter Gelner MOD Forum Pro • Posts: 19,400
vbd70 wrote:
Hello Kendall,
thank you for the samples. I see what you mean. What it is quite impressive is how well controlled is CA in the second example, did you use SPP's CA controls?
I don't believe I have on that one, generally I've only used the CA controls with DP-1M images.
Good to hear that the 8-16m is great at 10mm. That would be enough for me (of course, if a lens goes to 8 one shall expect it to be good there as well, but this is another story).
Thank you very much again for your help, best
Sure, I always think it better to show reference images because two people can interpret terms quite differently.
 Kendall Helmstetter Gelner's gear list:Kendall Helmstetter Gelner's gear list
Sigma 70-200mm F2.8 EX DG OS HSM Sigma 85mm F1.4 EX DG HSM Sigma 1.4x EX DG Tele Converter Sigma 24-70mm F2.8 EX DG HSM Sigma 8-16mm F4.5-5.6 DC HSM +4 more
detectorman
detectorman Regular Member • Posts: 135
I've used my SD1 to photograph "in the house".
SD1M with 8-16 mm lens -- in the house (condo actually)
This was taken with hand-held with natural light only.
vbd70
Kendall Helmstetter Gelner wrote:
vbd70 wrote:
Hello Kendall,
Wow, then it's very impressive indeed. I refer to the top grids in the corner, the ones you aren't happy as far as sharpness goes. CA control is pretty amazing there, I have seen lenses of higher repute faring much worse in similar scenes
As they say, a picture is worth a thousand words - and is less prone to misinterpretation, too!
Thanks again, best
Vieri
My Newsletter:
portfolios:
my blog
Facebook galleries:
vbd70
You are the second funny guy in the thread, but your image is useful all the same, thank you - you can see the distortion in a real world situation, it seems quite acceptable to me and easily correctable.
Best,
Vieri
My Newsletter:
portfolios:
my blog
Facebook galleries:
L Tippett Senior Member • Posts: 1,933
vbd70 wrote:
Hello Foveon lovers,
since using the DP1M, DP2M and DP3M the Foveon bug started working its way in my head and I have been considering adding a SD1 Merrill with some lenses to my arsenal. As you can see from my website(s), i do Landscape / Fine Art mostly and some architectural / portrait / editorial as well. At the moment I am Nikon-based, using a D800E & D3x with a lot of Nikon glass (14-24, 24 f1.4, 35 f1.4, 50 f1.4, 85 f1.4, 135 f2, 70-200, 24-45-85 PC-E, etc); however, I am really fond of the Foveon results and would love to have a DSLR with it in it.
For my type of shooting, however, my problem is not with the camera but with the lenses.
So, any Landscape / Fine Art guys in the house that can share their impressions of the SD1 and what glass do they use with it, especially on the WA side of things?
I am thinking 8-16, 35 f1.4, 50 f2.8 (the 50 f1.4 seems a bit soft / have field curvature, for landscape), 85 f1.4 or 70 f2.8 (same logic than with the 50 mm, the 70 seems a bit more solid for landscape), 150 f2.8 macro.
Is there any users of any of this camera / lenses combo that care to share their thoughts?
Any help is much appreciated, thank you in advance.
Best,
Vieri
My Newsletter:
portfolios:
my blog
Facebook galleries:
Hi Vieri,
I hope you purchase an SD1M and a set of Lenses to complement to camera in the near future as i would love to see some of your images taken with this combination.
I use the SD1M and have a selection of lenses.
Personally i have had very pleasing results with the 20mm f1.8 which i really like on the SD1M.
The 8-16mm DC is also very sharp pretty well across the frame but for me it is a bit of a pain as it requires the Lucroit Filter holder which is an expense.
Also similar in requiring the filter holder is the 12-24mm which i borrowed from a friend and i was blown away with the sharpness on the SD1M (very nice!)
The 10-20mm f3.5 which i have can give good results although i have had mixed results regarding sharpness but the focal length is lovely for most of my work and i find the lens gives good contrast.
Slightly longer but a very worthy contender i have found the newest 24-70EX HSM to be a very good performer with the SD1M. A reasonably fast lens and sharp with again good contrast.
I know most of these lenses have already been mentioned on this post but then that must count for something i guess!
Hope my small contribution is a little bit of a help.
Look forward in seeing some great images from you my friend.
Kind regards Lea.
vbd70
L Tippett wrote:
Hi Vieri,
Kind regards Lea.
Hello Lea,
thank you very much for your long and detailed reply, I really appreciate it, as well as your kind words about my photography.
I surely hope I will have soon a SD1 in my hands, and I hope to be able to put it to a good use.
Let me start by saying that your experience with all the WA for the SD1 is impressive; it is difficult enough to find SD1 users, let alone people that tried pretty much all the WA Sigma has to offer.
I am glad to hear that the 8-16 is good and sharp all over the frame; I think I am leaning towards this lens, in the end it just seems to be the best option. I have the Lee SW 150 for the Nikon 14-24, which I think I can be able to adjust to fit the 8-16 with the Lee adapter and a 77mm filter holder with some little extra modifications... A bit of a pain, as you say, but doable. Once I do that, I will use the filters for all the other lens, too, so (even if they are really huge!) is not too big a deal - I'd carry a filter set (Singh-Ray, squares) anyway, so a few cm more aren't going to be a problem. The adapter is big though.
I am surprised to hear about the 12-24, I didn't think it would be sharp enough for the new sensor of the SD1 and the strain it puts on the lenses. However, that's an option worth considering, actually: a very sharp over the frame 18mm equivalent lens would be wide enough for me.
I kinda dismissed the 20 and the 10-20 (both of them) after seeing a lot of samples online; they just don't seem up to the sensor, especially on the sides and in the corners.
The 24-70 looks good in general, very good on the long end but I found it quite weak on the wide end from the samples I have seen... do you agree with these findings?
Well, this is about it for the moment; thank you so much for your help, again I appreciate it very much your taking the time and sharing.
Best,
Vieri
My Newsletter:
portfolios:
my blog
Facebook galleries:
Ktrphoto Forum Member • Posts: 53
It is a wonderful camera if you are the sort of photographer that shoots slowly and methodically.
After using my SD1 for a couple of months I got so frustrated with the slow write-to-card times that I went back to Canon SLRs.
You also need to select your lens or lenses very carefully. The sensor will ruthlessly show up any faults. I bought the 17-70mm f/2.8-4 DC Macro OS HSM (what a mouthful!). It is an excellent lens, but I had hoped to use the 17mm end (roughly equivalent to 28mm on FF, so not especially wide) and at that extreme the corners are a lot less sharp than the centre and they also show some coma, even when stopped down. There is no comparison with the performance of a DP1M or DP3M with their perfectly matched prime lenses.
A really good lens counts for a lot. I found that a Canon 1-D mk ii N with Canon's 35mm f/2 produced images with almost as much detail as the SD1, but as good in the corners as in the centre. In fact on a computer screen there was nothing to choose between images from an EOS 1-D ii N (8.2 mp), EOS 1-Ds ii (16.7 Mp) and Sigma SD1 (15Mp, but generated from a 45 Mega-sensel sensor.
FOr example, this image, taken in this instance with the poorly regarded (but actually excellent) 28-105mm f/3.5-4.5 USM:
Canon EOS 1-Ds mark ii and 28-105mm f/3.5-4.5 USM at 105mm and 1/500 @f/8 @ISO 250
However, before selling the SD1 I made some prints at A3+ size and I was very surprised to see that the SD1 images stood out as being obviously more natural looking and more pleasing to the eye than the Canon images which seemed just a little bit cartoon-like in comparison. There is a separate thread on dpreview where people are speculating about which of the SD1's differences is responsible for the subjectively different "look".
As for the corner softness of the 17-70, it did not detract from the print quality and was un-noticeable even viewed quite close. At A3+ you would have to put your eye 2 inches from the print to see it at all.
So I am back to using the Sigma for slow careful scenic and architectural shots and the Canons for everything else. I see that some professional nature and action photographers are using the Sigma to photograph animals and fast moving athletes. I really do not know how they cope with the slow buffer clearing times.
It is a real pain running two systems side by side. I really wish Sigma would make an SD1 with an EOS mount. Canon's lens line up is much more complete, but more to the point I could simply carry Sigma and/or Canon bodies and use the same set of lenses with each.
I know that the SD1 can be converted to EOS as the Sigma mount uses the same electrical connections to control lens functions and obtain lens information. But I do not have enough experience of dismantling cameras to risk doing it myself, and to date I have not found a camera technician willing to attempt it.
Finally ... compare the corners of the image below at 100% with those from the 1-Ds ii above.
Sigma SD1 with 17-70mm f/2.8-4 DC Macro OS HSM at 28mm and 1/200 @f/7.1 @ISO 125
p.s. What is that thing I just noticed at the top of the screen? "Junior Member"? Who does dpreview think it is calling "Junior". I was born in 1955!
 Ktrphoto's gear list:Ktrphoto's gear list
Canon PowerShot G1 X II Canon EOS-1Ds Mark II Canon EOS-1D Mark II N Canon EF 24-70mm f/4L IS USM Canon EF 35mm f/2.0 +6 more
Hardy Steiner Senior Member • Posts: 2,442
The 18-35 A lens is extremely sharp. Wide enough for me for landscape.
The 20mm f1.8 is ok, but now that the 24mm A lens is out, I'd probably opt for this one. For landscape, this one might not be wide enough though.
The 24-70 is only good from 35-70.
Best regards,
Hardy
Join the Sigma DP Macro Group on:
http://www.flickr.com/groups/sigma_dp_macro/
My pictures on:
On Flickr: http://www.flickr.com/photos/diddy
Scottelly
Scottelly Senior Member • Posts: 4,430
Did you notice that this original post was made back in 2013? Vieri ended up getting both a Nikon D800E and a Sigma SD1, and he prefers the Sigma SD1. See his blog here:
https://vieribottazzini.com/2013/06/the-saga-begins-sigma-sd1-merrill-vs-nikon-d800e-part-1.html
I think that tells the story pretty well.
Your observations must be based on some sort of faulty process. First of all, you used a cheap lens that doesn't resolve very good quality images. Try the 70mm f2.8 macro or an Art lens, like the 18-35mm f1.8 A, and you'll see the performance of the SD1 shine. I also can't understand how you can think a 16 MP Canon with an AA filter on the sensor can compete with the likes of the SD1 for detail captured, when the SD1 is performing well against 36 MP cameras that have no AA filter. I think you need to do a little more research or get a better computer screen or something.
Just so you can see better, I did a comparison of the Merrill with a variety of cameras, all based on publicly available raw files, shot in the same studio by the same people of the same scene - the most scientifically identical examples available, I think. Here it is:
http://www.dpreview.com/forums/post/54317211
 Scottelly's gear list:Scottelly's gear list
Olympus TG-860 Sigma SD14 Nikon D200 Sony SLT-A65 Tamron SP AF 10-24mm F/3.5-4.5 Di II LD Aspherical (IF) +10 more
