Nikon 18-70 vs Nikon 18-135
Started Apr 11, 2013 | Discussions
Andrazh
New MemberPosts: 8
Apr 11, 2013
I own both lenses and i have to decide which one to keep.
I like the build quality of 18-70 and focus better. But I think 18-135 is a bit more sharp and has larger range.
Can someone tell me how should I test these two for sharpness? So it would be accurate?
Dont want to sell the wrong one
Thnx
mobi1
Forum MemberPosts: 65
Re: Nikon 18-70 vs Nikon 18-135
In reply to Andrazh, Apr 11, 2013
slimandy
Forum ProPosts: 15,888Gear list
Take photos.
Look at photos.
Decide.
www.andrewsandersphotography.co.uk
 slimandy's gear list:slimandy's gear list
Sony RX100 II Nikon D200 Nikon D700 Olympus OM-D E-M5 Fujifilm X-E1 +1 more
john Clinch
Veteran MemberPosts: 3,034
In reply to slimandy, Apr 11, 2013
If you can't tell which is shaper then its irrelevant isn't it.
I really can't see how anyone else can help as you have both lenses sat in front of you
Liviu Namolovan
Contributing MemberPosts: 536
Re: Nikon 18-135
Had both of them. Nikon 18-70 mm could not lived up to its fame. The humble "consumer" 18-135 blew out of the water the praised 18-70mm. In my opinion 18-70 was a deception. Nikon 18-135 is a much versatile lens and has an IQ at least on par with the 18-70mm
alexsid
Regular MemberPosts: 183Gear list
Re: Nikon 18-135
In reply to Liviu Namolovan, Apr 11, 2013
Yes, DxOMark gives the same score for both of them:
http://www.dxomark.com/index.php/Lenses/Compare-Camera-Lenses/Compare-lenses/(lens1)/174/(lens2)/207/(brand1)/Nikkor/(camera1)/680/(brand2)/Nikkor/(camera2)/680
I still have 18-135mm (purchased with D80) and it is surprisingly sharp on D7000!
Alex
 alexsid's gear list:alexsid's gear list
Nikon Coolpix P7100 Nikon D7000 Nikon D800 Nikon 1 V2 Nikon AF-S Nikkor 50mm f/1.4G +16 more
john Clinch
Re: Nikon 18-135
In reply to alexsid, Apr 11, 2013
Alex
Why would you want to look out how copies of the lens, other than the ones you own, perform? Surely in this unigue situation the answer has to come from the copies you have on hand
Retzius
Contributing MemberPosts: 591Gear list
I have both the 18-70 and the 18-105 and I like the 18-70 better. It is sharp, more compact, better built, and easy to carry. I pictures in my gallery with the 18-70 if you want to see some examples.
 Retzius's gear list:Retzius's gear list
Nikon D7000 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR +1 more
PHXAZCRAIG
Forum ProPosts: 12,165Gear list
18-70 - was a decent all-around lens on my D70s.   Not great, not too many flaws.
18-135 - one of the sharpest zooms Nikon made, at the expense of a lot of other optical issues.  CA was quite apparent.  Some distortion as well.   Worked well on 10mp cameras, but not sure how it does on the modern stuff.
Both needed VR.    The 18-135 was clearly sharper, but...
Craig
www.cjcphoto.net
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +35 more
Chad Gladstone
Senior MemberPosts: 2,608Gear list
Re: Nikon 18-70 vs Nikon 18-135 *slightly* OT
In reply to Andrazh, Apr 12, 2013
Thnx
Sell the 18-135.  Why?, because you can conceivably get more money for it.  Don't bother getting caught up in the minutia.  The 18-70 is a great Disneyland lens.  Or sell them both and get a 24-85VR, they are practically giving them away with the recent D600 bundled promotions if you scout around.  If you are contemplating a indeterminate stay with DX, please disregard the comment as 24mm is probably not ideal for an all purpose zoom in that format.
I happen to like the 18-70, not because it is especially good, but I perceive as having an important historical role in saving Nikon from digital obscurity along with the D70.  I shot Canon at the time and, like the specifications of the D800, the D70 18-70 kit was so well specified and reasonably priced, I instantly became enamored by it and increasingly disillusioned with Canon's artificial market compartmentalization and felt marginalized as a consumer because of their election to reduce functionality, based solely on software 'crippling,' for no reason other than to create incremental, but costly upgrade paths.
Fast forward to today and many of the Canon bodies are only differentiated by features alone, and employ the same (or similar) sensor for nearly all their consumer bodies.
Chad Gladstone
 Chad Gladstone's gear list:Chad Gladstone's gear list
Nikon 1 V1 Nikon D800E Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 50mm f/1.4G Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +7 more
