Older Minolta Lenses
Started Apr 11, 2013 | Discussions
alankushnir New Member • Posts: 7
I want to try my older Minolta Lenses which have been sitting in the closet for many years with my new NEX 7.  These worked on the Minolta Maxxum. What sort of adaptor would be appropriate for these lenses and the NEX7.  Thanks.
 alankushnir's gear list:alankushnir's gear list
Sony Alpha 7 Canon EF 70-300mm f/4.5-5.6 DO IS USM
Sony Alpha NEX-7
SQLGuy Veteran Member • Posts: 4,172
Re: Older Minolta Lenses
Sony LA-EA1 or LA-EA2. With the LA-EA2 you'll get similar performance with these lenses to what you would get using them on a Sony SLT camera, like the A57 or A77.
Nex-7 with kit lenses, Contax G 35, and a number of legacy lenses (mostly Canon FD)
 SQLGuy's gear list:SQLGuy's gear list
Canon PowerShot G9 Nikon D200 Sony Alpha 7 II Sony Alpha NEX-7 Nikon AF-S DX Nikkor 35mm f/1.8G +2 more
Keit ll Senior Member • Posts: 3,677
Yes but the main problem will be the lack of an image stability system as is found in Minolta & Sony DSLRs & SLTs.
This lack becomes more of an issue the longer the focal length of the lens , try putting a 500mm mirror lens on a NEX & you will see an image which dances around on the LCD or in the EVF & which can only be controlled by using a tripod. I have issues with shorter FLs as well & need good sunlight in order to have fast shutter speeds of at least 1/ 2x FL in order to control camera shake reliably.
Some will protest at these comments but I am speaking from my personal experience & would caution those contemplating this move.
Keith C
John Knuhtsen
John Knuhtsen Contributing Member • Posts: 685
It depends on if they are manual lenses, MC or MD. If so, you can buy an adapter on ebay for almost nothing. I believe these mc/md are the very best.
D Williams Contributing Member • Posts: 774
The Maxxum was autofocus so get a Minolta AF to NEX adapter like this
http://www.amazon.com/RainbowImaging-Minolta-E-Mount-NEX-VG10-aperture/dp/B004G3D61W/ref=sr_1_1?ie=UTF8&qid=1365714987&sr=8-1&keywords=minolta+AF+nex+adapter
for $20 or less.  You will have to focus and set the aperture manually but you can find out how you like the lens (which lenses do you have).  If you like the idea you can go for the LE-EA2
http://www.amazon.com/Sony-Adaptor-Translucent-Mirror-Technology/dp/B005K8AUYI/ref=sr_1_1?s=electronics&ie=UTF8&qid=1365715180&sr=1-1&keywords=LE-EA2
for about $280.  That lenses will work as well or better (except for crop factor) than they ever did on the Maxxum.
As noted above, they will have no stabilization but then neither did the Maxxum.
PS  If by any chance they were MC or MD lenses and you were using an adapter on the Maxxum, you will need to get the MC/MD version of the NEX adapter like this
http://www.amazon.com/RainbowImaging-Minolta-NEX-3-Camera-Adapter/dp/B003XQ6FDE/ref=sr_1_1?s=electronics&ie=UTF8&qid=1365715490&sr=1-1&keywords=MD+NEX+adapter
 D Williams's gear list:D Williams's gear list
Panasonic Lumix DMC-LX7 Sony SLT-A77 Sony Alpha DSLR-A900 Sony a6000 Sony Alpha NEX-7 +30 more
davect01
davect01 Veteran Member • Posts: 7,037
The few I have and have had were all MD mount, but it did vary a bit, so do your research.
Many of us love manual focusing on the NEX platform.  Not ideal for all things and all situations, but a lot of fun.  Takes some practice, but once you get it down, you'll love it.  You start having a few issues with stabilization in the 300+ range, but under that, you can hardly tell.
DP has a pretty good lens review portion.
http://www.dpreview.com/products/lenses
A run down, particularly of Minolta lenses
http://www.paulfvs.dds.nl/lenses.html
Novice photobug, proud NEX-3 owner
http://davesnex-3photos.blogspot.com/
santiclaws Contributing Member • Posts: 938
Keith C
If he has had those in the closet for many years, presumably he used them with Minolta film cameras which had no stabilization.
kev777zero
kev777zero Senior Member • Posts: 1,548
Keith C
I don't understand why people avoid the lack of stabilization like the plague. Yes it can be useful but unless you shoot in the dark all the time, it's not going to make your pictures any better.
And even if stabilization can keep your hands from shaking, it's not going to freeze your subject from moving.
I am also speaking from personal experience, and I was born after camera/lens stabilization was made available too.
I do agree though that using the 500mm f/8 mirror lens handheld w/out stabilization is quite tough (owned one before). ISO is at least at 1600 on an average day. But there's still plenty of light shooting with f/5.6 @ 300mm on a gloomy day without it!
YMMV
 kev777zero's gear list:kev777zero's gear list
Sony Cyber-shot DSC-RX100 III Sony Alpha 7 Rokinon 8mm f/2.8 UMC Aspherical Fisheye Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Sony FE 55mm F1.8 +3 more
kev777zero
is there something wrong with dpreview's gallery btw? can't see the pics on my computer..
captura Forum Pro • Posts: 21,710
The OP already said that his lenses were from a Maxxum. So they would not be MD /MC manual lenses.
GaryW Veteran Member • Posts: 8,170
Do we even know what focal lengths are involved?  Before going into too much panic, maybe the OP has a 50mm, not a 500mm.  An adapted 50/1.7 is just great on the Nex.
I protest your premature negativity, not the point about the 500mm.  I'd say even 300mm gets to be tough (although I've done it -- handheld -- and it worked).
Keith C
Stablization helps in certain circumstances, not so much in others.  It is more useful on longer lenses, IMO.  It's also more useful on video than stills (again, IMO).
I appreciate the better high-ISO more with the Nex.  It can be a reasonable trade off to get more speed.
Gary W.
 GaryW's gear list:GaryW's gear list
Sony Alpha NEX-6 Sony E 16-50mm F3.5-5.6 PZ OSS Sony E PZ 18-105mm F4 G OSS Sony Cyber-shot DSC-V3 Sony Alpha NEX-5 +9 more
jpr2 Forum Pro • Posts: 14,710
re: nay, nowhere as bad as you make it sound...
...certainly tripod will help with stabilizing an image from the Minolta AF reflex 500/8, but not as much as expected = instead of handshakes and tremors we'll have to cope with vibrations (unless a tripod is hyper-sturdy). However, the 500/8 cat is perfectly hand-holdable down to 1/500 sec. Also, in a good light there seldom is any need to pump ISO above 400-800 level (and I'm talking of Nex-7 here, not exactly low noise champion ),
jpr2
alankushnir OP New Member • Posts: 7
Actually, one of the lenses I was talking about was a 50/1.7 !
Thanks for the encouragement.
Alan
