Best Flash for the D7100
Started Apr 10, 2013 | Discussions
Bullseyejoe New Member • Posts: 2
Hi , I am new to Photography with dslr cameras and I am about to buy the 7100 and wondered which would be the best flash to buy for general use , I wont be using the camera to excess, just average general use I guess. I did own the 7000 for a short while and bought a second hand sb600 flash which seemed to over expose the pics! Anyway I sold both as I got my heart set on the 7100 shortly after it was released,
Thanks in advance Andrew
Nikon D7100
JeffryZ Senior Member • Posts: 2,266
Re: Best Flash for the D7100
The SB600 is a good flash.  If you think it is over-exposing you can adjust the settings of the flash or your camera settings- cheaper than buying a new one.  I own two SB600 flashes and will continue to use them when my D7100 arrives (Just shipped today!).  I am normally set for Rear Curtain Sycn in Aperature Priority mode and use the EV exposure controls to adjust my exposure.
 JeffryZ's gear list:JeffryZ's gear list
Nikon D7100 Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Tokina AT-X Pro 11-16mm f/2.8 DX +1 more
Curious why you sold your gear.  Since you refer to yourself as "new to DSLR" photography it sounds perhaps like you hadn't yet learned how to use it and get the most out of it.  Familiarize yourself better with it and then you will be able to get better pictures.
Bullseyejoe OP New Member • Posts: 2
Yes you are probably right that I didn't get the best out of the 7000 as I only had it for 4 weeks but I decided to twist rather than stick and get most of my money back whilst I could and get the 7100.So the 600 flash would of been good enough then? Is there no reason to get the SB 700 or the 910 ? Thanks
hirejn Regular Member • Posts: 341
The SB-600 is good for playing around. It's an archived product, so I have no problem recommending the SB-700 as a replacement, and used is a good option. The SB-910 is a pro flash. Anyone can buy it, but it's designed to keep up with the needs of pros. Flashes are the same in that they don't change the physics of light or how to use it. They don't differ in quality of light. A more expensive flash won't improve your flash photography.
Joel Nisleit Photography
The secret to great photography is no more in the equipment than the secret to great painting is in the brush.
 hirejn's gear list:hirejn's gear list
Nikon D300 Nikon D100 Nikon D200 Nikon D700 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +8 more
JoeR
JoeR Senior Member • Posts: 1,961
If money is not an issue get the SB910. Otherwise get the most powerful Nikon flash your budget allows. Learn how to use it and your flash photography will improve.
joer56
http://www.pbase.com/joer
stevegep Regular Member • Posts: 125
I have an SB-600 and use it a lot.  For what I do, I wish I had a more powerful flash like the SB-910.
rosiesphoto Regular Member • Posts: 187
SB600 speedlight is a good flash for a beginner. Overexposure is not caused by the speedlight, its most likely inexperience of the photographer. I would recommend starting with aperture priorty and TTL when using a speedlight.
 rosiesphoto's gear list:rosiesphoto's gear list
Nikon D3100 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR
sr71 Junior Member • Posts: 46
Learn to command your devices and take the correct setting (exposure control for flash).
If you plan to use multiple flashes I would recommend the SB-910. But anyway this premium flash
is perfect. I use the SB-800/SB-600. Both are good but on newer speedlights you have more controls.
... if you need. Depends what you need. SB-600 could be a good start. The internal flash can also be used as master on the D7100.
herbymel Senior Member • Posts: 5,291
joer56
Overkill for most photographers, he'd probably never get the use out of it. Probably best sticking with the 600 for now, learning flash photography or getting a 700 new or used. He could then decide what his flash needs are. Nothing wrong with having more than one.
 herbymel's gear list:herbymel's gear list
Nikon D810 Nikon D750 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF Nikkor 50mm f/1.8D +7 more
olynik969 Senior Member • Posts: 1,432
SB700.....
Provides excellent exposure results on my D7000 and D300s.  That said, I liked me SB800 (which recently died) was the most pleasing flash I've ever used. Considering the 900/910.
Bob
Bob (formerly bobmax)
 olynik969's gear list:olynik969's gear list
Olympus E-M1
HankK
HankK Regular Member • Posts: 389
SB-700 for my D7100
I tried the smaller SB-400 and still have it but the SB-700 provides better coverage and is not that large size wise.  I just liked the flash output a lot more.  You can also set flash exposure compensation on the flash.
Hank K
Nikon D7100, Coolpix A, Fuji XE-1, Samsung NX20 (former D800E, 5DM2, RX100, GH2 Kit, and Fujifilm X100 shooter)
Re: SB-700 for my D7100
Hank K
I could be wrong (don't own one) but I believe the SB 400 cannot be used as a slave unit.  What this means is that as you improve with using your flash, you can't use it off- camera and use the built in flash to trigger it.  The light can be more appealing when it doesn't come from straight ahead.
Sern New Member • Posts: 2
A D7000 and an SB700 would probably be about the same price as a new D7100 and would be totally worth the money. I don't have any experience with the D7100 but have been using a D7000 now for seven or eight months. It was a an upgrade from the D60 I had been using since 2008. The D7000 is a very good camera for the money and for most people may be all the camera they ever need (I'm not trying to sound like Ken Rockwell). If your just taking pictures of family and friends an SB400 does a great job; I used one for three years and now need to upgrade for business purposes. The SB400 is limited when you want to get creative or need to take an image portrait style, monkey hand your camera. If you want to get technical, read Joe McNally's book "the HOT SHOE DIARIES". Moose Peterson has a decent article (IMHO) that may help explain flash a little better. Here is the link
http://www.moosepeterson.com/techtips/flash.html#basics
Good Luck
B. R. Sorensen
 Sern's gear list:Sern's gear list
Sony RX100 II Nikon D7000 Nikon D750 Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +6 more
