D7100 Presents: Single Shot HDR
Started Apr 10, 2013 | Discussions
BlueBomberTurbo OP Contributing Member • Posts: 974
Re: D7100 Presents: Single Shot HDR
_sem_ wrote:
AngryCorgi wrote:
While there is clearly banding in the trees, it doesn't show up too strongly at 1600px across.  Nice composition.
Yep. Perhaps a touch-up with Dfine or Denoise would clean up the banding. Or one should revert to the D7000 for single-exposure HDR
Nah, the D7100 definitely has more room for highlight recovery, and less splotchy chroma noise in shadows.   Not to mention the extremely accurate color reproduction (**drool!**).
 BlueBomberTurbo's gear list:BlueBomberTurbo's gear list
Sony a6000 Nikon D750 Sony Alpha a6300 Sony E 18-55mm F3.5-5.6 OSS Sigma 70-200mm F2.8 EX DG Macro HSM II +13 more
AngryCorgi
AngryCorgi Contributing Member • Posts: 916
From comparisons online, I think the "less splotchy chroma noise in shadows" is not documented for the D7100, but rather the opposite is seen to be the case.
Here is a D7100 (left) vs D7000 (right) comparison of shadow noise on just a 2EV push (From http://betterfamilyphotos.blogspot.com/2013/04/nikon-d5200-and-d7100-band-aid.html):
D7100 vs D7000
I think its readily apparent, at least to my eyes, that the shadow noise AND banding is visible in the D7100 and not the D7000.
-AC-
D7100 vs D7000
-AC-
Guess it depends on the situation.  Here's probably the best comparison image from my D7000:
1.  No NR
2.  Max NR possible in ACR
First image is processed the same way as the pic in the first post in this thread (very light chroma NR, no luma).  Second with a TON of noise reduction and color adjustment, including ACR moire reduction, which took almost 2 min to render in PS on my PC.  And my PC isn't a slouch (i7 2600K, GTX 570, 32GB RAM).  Still wasn't enough to fully quell the chroma noise, but much more usable.  Both are ISO 100 with major shadow lifting and highlight recovery.  By itself, the D7000 is very splotchy compared to how well behaved the D7100 was.
Also, note that the D7100 pic is significantly cropped.  Here's the original vs crop:
Original vs Crop
howielenny Contributing Member • Posts: 816
http://chrisfiorephotography.com/blog/upload/_DSC0678.jpg
D7100 + 17-55mm on the side of a freeway.
Been trying to enable hdr on my D7100 but yet to do so. Looking in the manual on page 115 seems easy to do. I have the camera on Aperture mode and when I go to the menu settings and try to choose HDR it says
"This option is not available at current settings or in the cameras current state"
Any ideas?
 howielenny's gear list:howielenny's gear list
Sony Cyber-shot DSC-RX100 IV Nikon D750 Nikon D7200 Panasonic Lumix DMC-GX8 Nikon AF-S Nikkor 24-120mm f/4G ED VR +10 more
Any ideas?
In-camera HDR only works in full JPG mode, but if you know how to post process, using a RAW like above will give you a ton more flexibility and much higher image quality.  You absolutely need a tripod or a wide angle lens for in-camera HDR, since it won't align the photos for you, too.  And if anything's moving in the image, it won't turn out very well.
Good Camera Forum Member • Posts: 54
That is one very very neat photo!!!!!!!!!!
Any ideas?
Cheers, just realised it only works in jpg mode. I doubt very much I'll use the hdr mode as I generally bracket images and run them through Photomatix but just couldn't work out why it wouldn't allow me to choose the setting.
Thanks.
AngryCorgi
D7100 vs D7000
-AC-
1.  No NR
Original vs Crop
Yeah, I'm pretty certain comparing two entirely different scenes probably isn't the most effective way to prove one's point.
-AC-
-AC-
Not much else I can offer beyond my experience with the D7000, which I had since its launch till the D7100's launch.  Many of my daytime photos were pushed just as hard in post, and I did a lot of high ISO/low light shooting, including weddings.  The high ISO capabilities of Nikon's DSLRS are what drew me to them in the first place (starting with the D90), and I've definitely taken advantage of them in that time.
Nexu1 Senior Member • Posts: 2,556
BlueBomberTurbo what software do you use for this single shot HDR technique?  I'm very intrigued and would like to dabble with it.
AngryCorgi
-AC-
I understand, I had a D90 and D7K as well.  But its hard to refute a test done between the two cameras with the same lighting and lens and scene, which is what I linked to.  I never got any real noise from a 2EV push with the D7K, but the D7100 sample from that link seems to behave differently from the D7K.
-AC-
fireplace33
fireplace33 Senior Member • Posts: 1,903
Nice image!
Just an idea,...The green post in the middle of the foreground is a bit distracting, I tried cloning it out,  and the resulting composition worked much better IMO. Somehow your eye can travel over the image towards the main tree in a much freeer way when it's gone.
 fireplace33's gear list:fireplace33's gear list
Nikon D7100 Nikon AF-S Nikkor 70-200mm f/4G ED VR Tokina 11-20mm F2.8 Nikon AF-S DX Nikkor 16-80mm F2.8-4E ED VR Canon PowerShot G15 +13 more
Adobe Camera Raw that comes with Adobe Photoshop.  You need Photoshop CS6 with the Camera Raw update 7.4 to be able to open D7100 files.
-AC-
Were the camera settings exactly the same?  The exposure looks brighter on the right, and it also shows a good amount of amp glow, which can be hard to remove since it's all in the magenta and purple channels.  Also, the pic on the right is out of focus (at least in the background), so the noise would definitely look smoother without any detail to try to pick out.
potluck New Member • Posts: 6
Very nice photo!
olynik969 Senior Member • Posts: 1,430
Wow.... Great Shot &
I too like "juiced" images....
Well done!
bob
Bob (formerly bobmax)
 olynik969's gear list:olynik969's gear list
Olympus E-M1
Pap38
Pap38 Veteran Member • Posts: 3,744
Not overdone, to me. Might have preferred if the image had been captured from slightly to the right. I’d loose the blown out area in the sky.
Pap
 Pap38's gear list:Pap38's gear list
Panasonic Lumix DMC-FZ28 Panasonic Lumix DMC-ZS8 Nikon D60 Nikon D5100
George Cifrancis Regular Member • Posts: 391
That's a really cool shot!
George C.
