DP2M: That's Resolution
Started Apr 10, 2013 | Discussions
IVN Senior Member • Posts: 1,750
DP2M vs SD1 & 30/1.4 = insane
The 30mm f/2.8 lens of the DP2M is insanely sharp. Take a look at this comparison  vs. the Sigma SD1 and the "old" 30mm F/1.4. It's mind-blowing how sharp the DP2M is wide open.
Tom Schum
Tom Schum Veteran Member • Posts: 5,180
Re: 808: resolution very impressive, DR and noise not so
Joerg V wrote:
Hi Petr,
I (somehow) agree with you. The sheer resolution of the 808 is mind-boggling considering how small the sensor is and that this is a cell phone camera. I looked a lot on dpreview's 808 studio scene and I am seriously impressed. If you only consider resolution: the 808'er output resolution is more impressive than the DPxM output (given the constraints!).
That's why I think all that focus on resolution alone as single measure of image quality falls a bit short. The 808's pixel quality is obviously not very good (but there are just soooo many pixels), the dynamic range is very very poor and the 100% images are quite noisy (which was to be expected).
I guess it would be possible to squeeze the 808'er sensor and optics into something just a bit large than a lighter. Now add an automatic multi exposures blending mode too overcome noise and dynamic range problems (works on static scenes only but ok)... wow!
Cheers
Joerg
For quite some time the speculation has been that a very large pixel count can equal Foveon.  Looks like this is true.  I guess a 45 megapixel APS-C sensor would fully equal the Merrill across the ISO range.  This would include less performance above ISO 800, same as Merrill.
If this ever will happen, it is going to be a few years, and by then hopefully Sigma will have improved upon the Merrill.
Tom Schum
Sigma DP2 Sigma DP3 Merrill Ricoh WG-4 GPS Fujifilm X30 Sigma dp0 Quattro +8 more
DMillier Forum Pro • Posts: 19,083
It's pretty easy to test. If you have a shift lens or adaptor you can flat stitch without any need for bending and twisting the images as you do with normal stitches. Shift-left, no shift, shift right will double the pixel count easily. So a NEX7 would give you a stitched 48MP file to compare.
Roland Karlsson Forum Pro • Posts: 24,526
Its even simpler.
You can crop the Foveon image and downscale the Bayer image.
 Roland Karlsson's gear list:Roland Karlsson's gear list
Sigma DP3 Merrill Sigma dp2 Quattro Sony Cyber-shot DSC-RX100 III Pentax K-3 Pentax K-1 +12 more
petr marek Regular Member • Posts: 179
Tom Schum wrote:
Joerg V wrote:
Hi Petr,
Cheers
Joerg
Tom Schum
The advantage of Foveon, as we all know, is full color information in one spot. The result is a very natural contrast, full tonal range and ability to reach microcontrasts in the detail along with smooth rendering of homogenous surfaces without false artefacts (although I know Sigma has to improve some characteristics).
With Bayer, even there´s a lot of information from the large amount of pixels, full microcontrasts are missing and tonal range is cropped, because of weighted average of interpolation and incapability to use full light information homogenously all over the sensor.
I still see future in layered sensors, not oversampling. Just resolution won´t create the magic of alive image.
