Single-bay charger for EN-EL18 battery?
Started Apr 10, 2013 | Discussions
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 12,570
I'd like to get an EN-EL18 battery for my D800 grip.   The cost of the battery is bad enough, but $400 for a MH-26 dual-bay charger is just too much, if there is an alternative.
Since I will only have a single battery for the foreseeable future, and I'd like to have a smaller charger for travel, is there an alternative charger for the EN-EL18?   One that someone here has personal experience with and can vouch for?
Craig
www.cjcphoto.net
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +35 more
Nikon D800
Pradipta Dutta
Pradipta Dutta Veteran Member • Posts: 9,780
Re: Single-bay charger for EN-EL18 battery?
PHXAZCRAIG wrote:
[snip] but $400 for a MH-26 dual-bay charger is just too much, if there is an alternative.
First of all MH-26 sells for $300 not $400. However, I agree, that even $300 sounds ridiculously high for a charger.
You should try Craigslist (or any other local classifieds) as I have seen people selling their spare MH-26 for far less. Most of those ad's typically claim that they are selling their spare charger as each of their cameras came with a charger.
My Online Gallery - http://www.pbase.com/pradipta
 Pradipta Dutta's gear list:Pradipta Dutta's gear list
Nikon D2X Nikon D3 Nikon D800 Nikon D3200 Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF +5 more
PHXAZCRAIG
PHXAZCRAIG OP Forum Pro • Posts: 12,570
Was looking yesterday, and say:
Samys $399
Then I saw somewhere else $378, and I was pretty sure I saw a similar price from B&H.
Today, $299 at B&H and Adorama.  Weird.
Regardless, it's not only too expensive, it's too big - too much!   With only one battery, I have no need for a dual-slot charger.
I can't believe someone doesn't make a separate charger and that you have to buy the Nikon one.    Come on, that's over $400 just to add a decent battery to the D800!
Craig
www.cjcphoto.net
Roy Kikuta Senior Member • Posts: 1,411
The problem is that  the few sites that advertise mh-26 compatible single bay chargers don't inspire much confidence - here's an example: http://www.my-chargers.com/mh-26-nikon-charger.htm
Apologies for being slightly off-topic, but here's a new product for folks who use both D3 and D4 might be interested in: http://www.nikonsportoptics.com/en/Nikon-Products/Power-Chargers/27112/MH-26aAK-Adapter-Kit.html
Now, why couldn't Nikon have released their D4 with this charger?  It would have reduced the number of complaints from those who use both bodies (EN-EL4a and EN-EL18).
lnaru78 Forum Member • Posts: 62
I was on the same boat and was looking for a charger a few weeks ago. My camera bag got stolen with the charger in it along with a few lenses. Thankfully, I was shooting with the camera and thats safe. Cutting to the chase, I looked all over for a third party replacement and found none. I even called several b&m stores like batteries plus and they said they have a replacement battery but not the charger.
The sites that other people are referring to dont have this charger and you will get an error when you actually try to order one. Atleast, I did when I tried to order.
I ended up buying another mh-26 from ebay for around $260 and it seems to work great. Its an awful lot for a charger but left with no other choice, you have to get one for that price. Good luck.
ejw07
ejw07 Regular Member • Posts: 425
Hey Prad...seen them for $$$399 here..so what u looking at.. Been trying to pick one for ages now..
E. j. W.
 ejw07's gear list:ejw07's gear list
Fujifilm X100T Leica Q
DigitalJay Senior Member • Posts: 1,458
I ordered one of these....
...from Amazon:
http://www.amazon.com/Smatree-EN-EL18A-EN-EL18-Rechargeable-Lithium-ion/dp/B008VOP12Y/ref=sr_1_1?ie=UTF8&qid=1365685356&sr=8-1&keywords=smatree+en-el18
It woks well, and has a built-in charger. Comes with AC and D/C cords. I have the EN-EL4a for my D700, but couldn't justify the increased cost for the big battery that doesn't increase my frame rate. Originally, I planned to use it just when cleaning the shutter, but have since reconsidered and just use it period.
Jay
 DigitalJay's gear list:DigitalJay's gear list
Nikon D200 Nikon D300 Nikon D700 Fujifilm X-E2 Fujifilm X-T1
BlueHeron74 Forum Member • Posts: 92
The DSTE batteries come with a plugin battery charger and car charger.   All it is a small transformer that plugs into a hole in their battery.   It makes a compact traveling kit.
I went the DSTE route because I wanted the higher capacity battery.   There website says the battery is compatible with their battery grip and the original battery grip.   I read a post a couple days saying the battery worked in a D4, but if I had a D4, I doubt I use the battery in it.  All the normal warnings about attaching a cheap Chinese knockoff battery to an expensive camera.  But for a $40 battery (with accessories), I don't have anything to complain about.
 BlueHeron74's gear list:BlueHeron74's gear list
Pentax K-5 Pentax K-01 Nikon D800 Pentax K-5 IIs Nikon AF-S Nikkor 16-35mm F4G ED VR +22 more
PHXAZCRAIG
Re: I ordered one of these....
Hmm.  $40, versus $400-500.   I think I may at least give this a try!
Craig
www.cjcphoto.net
Alec
Alec Contributing Member • Posts: 691
I use a pair of these DSTE EN-EL18 batteries in my D800.
They're a great value and work well much of the time. I say "Much" because they introduce a stability problem when the camera is in a LiveView mode. The camera, if powered solely by the DSTE EN-EL18 in the grip, would lock up immediately or shortly after entering LiveView (stills or movie mode) if the battery is anything less than fully charged. Electronically, the battery presents itself to the camera in a simplified way as an AA pack, even though its output voltage is less. Ebay sellers of DSTE have confirmed as much after some evasiveness, after being confronted with the issue.
Setting the battery chemistry in the camera to NiMh helps somewhat. Leaving a fully charged EN-EL15 in the camera sidesteps the issue (even with the camera set to draw power from EN-EL18 first), though I haven't tested how much the camera ends up leaning on EN-EL15.
Alexander "Sasha" Karasev
principal photographer
Karasev Studio
http://karasevstudio.com
 Alec's gear list:Alec's gear list
Sony Alpha DSLR-A900 Nikon D800 Nikon AF Micro-Nikkor 60mm f/2.8D Sony 50mm F1.4 Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* +33 more
