7D Mirror Shake - w/70-200 f/2.8 - Advice on brace, please
Started Apr 10, 2013 | Discussions
Zee Char Forum Pro • Posts: 10,555
Re: 7D Mirror Shake - w/70-200 f/2.8 - Advice on brace, please
springbock wrote:
Zee Char wrote:
tvstaff wrote:
I havent read every post here so forgive me if this has already been suggested but I think this is exactly what you are looking for.
http://www.manfrotto.com/telephoto-lens-support
Tom
Edit: Ooops too late I see you've already purchased your rig, never mind.
'The truth is rarely pure and never simple' Oscar Wilde
Tom, thanks. I tried one this weekend and am ordering one too my real important issue was the tripod and head. I'm half way there. Thank you.
My two cents. That looks like it is designed for a system that has no lens collar. Besides I would not be that comfortable with a strap pulling down on the lens which creates pressure at the mount for both the lens and the body. You technically should no even handle your gear via the body only when a heavy lens like that is attached.
You have a very good rig there now, why not try that first?  I have never had any issues with my tripod but of course that is up to you. Just must be sure not to put a lot of pressure on that strap. My guess is the instructions probably say that.
There is a V shaped support under the lens so it's not pulling down on it. The strap just holds it in place so it doesn't slide sideways. You can move the support forwards and backwards to find its optimal position. but you are right you can't use it with a tripod collar.
I was wondering about that. It was hard to make out in that link.
 Zee Char's gear list:Zee Char's gear list
Canon EOS 7D Mark II Canon EF 300mm f/4.0L IS USM Canon EF 70-200mm f/2.8L IS II USM Canon Extender EF 1.4x III Sigma 2x EX DG Tele Converter +3 more
tonyjr
tonyjr Veteran Member • Posts: 5,256
He did not post - I have / don't have a grip .
There are 3 types of people mainly on this site - those that help - those that want to learn and others
If just the OP read the posts , it would be different , I like others want to know also what others are using and any pro's or con's to using it .
 tonyjr's gear list:tonyjr's gear list
Canon EOS 400D Canon EOS 7D Canon EF 35mm f/2.0 Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +14 more
phill104 Senior Member • Posts: 2,619
4 types, those that tell you that their way is right, their kit is right and you have to do and buy as they say or all your images will be crap.
springbock Senior Member • Posts: 2,263
What does this mean Junior? Are you implying that I wasn't trying to help?
Maybe it's just a misunderstanding that that is common with text.
