Photographing a Person: A test of focal lengths
Started Apr 10, 2013 | Discussions
richj20 Veteran Member • Posts: 3,358
6
In another thread, I posted photographs of people taken at different focal lengths. I thought it would be useful to do a test with the same person at different focal lengths, so I enlisted the help of my neighbor.
The test wasn't as controlled as I would have liked: he changed is head angle slightly a few times, but I think an overall impression can be gotten.
(I'd like to get a manequin and do a similar test!)
Also, I moved his location when the sun became harsh on the face.
I positioned the tripod to frame approximately a head-shoulders pose, and moved back accordingly as I changed focal lengths from 12mm (a little less than 2 feet from lens to face) to 150mm (about 14 feet from lens to face).
Here they are -- focal lengths in m4/3 format, so double them to get full frame equivalent.
- Richard
12mm
14mm
17mm
25mm
35mm
45mm
76mm
100mm
150mm
"Careful photographers run their own tests." - Fred Picker
 richj20's gear list:richj20's gear list
Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G 20mm F1.7 ASPH Panasonic Leica 100-400mm F4.0-6.3 ASPH
BingoCharlie Contributing Member • Posts: 849
Re: Photographing a Person: A test of focal lengths
So what have you concluded from this experiment?
007peter
007peter Forum Pro • Posts: 10,310
Suggestion for a ReShoot, love the 1st photo the best
5
Thanks for your effort, but due to the changing lighting + different angles, the test isn't useful.  For example, I like the 1st photo the best because it has the best exposure and lighting.  You lose the light on 3rd and 4th photo, and the color balance is also quite different.
May I suggest a reshoot:
  • 1. Use a Tripod on a 2 seconds timer.  This way your camera is FIXED in place
  • 2. No Fence as Background.  Try to find a long Open Space as your Background.  This way, we can see how focal length affect Telephoto-Compression on noisy background
  • 3. Try to shoot within an hour under the same lighting, same light angle
  • 4. use MANUAL EXPOSURE and fixed that exposure.  So each photo doesn't look wildly different from another
  • 5. use MANUAL WHITE BALANCE, so each photo share the same color balance
 007peter's gear list:007peter's gear list
Panasonic Lumix DMC-GF6 Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 25mm F1.7 ASPH
richj20 OP Veteran Member • Posts: 3,358
That there isn't too much difference. If I couldn't see them side by side, I wouldn't think that any were completely unacceptable!
- Richard
Re: Suggestion for a ReShoot, love the 1st photo the best
Thanks for the comments. I'm aware of what you describe, but here I was curious as to how the face changed at the different focal lengths.
I'll consider doing another test under the conditions you outline.
- Richard
forpetessake
forpetessake Senior Member • Posts: 4,858
6
- Richard
You confirmed what traditionally was considered a good FL for people portraits 80-135mm in FF equivalent (most portrait lenses used to be 90-105mm). Below that the image becomes distorted and cartoonish, above that it becomes flat.
Anders W Forum Pro • Posts: 21,465
One additional consideration on top of those already mentioned: One of several reasons why longer FLs (45 up) are preferred to shorter (25 down) for head-and-should portraits is that the shorter FLs will give rise to perspective distortion (compared to how we usually see things with our naked eyes) of the face, exaggerating the size of proximate features (e.g., the nose) compared to more distant ones (e.g., the eyes and ears). By having the model turn his face to the side, you reduce the importance of that element. So have the model turn his face to the camera next time.
Panasonic Lumix DMC-G1 Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH +28 more
Aleo Veuliah
Aleo Veuliah MOD Forum Pro • Posts: 14,628
You have taken a good portrait with almost focal lengths. Nice to see the differences.
Simplicity is the ultimate sophistication.
Learn the rules like a pro, so you can break them like an artist.
Pure logic is the ruin of the spirit.
If plan A doesn't work, the alphabet has 25 more letters, keep calm.
Imagination is more important than knowledge.
God is the tangential point between zero and infinity.
Aleo Photo Site
 Aleo Veuliah's gear list:Aleo Veuliah's gear list
Panasonic Lumix DMC-ZS1 Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-G2 Panasonic Lumix DMC-GH4 +4 more
Matz03 Regular Member • Posts: 186
thanks for posting these, I was most interested in seeing the 25mm and 45mm perspective and wow, even bigger difference that I thought!  The age old rule is that a 50mm equivalent (your 25mm image) lens is bad for head shots and it obviously shows.  Your 45mm picture finally doesn't show that distortion and going up from there doesn't change things too much.
Setter Dog Veteran Member • Posts: 4,605
Well,....color me easy to please, but they all look good to these old eyes. Nice job.
Jack
Well, face-on is the pose that attracts me the least, so I tend to avoid it. I know what happens, as you describe!
- Richard
Thanks, Aleo, I'm glad it's been useful!
- Richard
You are welcome, and I'm glad they've been helpful!
- Richard
Jack
Thanks, Jack, it was fun to do.
- Richard
I'm glad it's been helpful.
- Richard
Sudo Nimh Regular Member • Posts: 281
I see the big difference between 17mm and 25mm. At 17mm and shorter, you feel close to the subject. I actually like that close feel for a lot of head shots, especially of young kids with their flawless complexions and especially when there's something interesting in the background.
gianstam Contributing Member • Posts: 810
Re: Photographing a Person: Distance
Your test confirms my opinion about portraits.
The photographer must be too close to his subject (for several reasons)
- Richard
 gianstam's gear list:gianstam's gear list
Nikon Coolpix 990 Samsung TL500 Canon PowerShot G1 X Pentax K20D
Vlad S Veteran Member • Posts: 3,658
Similar test under controlled conditions
 Vlad S's gear list:Vlad S's gear list
Olympus OM-D E-M5 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +2 more
.Sam.
.Sam. Veteran Member • Posts: 3,198
Thanks for the effort.
Obviously the 12mm doesn't look too pleasing. The rest seem to "useful" in a pinch. However, in my view the 45mm (e-90mm) stands out, and looks the best.
.Sam.
GF1+20+45 Sigma DP2 & Pentax K20D - ist* DS - ZX-5 - LX
Photos: http://www.flickr.com/shadzee/
 .Sam.'s gear list:.Sam.'s gear list
Sigma DP2 Pentax *ist DS Panasonic Lumix DMC-GF1 Olympus PEN E-P5 Panasonic Lumix G 20mm F1.7 ASPH +7 more
RoelHendrickx
RoelHendrickx Forum Pro • Posts: 24,429
Interesting... - I did the same in a LANDSCAPE setting
This is an interesting exercize, but the effects you show are fairly limited (note : I use "limited" not in a derogatory way, but more like an indication of the controlled state of your experiment).
There is some distortion on the face in the wider focal lengths (slightly elongated face, but well controlled, because your angle of view is good : this would be more obvious if you shot from higher to low or from lower to high).  Starting from 25mm, there is not really that much difference anymore between the shots.
That is the fact, IMHO, because you placed your model close to a neutral background.
The differences in view would be more spectacular, if you placed your model in a wide-open landscape setting (or even in a garden or room with a bit more space between him and the background) : then we would see the longer FL shots evolve from still environmental until a shot where the face is isolated against blurred and compressed neutrality.
While hiking the Libyan desert, I did a similar little test, when I was explaining to our guide Rhyssa (who became my test subject) the effect of focal length on perspective.
In that case, I was not aiming to show distortions on a body or face, but rather the relationship between a person and his surroundings.  This is relevant for portrait photographers who do not necessarily want to isolate the subject, but rather show it in his environment (and decide how much of that environment should be shown).
I used 4 focal lengths (using two lenses), trying to keep the person roughly the same size in the frame (but handheld and without calculating : this was on the fly in a few minutes), in order to show how dramatically the background would change.
Obviously the effects will be different depending on the kind of environment and the distance from the subject to the nearest objects : it works differently in a living room than in a mountainrange.
It is another test obviously - yours shows me that the face (portrait) itself is not influenced dramatically by focal lengths above 25mm (50 mm EFL).  Thank you for that.
Just for the heck of it (not meaning to hijack your thread), here is my series of four:
(If for some reason the photos do not show up as embedded - it happens sometimes - click on the space with the little red cross and you should see them...)
FL of 14mm:
FL of 54 mm:
FL of 104mm:
FL of 200 mm:
Roel Hendrickx
lots of images: www.roelh.zenfolio.com
my E-3 user field report from Tunisian Sahara: http://www.biofos.com/ukpsg/roel.html
