Monopod for tall photographers
Started Apr 9, 2013 | Discussions
Nick_Brisbane Contributing Member • Posts: 821
I am 6'2 around 188 cm tall. Does anyone know of a monopod that extends to around 180 at least. Most seem to be around 169 cms.
 Nick_Brisbane's gear list:Nick_Brisbane's gear list
Nikon D80 Nikon D5100 Nikon D600 Nikon D750 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +2 more
(unknown member) Senior Member • Posts: 3,849
Re: Monopod for tall photographers
Gitzo has a few:
- GM3350XL - Aluminium - 186cm
- GM3550 - Carbon - 192cm
- GM3551 - Carbon -192cm
Benro (more affordable):
- A49T - Aluminum - 193cm
- C49T - Carbon - 185cm
I almost bought the Benro C49T myself, but got a really good deal on a Jobu Design monopod which had enough height for me since I am using a tilt head. I am 185cm and do not have to fully extend the Jobu Design (163cm) because the head and lens collar add enough height.
 Wyville's gear list:Wyville's gear list
Canon PowerShot S95 Canon EOS 7D Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100-400mm f/4.5-5.6L IS USM
hotdog321
hotdog321 Forum Pro • Posts: 15,460
Remember that you can add 2-3 inches by choosing a good-sized head and quick release plate for your monopod.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark III Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM Canon EF 16-35mm f/4L IS USM Canon EF 11-24mm F4L +1 more
afoton
afoton Senior Member • Posts: 1,071
I am 190cm tall. My monopod is 170cm, and that is enough to get the ocular at the same heigh as my eyes, without using a head between the monopod and camera.. But I prefer to use a head so I can set the end of the monopod a little in front of me, tilting the monopod against me. With a decent head, my monopod is even long enough for using it this way.
hotdog321
I always use a head on a monopod so I can precisely balance a 300 or 400mm lens at their center of gravity for sports and news events, but still angle them slightly to frame the shot properly.
Hank3152
Hank3152 Forum Pro • Posts: 13,453
Okay, considering and allowing for your line of sight (4"), the swivel head (3") and viewfinder distance (3") for a non gripped body, that's 10" (25cm) leeway. I'm 6" and a 170cm or 67" pod is more than adequate.......it's way over my eye level with a head attached........
......seriously consider the Feisol CM-1471
This is one of the finest monopods I have ever owned and I've used Manfrotto and Gitzo....quality and design is well worth the cost....... http://www.feisol.net/feisol-monopod-cm1471-rapid-p-6.html .....
The unit weighs a mere 1.5 lbs and is as solid as a baseball bat made of Carbon fiber with 4 section non-rotational twist lock legs. The lower section is as robust as many upper legs of CF tripods........check the attached photos.
It's as good as a Gitzo at half the cost.....
you can use a tilt head like a Manfrotto 234RC2 or a much more fluid head like the Kirk... http://www.kirkphoto.com/Kirk_MPA-2_Monopod_Head.html
......which is less expensive than the RRS MH-01 models....... http://reallyrightstuff.com/Items.aspx?code=MH01&key=cat
 Hank3152's gear list:Hank3152's gear list
Canon PowerShot S95 Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EF 300mm f/4.0L IS USM Canon EF 100mm f/2.8L Macro IS USM +5 more
