Home studio setup (lighting) question......
Started Apr 9, 2013 | Questions
studionewbie New Member • Posts: 3
Hello,
Hugowolf Forum Pro • Posts: 12,542
Re: Home studio setup (lighting) question......
This is the most back to front post I have ever seen. I had to turn it around to read it.
studionewbie wrote:
Hello,
I am a newbie trying to setup a home studio and I need some advice....
The area that I have is approximately 10' (W) x 6' (H) x 12' (D).  I am planning to buy a 10' wide background support, with 9' wide muslin and vinyl backdrops.
As for lighting, I have just purchased a Bowens Germini 400/400 rx kit. I intend to use them for key light and fill light respectively. They come with a wireless "pulsar" module where I would plug into my camera hotshoe, to trigger the flash.
The big question:  I am looking to have a back light and a background light.... what kind of product would people typically purchase for studio of this size /setup, and how would they set them up?
Currently, I am looking at Flashpoint 160 budget kit with two lights: http://www.adorama.com/FPBK1.html
However, I am unsure if this is a good choice. For example, it doesn't have come with reflectors (not sure if it is a must for back /background lights); also,
Not only do they not come with reflectors, there is no mention of an accessory mount what so ever. They may have built in reflectors, and no means of mounting anything else, which wouldn't be good.
I would look to getting lights with the same mount as your Bowens lights, maybe even lower powered Bowens.
I am unsure if it can be triggered properly.... I am thinking that my BG400 units will be triggered by the wireless pulsar module, which will then the Flashpoint units (i.e. photo slave of the Flashpoint detecting the flash of BG400).  Is this how it should work???
Yep, set them in optical slave mode and they will be triggered when your other lights go off. You will have no remote control over their power settings, just triggering.
Many thanks!!!!
No problem.
antares103 Senior Member • Posts: 1,053
The lights look to be the type which have no inherent light mod attaching system. They take the "universal" modifiers, which are just 4 thumb screws. When (not if) these lights crap out, they will be tossed, along with the mods.
Don't waste your time or money. One decent light will be better than two of those.
Film is a four letter word
 antares103's gear list:antares103's gear list
NEX5R Sony Alpha NEX-6 Canon Pixma Pro9000 Mark II Adobe Photoshop Lightroom 5 Snapseed +1 more
Sailor Blue
Sailor Blue Veteran Member • Posts: 9,278
studionewbie wrote:
Hello,
Many thanks!!!!
However, I am unsure if this is a good choice. For example, it doesn't have come with reflectors (not sure if it is a must for back /background lights); also, I am unsure if it can be triggered properly.... I am thinking that my BG400 units will be triggered by the wireless pulsar module, which will then the Flashpoint units (i.e. photo slave of the Flashpoint detecting the flash of BG400).  Is this how it should work???
DO NOT BUY THESE LIGHTS.
As already mentioned, they don't have speedring attachments.  The power of the strobe is also not adjustable, and power adjustment is an absolute must.
Here is a much better light for hair, accent, and background.  Check with Adorama but I'm pretty sure you can buy speedrings, grids to fit the 8" reflectors, and other accessories like barn doors.
Adorama - Flashpoint II 320M, 150 Watt Second AC / DC Monolight Strobe
10'w is too small.  By the time you get two light stands with lights and diffusers in you will only have about 3'-4' of space to cram in a subject, and the diffusers will be about 1.5'-2' from the subject.  You need a wider space.
6' height?.  Do you mean 8' ceiling height?  I sure hope so, and even that is very limiting - I know because it is what I have to work with.
12' deep.  The subject should be 6' from the background.  Even with paper taped to the wall as a background you are only left with 6' of distance to the far wall, which means that the camera would be about 4.5' from the subject.  You would have to use a wide angle lens and you would get extension distortion in all your image, even with head shots.
You want to be 15' or further from the subject to minimize distortion and to give your images the same appearance as what your memory provides.
Portrait Lenses
You need about 25'-30' to be really comfortable.  That lets you get the subject 6'-10' from a background and gives you enough subject to camera distance that you can use longer focal lengths.  I love my 70-200 mm lens on my 7D for waist up or head shots, and it can easily put me more than 15' from the subject.  I go to my 28-70mm lens for full length portraits.
The way I get 26' of length is by combining my dinning room with my living room by shoving all the furniture out of the way.  You can get a bit more space by shooting corner to corner in a small room or by shooting through a doorway.
I suggest you read my article on equipment for a small home studio before investing any more money.  You don't want to waste money on low quality equipment that won't do what you want like I did the first time and like the ones you asked about.
Sailorblue - Digital Photography Review - Equipment Guide for Setting up a Small Home Portrait/Glamor Studio
Living and loving it in Bangkok, Thailand. Canon 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Tamron SP AF 90mm F/2.8 Di Macro +10 more
studionewbie OP New Member • Posts: 3
Thank you all for the help and your valuable comments!  I have decided to start with two lights before spending more money..... By the way the equipment guide is an excellent read......
