Possibly in wrong section, need help with radio triggers and flashguns
Started Apr 9, 2013 | Questions
littlegreen
New MemberPosts: 5Gear list
Apr 9, 2013
My setup is a D90, two SB 700 flashguns and 4 Bowens Pulsar transceivers. I had one flash working fine using the CLS system but when using two and also using modifiers on the flashes, the line of sight is blocked and they're not firing half the time. So, what I want to do is set up the flashes with my radio triggers but they won't flash.
All the equipment is in working order and I've double checked using different leads, so it's definitely something that I'm doing wrong. It's my first time doing this setup so don't judge me too harshly if I'm overlooking something very obvious!
So, to demonstrate my lack of flash, I have just set up one flash with hot shoe adapter to my bowens pulsar, set to rx for receiver. In fact- here are the photos, they'll explain it better than I can.
http://www.flickr.com/photos/94775371@N05/8634597534/
http://www.flickr.com/photos/94775371@N05/8634597942/
http://www.flickr.com/photos/94775371@N05/8634597772/
Thank you so much for looking and thank you even more if you can help me,
Sarah
 littlegreen's gear list:littlegreen's gear list
Nikon D90 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S DX Nikkor 10-24mm f/3-5-4.5G ED Nikon AF Nikkor 50mm f/1.8D +1 more
Nikon D90
Peter Berressem
Forum ProPosts: 10,647
Re: Possibly in wrong section, need help with radio triggers and flashguns
In reply to littlegreen, Apr 9, 2013
All what you did looks correct - the only thought is: maybe that the metal hotshoe irritates / has contacts that err the Pulsar ?? Did you by chance try without the flash connected to the hotshoe?
cheers, Peter
Germany
fotowbert
Senior MemberPosts: 1,919Gear list
Possible solution:
Possible solution:
I don't have your identical gear but your photo shows the SB700 in "remote" mode and as such it will only respond to a CLS Commander IR signal.  Take in out of remote and it should respond to the electrical signal of the connected radio trigger receiver.
Set the SB700 to manual power level and adjust the flash exposure by varying the power level from the back of the flash.  With simple radio triggers flash exposure is all manual.
This is the correct forum btw.
  • John
 fotowbert's gear list:fotowbert's gear list
Canon PowerShot A20 Canon PowerShot SD870 IS Fujifilm FinePix F31fd Panasonic Lumix DMC-LZ8 Canon PowerShot S95 +15 more
Peter Berressem
Re: Possible solution:
In reply to fotowbert, Apr 9, 2013
John, good catch I suppose.
cheers, Peter
Germany
littlegreen
Hi John, thanks for replying. In desperation I think I tried every setting available. With the setup in the photos I do have it switched to m on the left hand side, but quite sure I also tried it turned to 'on' instead of remote. I will have another go tomorrow but my hopes aren't high. Will also check the hot shoe adapter too just in case. Still at a loss to be honest...
Thanks guys,
Sarah
