Can Yongnuo 622C Triggers also be used as shutter releases?
Started Apr 8, 2013 | Discussions
abhijats New Member • Posts: 1
Hi everyone,
Wondered if anyone knew if it was possible to use the Yongnuo YN-622C transceivers as shutter releases as well?
I'm setting up a photobooth and would like the guests to be able to fire the shutter themselves if possible? I'm using a 7D for the booth as well.
Would appreciate the help. With thanks,
Ab
SeedyBee Regular Member • Posts: 150
Re: Can Yongnuo 622C Triggers also be used as shutter releases?
No. But you can use other radio or cable devices as a shutter release when you are using the YN-622C to control/fire flashes.
It takes 80 to 130 milliseconds after EOS camera shutter press for the camera to issue the Fire! command.
Clive
 SeedyBee's gear list:SeedyBee's gear list
Canon EOS 50D
Sailor Blue
Sailor Blue Veteran Member • Posts: 9,296
No, the YN-622 can't be used as a remote trigger for the camera.
The way to do it is to buy a pair of RF-602s (not RF-603s) and the N3 connector cable for the Canon.  The cable will connect the receiver to the camera and trigger it when the subject presses the test button on the transmitter.
When the shutter opens the YN-622 mounted on the hot-show will send out the trigger pulse to the flash.  The RF-602 and YN-622 won't interfere with each other.
Amazon.com - Yongnuo New RF-602 C3 Wireless Remote control Switch & Studio Flash Trigger Combi System for Canon Eos 1D,1DS,5D,5DII,7D,10D,20D,30D,40D,50D
Now my question is why the heck do you want to use a YN-622?
The last thing you want to do is use off-camera flash in TTL mode if the subject to flash distance is fixed, as it generally is in a photo booth type setup.  If you use any form of TTL the exposure will change with each different type of clothing the subjects wear. The result is a nightmare of post processing exposure adjustments.
You are far better off using the camera in full manual exposure mode and using the off-camera flash in full manual power control mode. Get the exposure right and forget it - all the images will be properly exposed with no variations.
The only reason for using the YN-622 would be to allow you to adjust the manual flash power at the beginning, and to my mind that hardly justifies the cost of the YN-622 over a total of $55 for a dual RF-602 system.
YONGNUO RF-602 2.4GHz Wireless Remote Flash Trigger for CANON
I use two RF-602 systems myself.  One set is on one frequency to act as a camera trigger, the second set is on a different frequency for the off-camera flash trigger.  It is extremely reliable for an investment of less than the cost of one YN-622 system.
Living and loving it in Bangkok, Thailand. Canon 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Tamron SP AF 90mm F/2.8 Di Macro +10 more
Prairie Rim Images
Prairie Rim Images New Member • Posts: 4
I fully understand why a YN622 (or any other device) can't trigger both a shutter and the flashes at the same time.  However, what if I want to use my YN622 to fire the flashes with some setups, and fire the shutter with other setups?  Why can't I just get (or make) a cable that connects the YN622's PC-sync port to the Canon's N3 port?
For example, I need the various flash firing features of the YN622 for lots of different things.  I also shoot sports sometimes (without any flash), and I like to be able to setup a remote camera behind the goal and have it automatically fire when my primary handheld camera fires so that I get two views of the same action.  The concept is well-proven, and I've used it myself with cheaper, less-reliable triggers.
Now I'm looking to upgrade triggers, and the YN622 is at the top of my list.  What is it about the YN622 that prevents the PC-sync port from triggering the camera shutter?
Dan Marchant Senior Member • Posts: 2,363
The YN603 can trigger both the camera shutter and flashes at the same time so I assume that with the 622 it is just a design decision (or rather a sales one). I think (might be wrong) that the 622 simply does not have a socket for the PC sync cable/shutter connecting cable. If I had to guess I would say they want you to buy a 602 as remote shutter release and 622s for the advanced flash trigger features.... with the 603 sitting in the middle doing both shutter release and flash triggering, but only in manual mode.
Dan
f/2.8 is a smaller number than f/22 in the same way that 100 is a smaller number than 20.
I am learning photo graphee - see the results at www.danmarchant.com
 Dan Marchant's gear list:Dan Marchant's gear list
Canon EOS 5D Mark III Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-105mm f/4L IS USM Canon EF 40mm f/2.8 STM +1 more
Prairie Rim Images
The 603 is effectively two triggers in a single package, which is how it triggers both the shutter and the flash with one button press.  That's not what I'm asking about.  The 622 receiver has a socket that gets triggered by the transmitter.  What prevents me from attaching a cable from the PC-sync port on the receiver into my N3 shutter port on the camera and thereby using the 622 to trigger my shutter remotely?  When YN claims that the 622 can't trigger shutters, do they really just mean that they won't sell you a cable with the proper ends on it, or is there more to it than that?
czesuaw2 New Member • Posts: 12
I use a pair of 603 to remote trigger the camera. Receiver is hanging on the cable connected to the shutter input on my D7100, 622 is on the Hot shoe of the camera to trigger TTL (or manual) flashes. You can put 622 over the 603 too.
622 have no output to trigger the camera shutter, you can't use PC-socket to do that.
If I'm using flashes on manual mode  I'm using a few of 603 only. If some flashes are difficult to adjust (inside a softbox or very high) I'm using 622 to adjust those from the transmitter on the camera.
As now the 622 TX is available (for the moment for Nikon only) the adjustment will be even easyer than before but I can adjust different flashes quite fast.
 czesuaw2's gear list:czesuaw2's gear list
Sony Alpha 7R II Sony FE 55mm F1.8 Sony FE 24-70mm F4 OSS Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Sony FE 28mm F2
lynnG Regular Member • Posts: 207
I know these discussions have been posted for a while. I just figured out that you can use YN622C and YN622C-TX to trigger Canon camera without any cable. What you have to do is to connect a Canon or Yongnuo flash to a YN622C and insert YN622C-TX into the flash hotshoe of a Canon camera. You need using another YN622C in hand as shutter release controller.
For Canon cameras produced after 2012, you don't need any C1 or C3 LS-2.5 cable, simply press the test button in you YN622C in hand, the flash will fire. One second later, both shutter and flash will be triggered all together automatically. In order to enable this function, you should set C.FN02 in your YN622C-TX "on". You can disable this function by setting it to "Off".
For cameras produced before 2012, you may use C1 or C3 LS-2.5 cable connecting YN622C-TX to the camera's remote control socket.
I hope this helps.
PS. This function works for DSLRs only but does not work on Canon EOS-M.
Prairie Rim Images
lynnG, how are you connecting your 622C to your Canon body?  Where did you find a cable that would mate a PC-sync socket to a Canon N3 socket?  Or did you just make your own by splicing together two other cables?
The cable connects to the 2.5mm socket on the side of the 622C-TX, not to the PC-sync-IN socket. See TOYUG II v5.0, page 60.
YN provides two cables in the box - for N3 and E3 fitted cameras. See TOYUG II v5.0 page 52.
TOYUG? The Other YN622C User Guide II at
https://drive.google.com/file/d/0B77OmmGIg0gMMzZFaDVlZ1VNTE0/view?usp=sharing
Clive
Canon EOS 50D
