water splash - fail
Started Apr 8, 2013 | Photos
b4cktr4ck
b4cktr4ck Regular Member • Posts: 156
water splash - fail
Hi,
I wanted to freeze the water splashing but the result is not what I wanted
I set the camera to the highest sync speed (1/180), as I noticed that with slower shutter speed the shot was even more blurred. Medium aperture f/6.3 to get people in focus and increased the ISO high to get some ambient light.The flash was off camera and behind a white shoot thru umbrella, about 1/4 power.
Maybe using direct flash would have frozen better the water? but I didn't want to have harsh light on the people
 b4cktr4ck's gear list:b4cktr4ck's gear list
Canon EOS 6D
hotdog321
hotdog321 Forum Pro • Posts: 15,190
Re: water splash - fail
This looks pretty good, but I think you got ghosting from the ambient light. The only way I can think to freeze the splash is to shoot in dim light and let the flash freeze the action. I shot this one during my film daze and turned out the dojo lights. Not perfect, but there was still some ambient light and I was having to shoot at something horrible like 1/60 or 1/125 sec:
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark III Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM Canon EF 16-35mm f/4L IS USM Canon EF 11-24mm F4L +1 more
SeaScout851
SeaScout851 Veteran Member • Posts: 6,157
Set the camera to high speed sync.  Then go to manual mode.  You'll then need to try different settings to make sure you get the light right.  But I'd start with something like ISO 400,  F5.6 and 1/1000 sec.
Andy
b4cktr4ck
b4cktr4ck OP Regular Member • Posts: 156
is there any disadvantage in using HHS?
Canon EOS 6D
Peter Berressem
Peter Berressem Forum Pro • Posts: 10,647
Well, you lose some (3 f/stops) of the flash power, resulting in either a wider aperture or higher ISO.
cheers, Peter
Germany
b4cktr4ck
so it's like a compromise right. I can freeze the water but I may not be able to capture ambient light and/or use a wider aperture and potentially loose some focus on the people
Canon EOS 6D
LincolnB
LincolnB Veteran Member • Posts: 4,082
b4cktr4ck wrote:
Hi,
Yes, because a higher percentage of the lighting is coming from ambient and thus being captured at the full shutter duration. The longer the shutter is open the more blur you're going to get. You wanted the majority of your lighting to come from flash, not ambient. Essentially the ambient is being recorded at 1/180th of a second while the flash is roughly 1/2000th (depending on your flash unit).
Then use flash with as diffuse light source as you can manage, e.g. a larger umbrella or a closer umbrella.
This is a mix of mostly flash and and a little bit of ambient, at 1/60th. Note the combination of both blur and freeze-frame:
These are almost entirely lit with flash:
 LincolnB's gear list:LincolnB's gear list
Olympus PEN E-P1 Panasonic Lumix DMC-G3 Fujifilm X-E1 Sony Alpha 7 II Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 +8 more
b4cktr4ck
thanks for the clarification and examples! building experience
Canon EOS 6D
