Change my sigma 30 2.8 to a 19mm?
Started Apr 8, 2013 | Discussions
Janne303 Regular Member • Posts: 276
Is there someone out there who has changed your sigma 30 to an 19mm? I have a 50mm but no wideangle. Is the 19mm something to consider?
uhligfd Senior Member • Posts: 1,912
Re: Change my sigma 30 2.8 to a 19mm?
Yep, one can make a 4 inch nail into a 2 inch one ... by filing away.
What exactly do you mmean by changing one lens into another? Surely one might do so by disassembling, re-grinding the individual pieces of glass inside the lens, changing the lens arrangements and so forth.
But would anyone do so? For you? Are you kidding? Just buy the 200 $ 19 mm lens and enjoy.
sarit
sarit Regular Member • Posts: 266
I guess he meant whether he should replace his Sigma 30mm with a 19mm.
 sarit's gear list:sarit's gear list
NEX5R Sigma 30mm F2.8 EX DN Sigma 19mm F2.8 EX DN Sony E 16-50mm F3.5-5.6 PZ OSS +4 more
peruchox Regular Member • Posts: 252
I have both. When I go to the beach or know that I want a wide angle shot on the beach, then I take the 19mm.
If I'm going for a walk and go light then I take the 30mm.
When with family and friends I usually take the kit lens as it has OSS and you can zoom.
 peruchox's gear list:peruchox's gear list
Sony a6000 Sony E 55-210mm F4.5-6.3 OSS Sigma 30mm F2.8 EX DN Sony E 16-50mm F3.5-5.6 PZ OSS Sony E 35mm F1.8 OSS
captura Forum Pro • Posts: 21,781
Maybe he wants to know if a Sigma 30 can be modified to become a 19 which of course is impossibe.
joe talks photography
joe talks photography Regular Member • Posts: 247
if you think the field of view is not wide enough with the 30mm you might consider getting the 19mm. the 19 is not as sharp but is great enough...with wider view. I have both and each has a good use for my style of shooting pics.
Joe
davect01
davect01 Veteran Member • Posts: 7,089
I take it you only want one.  Why not both?
The 19mm is great for intimate, party type shots and nice wide shots, whereas the 30mm is more of an everyday lens.
I personally have the 19mm and love it.  Seriously considering the 30mm.  If I do, I will resale one of my manual lenses.  Not one to keep multiple lenses of the aproxiamte length.
Novice photobug, proud NEX-3 owner
http://davesnex-3photos.blogspot.com/
Joe
The myth of the 19 mm Sigma being inferior to the 30 is specific to this forum only. I have both models, and I am an early purchaser of the 19. Roger Cicala reviewed these lenses along with the m43 versions and found them all to be remarkably equal in MFT.
SandyKHo Senior Member • Posts: 2,510
Joe
I, too, have both the Sigma 19 mm and the 30 mm and I find them to be equally sharp.  If I had to choose one over the other, I would probably choose the 19 mm to cover those occasions where wider angle is necessary.
God gave us an incredible world. See it, hear it, Touch it, taste it, smell it, PHOTOGRAPH IT!
 SandyKHo's gear list:SandyKHo's gear list
Canon PowerShot SD780 IS Sony Cyber-shot DSC-HX50V Canon EOS 60D Sony Alpha NEX-5N Canon EOS 70D +17 more
cptrios Senior Member • Posts: 1,352
Joe
I own both too, and can unequivocally state that the 19 (of which I've owned 3 copies) is inferior to the 30. They might be pretty much the same on m4/3, where the worst part of the 19's image is cropped away, but they're certainly not on the NEX. The 19's center sharpness is as good as the 30's, but it's got noticeably worse CA and substantial field curvature that leads to border softness in most situations.
It's still a great lens for the money, though (the older, cheaper one at least) and is kind of a no-brainer purchase. And if you've got a NEX-7 in particular, the 24mp means you'll need to print really large before the field curvature becomes apparent.
Cailean Gallimore Veteran Member • Posts: 6,082
They are so cheap that almost anyone could buy both. The 30mm in particular,  is very cheap for what it is. Well done Sigma.
John Knuhtsen
John Knuhtsen Contributing Member • Posts: 686
It is so typical behaviour (for the better part of us) on a technical forum like this. An unprecise question and first of all, no supervision for responses to make a dialog. Now 9 hours passed, and 10 confused answers with no correction done on, what was meant. So typical ! (excuse me) that I could laugh.
Joe
That is your subjective opinion, but why did you need three? Was it a bad  ger Cicala said that the 19 and 30 on the NEX-7, tested equally.
That is your subjective opinion, but why did you need three 19's? Was it a bad batch, perhaps?  Roger Cicala said that the 19 and 30 on the NEX-7, tested out equally.
Joe
Hi cptrios, here's the comparison:
NEX-7 Lens Imatest Results
Posted by Roger Cicala
http://www.lensrentals.com/blog/2012/04/nex-7-lens-imatest-resolution-comparison
MTF 50 at f/2.8
Lens Max Avg
Sony 16mm f/2.8 665 490
Sigma 19mm f/2.8 870 740
Sony-Zeiss 24mm f/2.8 960 735
Sony 18-200 f/4 855 680
Sony 18-55 20 f/4 855 640
Sony 30mm f/3.5 940 725
Sigma 30mm f/2.8 985 805
Sony 50mm f/2.8 806 732
Leica 50mm f/2.8 920 730
