inane prattle
Started Apr 8, 2013 | Discussions
James Pilcher Veteran Member • Posts: 8,464
inane prattle
8
In a current large thread, one of our own wrote this:
"Big aperture lenses for m4/3 are not really needed because of improvement in sensitivity - and IBIS in Oly. [S]o again, a form of snobbishness."
[insert expletive here] By his measure, the Nikkor 200mm f/2 VR is not really needed on Nikon's ultra-sensitive DSLR bodies. Put that VR in a 200mm f/6.3 and that's all those Nikon folks really need. Own anything faster and they are snobs.
How many of you are now going to toss your f/2 and faster "snob" lenses? Apparently you don't really need them.
Jim Pilcher
Summit County, Colorado, USA
 James Pilcher's gear list:James Pilcher's gear list
Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 75mm F1.8 Fujifilm X70 Olympus PEN-F +7 more
Ollie 2 Senior Member • Posts: 1,530
Re: inane prattle
That's just like, his opinion, man.
I see his point.
But I'm keeping my 0.95's.
 Ollie 2's gear list:Ollie 2's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Olympus PEN E-P2 Fujifilm X-Pro1 +19 more
James Pilcher OP Veteran Member • Posts: 8,464
opinions and paper weights
Yes, I agree that everyone is entitled to an opinion, no matter how uninformed or misguided.
I see his point.
I'm not sure, but if you see his point, I think the rules stipulate that you must use only kit zooms from this point forward. Those 0.95's will make very solid paper weights, though.
Jim Pilcher
Great Bustard Forum Pro • Posts: 33,341
For sure, but...
...such comments are to be expected from someone who "loathes bokeh", feels that deep DOF and sharpness across the frame represent the epitome of photography, and anything else is "snobbery".
JeanPierre Martel Senior Member • Posts: 2,844
Re: inane prattle
"Big aperture lenses for m4/3 are not really needed because of improvement in sensitivity - and IBIS in Oly. [S]o again, a form of snobbishness." (...)
Look at it the other way. I already have a cheap and very sharp telelens. But its widest aperture is F/4,0.
Since I don't care when ISO reach 3,600, will I pay a thousand of dollars to get a heavy and faster telezoom with razor thin DOF when its diaphragm is fully open? Probably not.
I'm not suggesting that such a lens is useless. I'm just saying that if I was unable to take picture above 800 ISO, I would desperately need faster lenses.
 JeanPierre Martel's gear list:JeanPierre Martel's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Olympus 12-40mm F2.8 Leica Nocticron 42.5mm Olympus 40-150mm F2.8 Pro +24 more
zxaar Veteran Member • Posts: 3,941
what is not expected ..
what is not expected from such person is his investment in m43 sensor rather than pentax Q or smaller sensor cams or cellphones. Nothing could beat pentax Q with 50mm F1.8 etc lens when deeper DOF is needed.
::> Knowledge is mother of efficiency.
dgnelson Contributing Member • Posts: 815
Re: inane prattle
10
Whereas I might not agree with what the person you are talking about said, I don't think it's fair to start a thread to pick on him.  Let it go.
Dan
PC Wheeler
PC Wheeler Forum Pro • Posts: 16,030
Re: inane prattle
Lots of inane prattle to be found in any forum, Jim. You cited one of the lesser examples
At least it wasn't nasty like some I've found.
Phil
 PC Wheeler's gear list:PC Wheeler's gear list
Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-ZS100 Sony Alpha a6300 Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA Sony E 50mm F1.8 OSS +5 more
Dave Sanders Senior Member • Posts: 1,797
Re: inane prattle
The dude abides.
Dave Sanders
Landscapephoto99 Senior Member • Posts: 2,734
Re: inane prattle
Jim Pilcher
This may be a common feeling amongst those who are used to taking snapshots with a point and shoot and suddenly find themselves with Oly's nice IBIS / great high ISO.  They don't understand composition, DoF, etc. but will likely learn the craft of photography over time if they keep at it.
Paul De Bra
Paul De Bra Forum Pro • Posts: 12,063
That statement is wrong for a different reason...
It is true that sensors have become better and IBIS is very good as well. But there is another reason for still wanting faster lenses:
- Typically a lens is at its best when stopped down at least 1 stop but in most cases 2 stops.
- With the smaller m43 sensor (relative to 35mm) diffraction sets in earlier. The optimal f-stop for m43 seems to be f/4, with f/5.6 still quite usable but f/8 starting to show diffraction.
These two factors combined mean that unless a lens is already at its best wide open you need at least an f/2.8 lens (1 stop down means f/4 and 2 stops down means f/5.6 so that just does it) and that f/2 is actually a safer bet (with 2 stops down reaching the optimal f/4 stop).
So the only really valid argument that says we don't need faster lenses (except for shallow DoF) would say that we don't need lenses faster than f/2.
If you would translate this story to APS-C it would say that f/4 lenses are acceptable and f/2.8 is better, and for 35mm f/5.6 is acceptable and f/4 is better.
Slowly learning to use the Olympus OM-D E-M5.
Public pictures at http://debra.zenfolio.com/.
 Paul De Bra's gear list:Paul De Bra's gear list
Fujifilm FinePix F200EXR Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +5 more
richarddd
richarddd Senior Member • Posts: 2,982
Re: inane prattle
 richarddd's gear list:richarddd's gear list
Olympus OM-D E-M5 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 UMC Fisheye MFT +3 more
Detail Man
Detail Man Forum Pro • Posts: 16,420
Sharpness is not everything, absolutely, ...
... but resolution perhaps is.
s_grins
s_grins Forum Pro • Posts: 10,299
Re: inane prattle
Jim Pilcher
Even so I agree with you, the reason to respond is your snobbish - "Nikon's ultra-sensitive DSLR bodies"
It stinks too.
Regards.
S.
Looking for equilibrium...
 s_grins's gear list:s_grins's gear list
Panasonic Lumix DMC-GH2 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Sigma 30mm F2.8 EX DN +3 more
(unknown member) Veteran Member • Posts: 3,348
Re: inane prattle
I'm obviously a snob.
I don't own anything slower than 2.8 and never will.
tt321 Senior Member • Posts: 7,265
Re: what is not expected ..
You don't need a Pentax Q to have the kind of DoF he wants. Just stop your FF wide angle (or even standard lens) to about F8 (or your M43 to F4) and you are there in the vast majority of cases.
Just Having Fun Veteran Member • Posts: 3,869
Partially true
As others and I have discussed in the Nikon forums, since I can shoot fast action sports at 1/2000+ sec shutter speeds at F/5.6 and higher with my D600 (and still have virtually no noise), the only reason to use F/2.8 would be to get a shallower DoF.
olliess Senior Member • Posts: 1,075
Re: Partially true
An f/2.8 lens will help your AF for fast action sports, though.
Anders W Forum Pro • Posts: 21,465
Re: That statement is wrong for a different reason...
That's true as a purely descriptive empirical generalization, although if we are talking FF lenses rather than MFT lenses, you'd have to add another stop or two. With such lenses, at least if they are pretty fast, it is not unusual that you have to stop down three or even four stops before the optimum is reached.
But why is it that you have to stop down to reach optimal performance? Is it because it is impossible to design an f/4-lens that is just as good wide open at f/4 as an f/2-lens stopped down two stops? I think not. Rather, I think it is because it is easier to keep optical aberrations at bay at f/4 than at f/2.
Personally, I'd much rather have f/2-lenses that peak at f/4 than f/4-lenses that peak wide open even if the performance from f/4 on is just the same. But there is no doubt in my mind that the f/4-lenses we are talking about could be built.
Panasonic Lumix DMC-G1 Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH +28 more
String
String Senior Member • Posts: 1,575
Re: Partially true
And you are not going to shoot hockey at 1/2000 and f5.6 on any current camera.
 String's gear list:String's gear list
Olympus E-M1 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus 12-40mm F2.8 Olympus 40-150mm F2.8 Pro +3 more
