Does anyone care about moire?
Started Apr 8, 2013 | Discussions
sigala1 Senior Member • Posts: 3,634
Camera makers finally got the message. They always got dinged for having a resolution-destroying optical-low-pass filter, but no reviews ever say anything bad about moire. So Nikon finally decided to give the reviewers what they really want, although if you look at most new cameras, the OLPF is very weak and most current DSLRs make moire on this coin. The E-M5 hardly has any moire, so I included that as a comparison.
I personally would prefer slightly less resolution and no moire.
Reilly Diefenbach
Reilly Diefenbach Veteran Member • Posts: 9,886
Re: Does anyone care about moire?
24000 pixels out of 24,000,000. Is it really worth blurring the rest of the picture?
http://www.flickr.com/photos/51747496@N08/8630532806/sizes/o/in/photostream/
103kb
5 seconds with the LR4 moire brush.
Stacey_K
Stacey_K Veteran Member • Posts: 7,815
I agree. It's like CA, even if it can be fixed in photoshop, it shouldn't be there to start with. It's just one more step that you have to look for this defect and fix required for each image..
Stacey
 Stacey_K's gear list:Stacey_K's gear list
Nikon D200 Nikon D700 Nikon D7000 Nikon D800 Sony Alpha 7 +14 more
fotolopithecus Senior Member • Posts: 1,699
The more moire the merrier.
 fotolopithecus's gear list:fotolopithecus's gear list
Nikon D610 Tamron SP AF 90mm F/2.8 Di Macro Nikon AF-S Nikkor 50mm f/1.8G
JimPearce
JimPearce Veteran Member • Posts: 8,755
I'm so glad I have a D7000 that is out of date...
Jim
 JimPearce's gear list:JimPearce's gear list
Nikon D7100 Nikon D500
Shakens
Shakens Regular Member • Posts: 430
just buy a Dslr with a optical-low-pass filter then, you don't have to buy the D7100.
it normal every day use you're not going to see any moire
just having less resolution wont mean no moire or we wouldn't have most cameras with a optical-low-pass filter now would we
Nikon D5100...Canon SX230HS...Panasonic FZ48/TZ6
Hi from England
 Shakens's gear list:Shakens's gear list
Panasonic Lumix DMC-ZS1 Canon PowerShot SX230 HS Panasonic Lumix DMC-FZ47 Nikon D5100 Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR +7 more
Reilly Diefenbach
Fear of moire may be contagious, but I might point out that I have never seen moire or touched the moire brush in about ten thousand shots with the D800e, nor do I know anyone who has.  The D7100 should be similar.  It's your funeral if you want to throw away the extra resolution, color and contrast simply because you might possibly have to brush for thirty seconds.
If there are closely spaced vertical slats,you might want to keep an eye out for it:
http://www.flickr.com/photos/51747496@N08/8339091543/sizes/o/in/set-72157630696943482/
but for the most part it will not even be worth fixing:
coudet Veteran Member • Posts: 3,869
Re: I'm so glad I have a D7000 that is out of date...
JimPearce wrote:
Why, though? It's pretty bad too: link.
It's actually even slightly worse than D7100 in some other areas of the test scene, look left of those colored cotton balls (or whatever they are!) or at that red net (?), left of the card. There's no substitute for more megapixels. It would have been even better if it had AA filter, but it is what it is.
E-M5 also shows aliasing in the test scene.
Wrong answer.
The correct answer is: more resolution and no aliasing artifacts. How do you get that, the best of both worlds? More megapixels + AA filter.
Mark Buckley Contributing Member • Posts: 516
Re: how about moire in Video ?
as someone considering a D7100 (although more like D7000 or D5200) - how much of an issue is Moire in Videos ? or when the camera outputs from the sensor to lowly 1080p - does it become a non-issue ?
just thinking that Moire is not too difficult to remove on still images- but I guess harder to remove in video ?
Whalligeo Regular Member • Posts: 245
It seems a perfectly reasonable development to remove the AA filter in the pursuance of technical excellence, regardless of what the press have to say (most journos are blind anyway). Moire is kicking around in quite a few cameras, yet no one is making a fuss about that. The irony is that when the moire pitches up on an AA filtered camera that is supposed to remove the moire, its almost noticed, and yet when we have a camera the isn't supposed to remove the moire by way of AA filter, because it isn't fitted, it gets loads of attention.
All of the following have moire in the same part of the picture, some better, some worse. Most with AA filter.
D4, D600, D800, D800e, D3200, D5100, D5200, D7000,
Canon EOS 5D MkII, (bloody awful), Canon EOS 5D MkIII (same), Canon EOS 6D,
The best camera is the Pentax 645D (as a reasonably priced expensive camera), but I'm guessing that is not what folk are looking for, but it is a clear demonstration how good MF is.
Moire is a fact of life, and its going to be around for a while longer. But, there is a button for it.
They said it couldn't be done, so I encouraged my peers not to bother.
Here is a review http://youtu.be/_gbf-CDd-AY moire is discussed at 10:00 into the vid. It's none event.
BlueBomberTurbo Contributing Member • Posts: 989
 BlueBomberTurbo's gear list:BlueBomberTurbo's gear list
Sony a6000 Nikon D750 Sony Alpha a6300 Sony E 18-55mm F3.5-5.6 OSS Sigma 70-200mm F2.8 EX DG Macro HSM II +13 more
Bailey151 Senior Member • Posts: 1,137
Exactly - remind me again what % of pics would this affect? Personally I don't take pics of fabric for a living.
No thanks, I'll take resolution and detail - deal with moire in the handful of images it may impact.
scokill Senior Member • Posts: 2,421
Re: Does anyone care about moire? NO..(nt)
No text.
 scokill's gear list:scokill's gear list
Nikon D610 Nikon Df Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF Nikkor 50mm f/1.8D +1 more
olliess Senior Member • Posts: 1,069
Fear of moire may be contagious, but I might point out that I have never seen moire or touched the moire brush in about ten thousand shots with the D800e, nor do I know anyone who has....
Is the pink/green striping on the panels of the taller rectangular building on the horizon a moire effect?
Nexu1 Senior Member • Posts: 2,576
Which would be more noticeable on an 8x10 or 24x36 print, the moire or the increase in resolution?  I doubt many could see either without deeply searching for it from a few inches away.
coudet wrote:
Wrong answer.
I think sigala1 had it right. It's less resolution from the same spatial sampling rate, or else a higher sampling rate (more megapixels) for a given resolution, to avoid aliasing.
sigala1 OP Senior Member • Posts: 3,634
The moire patterns like the one seen on the coin do NOT go away when you downsize the photo. But the loss of resolution from a strong OLPF filter becomes invisible when you do that.
How much resolution is ENOUGH or TOO MUCH?
I think there's a rather weird disconnect.
When Nikon first introduced 24 MP APS-C cameras, everyone said, "oh my god, that's TOO MUCH resolution, no one needs that much resolution or can do anything with it."
But when Nikon removes the OLPF so that the 24 MP sensor can have even more resolution, everyone praises this as the smart thing to do.
I don't get it. Is 24 MP too much resolution, or not enough resolution?
