What bath process do you do immediately upon import in Aperture?
Started Apr 8, 2013 | Discussions
qwerty11
qwerty11 New Member • Posts: 12
I've seen some people do a bath process immediately upon import regardless of the type of picture, scene, etc. I was wondering what everyone uses?
webfrasse
webfrasse Veteran Member • Posts: 3,853
Re: What bath process do you do immediately upon import in Aperture?
Rename (including original file) and add IPCT data.
Mikael
mnodonnell
mnodonnell Contributing Member • Posts: 639
Keywording, if relevant
For example, if the entire import batch was from a single session or location I'll get those keywords in at this point.
www.michaelneilodonnell.com
Alpha Doug
Alpha Doug Veteran Member • Posts: 9,219
Re: Keywording, if relevant
Possibly add an adjustment preset.  Also, split images into separate "Projects" if necessary.
Only my opinion. It's worth what you paid for it. Your mileage may vary! ;-}
www.dougwigton.com/
 Alpha Doug's gear list:Alpha Doug's gear list
Canon PowerShot S95 Sony SLT-A77 Olympus PEN E-PM2 Sony Alpha NEX-6 Sigma 17-70mm F2.8-4 DC Macro OS HSM +1 more
Jacques Cornell
Jacques Cornell Veteran Member • Posts: 6,141
No more selenium - too toxic
Bath process? Well, first I put it in a running-water rinse tank for 30 minutes to remove all the fixer...
After that, for indoor event work, I'll batch apply IPTC info, 0.25 Recovery, 0.15 Definition, default Edge sharpening, and 20/20/5 Highlight & Shadow. But then I go through them all and individually tweak.
'No matter where you go, there you are.'
 Jacques Cornell's gear list:Jacques Cornell's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus M.Zuiko Digital 45mm F1.8 Panasonic 20mm F1.7 II Panasonic Lumix G X Vario 35-100mm F2.8 OIS +27 more
unknown member
(unknown member) Veteran Member • Posts: 3,484
I use the Bubble Bath preset...
