Fusion and SSD question
Started Apr 8, 2013 | Discussions
fly1
fly1 Contributing Member • Posts: 574
Hi guys,
My very old windose laptop has finally gone to heaven, (may have gone somewhere else the way it was behaving;-) )
Now surviving with an iPad until about June 30 when I hope to get a  27" iMac, maxed out except I cannot decide on which HD
The storage on the 3TB fusion looks very tempting but I'm thinking the 768GB SSD would be attractive also,
Would there be much difference in speed between the two? I'm thinking mainly processing power and speed for image editing programs, and am planning to add another camera soon which is 36mp and files are around 100MB !
Gary
 fly1's gear list:fly1's gear list
Nikon D4S Nikon AF-S Nikkor 300mm f/4D ED-IF Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-120mm f/4G ED VR Nikon AF-S Nikkor 50mm f/1.8G +1 more
noirdesir Forum Pro • Posts: 12,488
Re: Fusion and SSD question
fly1 wrote:
Hi guys,
I'd say in 95% of all situations they will have a very similar speed. The Fusion Drive maintains a buffer of 4 GB. If you, eg, import images from a memory card of more than 4 GB, the import process will slow down after these 4 GB (of course things also depend on the speed of your memory card and card reader if they are slower than the 3 TB 3.5" HDD than you naturally will not see any difference).
fly1
fly1 OP Contributing Member • Posts: 574
Thank you for the heads-up,
I am using 16GB cards now for my wildlife images and I can see me increasing that to 32GB cards for future camera purchases, a 36mp camera will demand at least 16GB I guess
Starting to appear like.
Pone-up for the 768SSD and just store media on portable drives and leave the SSD for programs and processing,
At first 768GB SSD looked small but I guess it would handle a stack of software and still have enough in reserve if the media is stored externally?
Gary
webfrasse Veteran Member • Posts: 3,858
noirdesir wrote:
fly1 wrote:
Hi guys,
Where do you find that 4GB buffer info?
http://www.anandtech.com/show/6679/a-month-with-apples-fusion-drive/3
http://barefeats.com/imac12d1.html
Mikael
JulesJ
JulesJ Forum Pro • Posts: 39,636
fly1 wrote:
Hi guys,
Gary
I just got a new iMac 27" I got the fastest processor and bought the max extra RAM, but I did not go for the fusion drive. I don't run lots of programmes at once, usually just CS6 and sometimes LR4 together. I have had no speed problem issues at all in the couple of months of use so far. All is good.
webfrasse wrote:
noirdesir wrote:
fly1 wrote:
Hi guys,
Here for example: http://www.anandtech.com/show/6406/understanding-apples-fusion-drive
noirdesir wrote:
webfrasse wrote:
noirdesir wrote:
fly1 wrote:
Hi guys,
Looks like Anandtech contradicts themselves, look at my link above.
Mikael
webfrasse wrote:
noirdesir wrote:
webfrasse wrote:
noirdesir wrote:
fly1 wrote:
Hi guys,
Here is another link talking about a 4 GB buffer that however in some situations is increased to 8 GB.
On page six of your link Anandtech also talks about a 4 GB buffer. So, it really looks like 4 GB is the normal offer but in some situations, in particular writes, that can be expanded to 8 GB.
Snodayz Regular Member • Posts: 120
I'm in the process of buying the same machine, but have opted for the fusion drive.  My understanding is that internal busses are generally faster than external drives and so accessing photos within my library will be faster (although the initial boot into Aperture will be fractionally slower).  Photo editing should be identical between the two as that is done in RAM and 32Gb should be more than enough even for large individual files.  Lastly, I'm not keen on my primary library existing on something as portable as an external HD - way too easy for a burglar to walk off with.  I keep no less than three external backups of my photo library at all times with at least one of these off-site.  When my content eventually outgrows 3Gb my movies and music will go to external drives but I'll keep my photo library inboard for as long as possible.  Who knows, by then internal multi-Tb SSD's may be available and much cheaper than now.
 Snodayz's gear list:Snodayz's gear list
Canon PowerShot S100 Nikon D4 Nikon D800 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +11 more
