Need 512 GB SSD for Mac Pro (4,1) tower
Started Apr 7, 2013 | Discussions
iShootWideOpen
Regular MemberPosts: 326Gear list
Apr 7, 2013
I already have a 240GB OWC SSD HD as my main start up HD. I'm looking to add a larger SSD.
Any recommendations?
Thanks!
 iShootWideOpen's gear list:iShootWideOpen's gear list
Canon EOS-1D X Canon EOS 5D Mark III Canon EOS 5DS Canon EF 50mm f/1.2L USM Canon EF 85mm f/1.2L II USM +10 more
Howard Moftich
Veteran MemberPosts: 7,422
Re: Need 512 GB SSD for Mac Pro (4,1) tower
In reply to iShootWideOpen, Apr 8, 2013
http://www.sandisk.com/products/ssd/sata/extreme/?capacity=480GB
I'm using one of the 256's on a mac flawlessly.
noirdesir
Forum ProPosts: 12,182
Keep in mind that the SATA drive bays are limited to 300 MB/s because they are SATA 2. If you want something faster, you'd either need to create a striped software RAID out of two SATA drive bays (which really requires two SSDs of the same size), or you get an SSD that connects directly to a PCI slot (eg, the OWC Mercury Accelsior PCI Express SSD). You can see the speed difference here.
