s-m-c Takumar: any difference between old and new production re coatings?
Started Apr 7, 2013 | Discussions
BobORama
BobORama Senior Member • Posts: 2,057
Given a Super-Multi-Coated Takumar lens of some type, is there any difference between older and newer production of the same lens in terms of coatings?   I'm not referring to Takumar vs Super-Takumar, etc.   But rather if the coatings are significantly different between older and newer production runs of what, outwardly, is the the same lens?
 BobORama's gear list:BobORama's gear list
Pentax K-5 Sigma 10mm F2.8 EX DC HSM Diagonal Fisheye Pentax smc DA 18-55mm F3.5-5.6 AL WR Samyang 14mm F2.8 IF ED MC Aspherical +8 more
steephill Veteran Member • Posts: 9,702
Don't think so
My impression was that back then coatings only changed during model changes e.g. Takumar to superTakumar. However as this is the internet it is probably wrong :).
Steve
www.pbase.com/steephill
Col K10d
Col K10d Veteran Member • Posts: 3,216
Re: s-m-c Takumar: any difference between old and new production re coatings?
I would say not.  A marketing department (even Pentax's) would surely not let any change go through without it being advertised as an new improvement!
 Col K10d's gear list:Col K10d's gear list
Pentax K-3 Pentax smc DA* 300mm F4.0 ED (IF) SDM Pentax smc FA 43mm F1.9 Limited Carl Zeiss Distagon T* 2,8/25 Voigtlander 90mm F3.5 APO-Lanthar SL II +9 more
brandrx Forum Pro • Posts: 28,120
Bob,
My understanding is that there is no difference between the coatings of Super-Multi-Coated and S-M-C. Also, these are not "outwardly" the same lens. The Super-Muti-Coated have metal focus rings and the S-M-C have rubber on the focus rings.
Cheers.
Ron
Ron - 'We don't have time to go take pics this afternoon Carl.'
Carl - 'What do you mean? It will only take 1/1000s.'
'Keep your eyes looking forward. However, glance back now and then to see where you've come from. It will put a smile on your face.' ~ brandrx
BobORama
BobORama OP Senior Member • Posts: 2,057
Ron,
I guess I'm speaking of same lens model very different serial numbers.
BobORama wrote:
Ron,
Sorry Bob. I guess I misunderstood what you were asking. However, if the newer model S-M-C has the same coating as the older model Super-Multi-Coated, then I would think that all of the same lens, even if a different production run, would have the same coatings. Just my opinion.
Ron
BobORama
brandrx wrote:
BobORama wrote:
Ron,
Because of some odd luck with box lots at the silent auction, I ended up with some duplicate lenses and am trying to figure which ones to jettison out the air lock to recoup.   In a couple instances, the lower serial numbered ones are in better cosmetic / external / mechanical condition.   So if the later production were "better" some how optically, I'd keep them.
If you don't know the answer, I'm not sure who would.
I have to assume, as others have mentioned, that if there were some difference, they would have been marketing it.
Thanks!
Bob,
Here is an old thread (March 2006) that we were discussing S-M-C versus Super-Multi-Coated. There are a few links within that thread that might be some interesting reading for you so I suggest you read all of the replies.
Cheers.
Ron
MightyMike Forum Pro • Posts: 33,902
Ron you can correct me if i'm wrong but this is how i recall it...
- Takumar, Auto-Takumar and Tele-takumar (likely the same coating)
- then Super-Takumar
- then Super-Multi-Coated Takumar
- then SMC Takumar
- then SMC Pentax (K)
- then SMC Pentax-M
- then SMC Pentax-A
and on and on... I believe the coating did chance between Super-Multi-Coated and SMC, after SMC takumar the changes were likely not advertised but still happened
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/search/photo.search?sort_order=views%20DESC&first_this_page=0&page_limit=180&&emailsearch=mighty_mike88%40hotmail.com&thumbnails=
Bruce Trail Hiker Senior Member • Posts: 1,378
Hi Mike,
I picked up a Super Takumar 55mm f2 for $5 at a flea market on my recent trip to Washington DC - no fungus and comes with the original leather case.
Did some research on Takumar lenses and the question of "Radioactive" showed up.
As we are on the subject on these old but quality lenses - can you enlighten me if the Super Takumar 55mm f2 and the Super-Multi-Coated TAKUMAR/Auto-Takumar 85mm F1.8 radioactive or not?
If they are radioactive are they safe to use.
Man Khun
- then SMC Takumar
- then SMC Pentax-M
- then SMC Pentax-A
Mike from Canada
 Bruce Trail Hiker's gear list:Bruce Trail Hiker's gear list
Pentax K-3
I know my Super-Takumar 55mm F2.0 has a yellowing issue, the 2nd version of the Super-Takumar 50mm F1.4 has the issue, the 49mm version of the Super-Takumar 35mm F2.0 also
I don't recall which other ones might have it but it seems to be limited to the Super-Takumars
Mike from Canada
Yes totally safe to use, the thorium which is a rather mild radioactive substance over time turnd some of the coatings yellow, this yellow can be weak or stronger, unless its very strong the auto WB tends to compensate for it. It can also lower the amount of light that makes it through the lens, of course more so if its strong. the yellowing can be reversed by removing the rear cap wrapping the lens in foil leaving the front exposed and leaving it in direct sunlight for a few to several days, some have had to leave it for a longer time others not so long, the UV light is what reverses the yellowing and this doesn't change the effectiveness of the coating it just corrects the effect of the thorium.
Mike from Canada
Mike,
Thank you so much for the quick reply!
Now I am at ease with trying out these wonderfully built manual focus lenses!
Judging from the PF Takumar club - image quality from these Takumar lenses are excellent and beautiful!
Cheers
Man Khun
Mike from Canada
Pentax K-3
Just to make it more clear reading: Remove the front and rear caps. Wrap the lens in foil leaving the rear of the lens exposed and pointing towards the sun.
How to Cure Yellowing in Takumar 50mm f1.4 lenses.
Ron
Interesting, i was told the other way around, maybe thats why it hasn't been super effective for me
Mike from Canada
Joseph Tainter Veteran Member • Posts: 9,194
I wouldn't be so sure. The old SMC F 70-210 had an ED element that Pentax never advertised.
Pentax is not good at marketing.
Joe
kuuan Veteran Member • Posts: 3,546
Thanks!
'officially' the coating change was between Super Takumar and Super Multi Coated ( S-M-C ) Takumar and the SMC has the same coating as the S-M-C.
all your S-M-C lenses 'should' have the same coating regardless of serial number. If you have more copies of the same S-M-C lens I would not base my decision which one to keep on serial number but certainly would test them against each other, sample variation of old lenses quite often is considerable.
photos mostly taken with manual lenses on Sony NEX5N, Pentax K-x and *istDs: http://flickr.com/photos/kuuan/
 kuuan's gear list:kuuan's gear list
Fujifilm FinePix F31fd Konica Minolta DiMAGE A2 Pentax *ist DS Ricoh GXR Mount A12 Sony Alpha NEX-5N +1 more
Thanks Ron.
Cheers
Man Khun
Ron
Pentax K-3
Coldamus Senior Member • Posts: 2,281
Bob,
I agree with what Ron said but am throwing a spanner in the works.  You may need to consider more than just the coatings.
I recently bought a Super-Multi-Coated Takumar 135/f2.5.  Between submitting my bid and winning the auction, I discovered there are several versions of that lens and at least two versions of the Super-Multi-Coated variety.  The difference is in the number of lens elements (6 vs 5) and the number of aperture blades (6 vs 8).  I realised the one I was bidding on was the inferior version but at the price, was not unhappy about it.  There are two ways to tell the difference between the varieties: (a) - the number behind the auto/manual switch of the first version ends in 02 while on the second (better) version it ends in 12. (b) the last number before infinity on the metric distance scale is 30 on the first version and 35 on the better second version.
So what I am suggesting is that you may need to research each lens type individually in case there are significant differences other than the coatings.
Coldamus wrote:
Bob,
I agree with what Coldamus has written above. That "great" Super-Multi-Coated Takumar 135/2.5 is on par (image quality wise) with the SMC K135/2.5 lens. The SMC K135/2.5 has sometimes been referred to as "the poor man's A*135mm f1.8 lens". The SMC K135/2.5 also has the 35 reading just before the infinity mark. This lens can sometimes cost about US $200 or more.
Cheers.
Ron
